BestCoast Samba Member
Posted: Sun Sep 09, 2012 2:46 pm Post subject: Alternator stand gasket |
Took off my alternator stand and got confused. There are 0 gaskets existing so i dont know where to put it.
Posted: Sun Sep 09, 2012 2:46 pm Post subject: |
Above or below this plate?
Joey Samba Member
Joined: August 12, 2005 Posts: 5376 Location: Nova Scotia - Canada
Posted: Sun Sep 09, 2012 2:52 pm Post subject: |
I always use two and put the metal baffle in between the two. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33394 Location: Hot Arizona
Posted: Sun Sep 09, 2012 3:04 pm Post subject: |
| Thank you. Will go buy a 2nd one now :/ |
jgrexx Samba Member
wbrown45 Samba Member
Posted: Sun Sep 09, 2012 3:57 pm Post subject: |
I use only the metal gasket (installed in the correct orientation) with Loctite 518, or any non-silicone sealer you prefer. I have never had one leak in the hundreds I have installed over the years. _________________ OK Thang |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8868 Location: Sunset, Louisiana
Posted: Sun Sep 09, 2012 4:22 pm Post subject: |
No gaskets needed because the metal baffle has a crush ridge on it and is supposed to be non-reusable. That's why you always get one in a complete gasket set. But if you do reuse the baffle, then you should probably use 2 gaskets and maybe a prayer it won't leak. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80248 Location: Sneaking up behind you
Posted: Sun Sep 09, 2012 4:24 pm Post subject: |
| Q-Dog wrote: |
| No gaskets needed because the metal baffle has a crush ridge on it and is supposed to be non-reusable. That's why you always get one in a complete gasket set. But if you do reuse the baffle, then you should probably use 2 gaskets and maybe a prayer it won't leak. |
The Elring kits i get have 2 gaskets and the baffle. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sun Sep 09, 2012 5:05 pm Post subject: |
Oh damn crush style :/ i plan on reusing that crush washer thing and made a 2nd gasket out of cork material
Think shell be ok? |
jgrexx Samba Member
saucerman Samba Member
Joined: February 17, 2004 Posts: 499 Location: Deep South GA
Posted: Sun Sep 09, 2012 7:25 pm Post subject: |
Nothing to do with gaskets really, but why not take the opportunity to replace the Alternator studs with bolts so the stand can be unbolted and slid forward in the event you ever have to replace the Alternator and don't want to or have time to remove the entire engine.
Someone told me that a while back and it ended up really helping me. _________________ 70 Beetle (1776 MoFoCo)
68 Bus (1600DP)
02 Beetle
I have my Bus, my backpack full of food and my AK47...bring on the Zombies! |
Posted: Sun Sep 09, 2012 8:10 pm Post subject: |
| saucerman wrote: |
Someone told me that a while back and it ended up really helping me. |
That sounds like an awesome upgrade, i had no idea about it. |
jgrexx Samba Member
