Rocknrod Samba Member
Joined: November 02, 2004 Posts: 2157 Location: North Carolina
Posted: Thu Oct 04, 2007 3:27 pm Post subject: Park on an incline, smoke show. |
Hey guys...
My bus (71 with 1600 dp) puts on a decent james bond smoke effect show... Doesn't do it any other time, or doesn't burn much oil... So I figure the rings are in decent shape.
Is this enough to warrant an overhaul, is the cause badly worn out valve stems/valve guides? No seals on these motors to my knowledge... Is a smoke show just part of VW ownership?
(Its been a few months without having to pull the engine, I guess I'm feeling lost without having it out... ) _________________ 1971 Westfalia with a high top.
http://71vwbus.blogspot.com/ - Pictures and words... Oh My! |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11045 Location: Black Forest, CO
mat3833 Samba Member
Posted: Thu Oct 04, 2007 8:06 pm Post subject: |
mine does it every morning, it smokes for a second or 2 and then its fine. it is from oil leaking past the rings, its normal if you are in an incline with the tail down-slope. at least i hope so...
Matt _________________
grimace007 wrote: |
then i found thesamba where we point out the painfully obvious and make eachother feel retarded  |
kidder = what are the pros and cons to getting more hp or less hp.
runslikeapenguin =
don3751 = Don't worry, kidder; he's rolling his eyes because he hasn't got the slightest @#$% idea.
Glenn = Owned! |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6137 Location: CONGERS, N.Y.
Posted: Thu Oct 04, 2007 8:38 pm Post subject: |
Nose up.
Haven't done a compression or leak down on the motor yet... saving up for a decent set. _________________ 1971 Westfalia with a high top.
Posted: Fri Oct 05, 2007 7:07 am Post subject: |
you should be ok, if it smokes for more than a few seconds you might have a problem tho.
grimace007 wrote: |
runslikeapenguin =
Glenn = Owned! |
