T3 Wiring
vincentrc
vincentrc is offline
PostPosted: Wed Aug 09, 2006 6:12 pm    Post subject: T3 Wiring Reply with quote
Well, I already did some research on a wiring harness for the T3, and am not sure what the best wiring harness kit out there is. I have a 1966 Fastback and I need to redo the wiring because mine is frayed, cut, and mickey moused beyond being fixed. ANy input on what harness anyone prefers would help me out alot, and I' am up for the challenge of installing harness.
-Thanks.
loading...
69sqbck
69sqbck is offline
PostPosted: Thu Aug 10, 2006 4:31 pm    Post subject: harness Reply with quote
I would go with the stock style replacement from ISP WEST
http://www.vwispwest.com/cgi-bin/perlshop.cgi?ACTI...=797859513
Don't think of yourself as an ugly person, think of yourself as a good looking Monkey!!!!!
1968 Ghia Vert
1969 Type 3 Squareback
1969 Type 3 Fastback
(o)\|/(o) Sole Designs, VW Restorations, Savannah, GA
spoon
Samba Penetrator
spoon is offline
PostPosted: Thu Aug 10, 2006 5:02 pm    Post subject: Reply with quote
HOw much of a bitch is it to replace a whole wiring loom anyway? Mine is all Mickey Mouse'd as well, causes me all sorts of issues!
Pit Bull Myths, Busted!
http://www.badrap.org/monster-myths
Type 3 > Type 1
Russ Wolfe
Russ Wolfe is offline
PostPosted: Thu Aug 10, 2006 5:22 pm    Post subject: Reply with quote
Depends on the body style. If the harness runs along side the drivers seat under the carpet, it is not too bad. On some of the early ones, and the T-34's, the harness runs through a conduit in the rocker panel.
Anytime you pull it through a hole or a panel, tie a strong cord onto it to pull the new one back in.
Gary: OK. Ima poop.
jimmynotch
jimmynotch is offline
PostPosted: Fri Aug 11, 2006 2:18 am    Post subject: Reply with quote
I did mine in a weekend on my 65. The harness runs through rocker and I had to remove both the front and rear fender, but that gave me oppertunities to do other stuff under there at the same time. Its not hard at all, and you can pull some of your own wiring through with it for accessories later on (tach, other guages, etc)
Jim in Sacto -
my wonderful loving supportive wife wrote:
You guys are dorks.
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2
localboy
Samba Longboarder
localboy is offline
PostPosted: Sat Aug 12, 2006 7:07 pm    Post subject: Reply with quote
The only real issue I had on the '65 was the old OG harness going thru the conduit. It was stuck...I mean stuck. I put a small rod down and pulled out a bunch of sand/dirt. Mad We were finally forced to use a 5' long, bladed drill bit on a rechargeable drill. In-out-in-out...slowly until we broke past the blockage and were able to pull the remaining harness out of the back. By my estimate we got about 5-6 tablespoons of crap out of the tube. Shocked But the new harness went in like butter. Pulled about 6 extra wires thru with it. Some are to be used; two extra are just in case...
One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project
Russ Wolfe
PostPosted: Sat Aug 12, 2006 8:41 pm    Post subject: Reply with quote
Speaking of butter, Get some wire pulling compound at your local electrical supply store. It will help greatly in pulling thru the tight places.
Don't just use oil or grease, and that can deteriorate the wires.
Gary: OK. Ima poop.
Bobnotch
Bobnotch is offline
PostPosted: Sun Aug 13, 2006 8:59 am    Post subject: Reply with quote
The only drawback to the new harnesses available is that they are for carbed cars. This means they don't have the couple of extra wires in them needed for the FI to run. Shocked Just something to think about.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
spoon
Samba Penetrator
spoon is offline
PostPosted: Mon Aug 14, 2006 11:51 am    Post subject: Reply with quote
WTF? Well that's just perfect. What am po peepo like me s'pozadoo? Crying or Very sad
Type 3 > Type 1
localboy
Samba Longboarder
localboy is offline
PostPosted: Mon Aug 14, 2006 11:54 am    Post subject: Reply with quote
I obviously don't do fuel injection, but can't you just add the required wires when pulling the new harness thru? Confused Tram? Russ? Think
spoon
Samba Penetrator
spoon is offline
PostPosted: Mon Aug 14, 2006 12:22 pm    Post subject: Reply with quote
I am assuming so. All the wires do is transmit voltage where/when voltages is supposed to be transmitted right? Do any of you have a diagram for what wires need to be added? George? Russ? Confused
Type 3 > Type 1
Russ Wolfe
PostPosted: Mon Aug 14, 2006 6:31 pm    Post subject: Reply with quote
Yeah, you could just pull the needed wires through with the new harness. Power wires from the relay under the rear seat, and the wires that go from the ECU to the fuel pump relay up front. There may be others that I am not thinking about.
Gary: OK. Ima poop.
notcho64
notcho64 is offline
PostPosted: Mon Aug 14, 2006 8:10 pm    Post subject: Reply with quote
I installed a new wire harness a few months ago and it went pretty smooth. I had to remove the left front/rear fenders of coarse but I failed to run extra cables for "other electrical stuff"...tach/temp/etc.
Is there a tube in the right passenger rocker panel as well for other cables?
1960 15 Window - Current Ride
1957 PGSG Kombi - Sold
1963 Ragtop/Air Ride/Turbo Bug ( I should have never bought it)
64 1500S Notchback (I should have never SOLD it)
www.norcalaircooledgroup.com
NAG#9
HenrikL
HenrikL is offline
PostPosted: Wed Dec 21, 2016 1:43 pm    Post subject: Reply with quote
I realise that the rear fender must be removed, but is there any change changing the wiring loom without removing the front fender?
W1K1
W1K1 is offline
PostPosted: Wed Dec 21, 2016 3:02 pm    Post subject: Re: T3 Wiring Reply with quote
it has to come out of the cabin, then down, and back in the channel, not much chance of doing that with the fender on.
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
