What is the reservoir on the driver side floor for?
Santana
Santana is offline
PostPosted: Thu May 14, 2009 6:12 pm    Post subject: What is the reservoir on the driver side floor for? Reply with quote
I know, I know, I need a bentley.
Is this for window washing fluid? I just noticed that there is some moisture under my carpet (only on the drivers side). I can't find any other place where moisture might be coming in. Any chance it would be coming from this reservoir?
PHOTO GALLERY
McVanagon
McVanagon is offline
PostPosted: Thu May 14, 2009 6:18 pm    Post subject: Reply with quote
Ha, I guess you haven't run out of windshield washer fluid yet, since that's the reservoir. Very Happy
'69 Mike
'85 GL
'87 Wolfsburg Hardtop
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
?Waldo?
?Waldo? is offline
PostPosted: Thu May 14, 2009 6:27 pm    Post subject: Reply with quote
Yes, that's the washer reservoir. The "moisture" on the driver's side is often brake fluid that has leaked from the clutch or brake hydraulics.
Andrew
Santana
Santana is offline
PostPosted: Thu May 14, 2009 6:34 pm    Post subject: Reply with quote
Andrew
Thanks for the quick responses!
Is there anything that I can do to remedy the moisture? I have been searching for the source but can't find anything. I don't want to start running into mold problems.
PHOTO GALLERY
Sheesh
Sheesh is offline
PostPosted: Thu May 14, 2009 6:59 pm    Post subject: Reply with quote
Andrew has the best idea of what the "moisture" may be. Is it greasy feeling? Check your hydraulic fluid and see if it is low. If it is, then check both the brake and clutch masters for leakage. Again, if it is, replace the faulty part, get the carpet out of your van andbuy yourself new carpet. Not only will the carpet hold the fluid, but you will track it all over your van. Additionally, hydraulic fluid will eat away the floorboard paint, requiring additional work.
1982 Westy, 2.0L AC CA emissions
hiram6
hiram6 is offline
PostPosted: Thu May 14, 2009 7:17 pm    Post subject: Reply with quote
Unlikely it's moisture coming from your washer reservoir, doesn't seem like you've filled that anytime lately, snce you didn't know what it was.
If the moisture isn't the hydraulic fluid that would be coming from your brake or clutch reservoir, it could be water leaking around the lower corner of your windshield. Had any rain lately or washed your van? If the seal is leaking around the lower corner of the windshield, it dribbles down the inside of the front sheetmetal, kinda behind the fusebox, and soaks into the carpet.
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
FNGRUVN
FNGRUVN is offline
PostPosted: Thu May 14, 2009 8:42 pm    Post subject: Reply with quote
Should we tell him about the oil filler tube while we're at it? Wink
msinabottle
msinabottle is offline
PostPosted: Thu May 14, 2009 9:20 pm    Post subject: That Which Leaks... Reply with quote
Larry Blazer and I share an unprintable opinion about a very bad run of very bad brake light switches on brake and clutch fluid reservoirs of Chinese manufacture. I've had two go bad on me, one with devastating results as I was getting ready to take Winston up into the mountains above Ft. Collins as part of Rocky Mountain Westy's camping trip.
Thank goodness for those big rubber mats in the cab! The hexes hold the gunk and tell me what the problem is the moment I notice it.
One of the first things you learn upon exploring your vanagon is that things are in weird places that make sense upon further reflection.
Shocked
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
McVanagon
PostPosted: Fri May 15, 2009 4:15 am    Post subject: Reply with quote
Could also be water leaking in through the antenna base...
'69 Mike
'85 GL
hiram6
hiram6 is offline
PostPosted: Fri May 15, 2009 4:35 am    Post subject: Reply with quote
McVanagon wrote:
Well now you're just taking the fun out of it. Laughing Laughing
1996 Mazda Miata
RCB
RCB is offline
PostPosted: Fri May 15, 2009 6:18 am    Post subject: Reply with quote
The moisture under the carpet turned out to be a rust spot under the windshield rubber.
From the outside I didnt see any rust but the wetness continued.
Fast foward a year...I see a small bit of rust on the edge of the window.
As luck would have it my insurance company paid for a new windshield due to a crack. When the old glass and seal were removed.....I saw a much larger area of rust.
A hole about the size of a quarter had grown UNDER and allong the seal.
Only a small 1/8 inch area was showing above the seal but quite a bit under it.
Rust is sneaky and lives in the strangest of areas.
carterzest
carterzest is offline
PostPosted: Fri May 15, 2009 8:17 am    Post subject: Reply with quote
Good news? At least you found it. They can and forever will be Quirky LiL Bastards....But they just don't make cars like this anymore....
Very nicely done.
Happiness=Portland, Oregon in the rearview mirror!
edgood1
edgood1 is offline
PostPosted: Fri May 15, 2009 11:02 am    Post subject: Re: What is the reservoir on the driver side floor for? Reply with quote
I thought this was where you pour the liquid schwartz Shocked
1991VanagonCarat wrote:
1987 Syncro Westfalia powered by Subaru
'65 Westfalia
Perales
Perales is offline
PostPosted: Fri May 15, 2009 11:49 am    Post subject: Reply with quote
hiram6 wrote:
Now you are confusing me, I thought that was the 710 filler tube. d'oh!
-- 1987 Westfalia automatic (Captain Vino)
joetiger Premium Member
joetiger is offline
PostPosted: Fri May 15, 2009 12:17 pm    Post subject: Re: What is the reservoir on the driver side floor for? Reply with quote
Now that is funny. Applause
Joe T.
'02 Baja-ish Beetle "Bubbles"
mightyart
mightyart is offline
PostPosted: Fri May 15, 2009 12:23 pm    Post subject: Reply with quote
You mean that's not the spittoon????
Man, no wonder my winsheild looks so bad...
GWTWTLW
GWTWTLW is offline
PostPosted: Fri May 15, 2009 12:48 pm    Post subject: Reply with quote
And smells like piss too! Razz
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
Santana
Santana is offline
PostPosted: Fri May 15, 2009 1:17 pm    Post subject: Reply with quote
Guess I am not part of the club, I don't have an oil filler tube as I have a tiico engine.
Since I don't use washer fluid, I am thinking of using it as a urinal. No more stopping on those long road trips. Laughing Laughing
PHOTO GALLERY
Santana
Santana is offline
PostPosted: Fri May 15, 2009 1:20 pm    Post subject: Reply with quote
On a serious note, thanks to everyone who gave insight as to where the moisture on the floor might be coming from. I am guessing it probably is a bad seal. I am going to dive into it this weekend and see what I can find out.
PHOTO GALLERY
?Waldo?
?Waldo? is offline
PostPosted: Fri May 15, 2009 2:05 pm    Post subject: Reply with quote
I thought the Tiico used the diesel vanagon oil pan along with the filler tube or do you have to open the engine lid to add oil? If you don't have any filler tube added, then you can certainly add the diesel vanagon version which does indeed have the tube extension.
Andrew
