sb001 Samba Member
Joined: May 19, 2011 Posts: 10458 Location: NW Arkansas
Posted: Sun Sep 29, 2013 7:17 pm Post subject: It's hardly ever... |
vacuum leak
fuel filter
battery. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
JONSMITHBUG Samba Member
Joined: March 21, 2012 Posts: 162 Location: albany,new york
Posted: Sun Sep 29, 2013 7:24 pm Post subject: |
fat chicks leg hittin the shifter _________________ 73 beetle w 70 eng 1600sp daily driver,72 squareback |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33098 Location: Hot Arizona
Posted: Sun Sep 29, 2013 7:38 pm Post subject: |
You mean like "famous last words" ?
My battery is OK
I re-checked the spark plug wires order
The coil is wired correctly
I adjusted the timing right
The carb is getting fuel
It CAN'T be....
I've tried EVERYTHING !!!
I don't need a spare tire, I NEVER get flat tires or blowouts
MY fuel filter won't leak and catch the engine on fire
I don't need to wear a seat belt
My car ALWAYS starts
I've never had trouble on the road
I don't need to use a torque wrench _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
sb001 Samba Member
Posted: Sun Sep 29, 2013 7:59 pm Post subject: |
Cusser wrote: |
No. I was totally serious. A lot of bandwidth could be saved.
I forgot one-- bad gas. _________________ I'm the humblest guy on this board.
1600 SP engine
olmer2 Samba Member
Joined: June 28, 2009 Posts: 781 Location: chattanooga TN
sb001 Samba Member
Posted: Sun Sep 29, 2013 8:50 pm Post subject: |
1600 SP engine
volksworld Samba Member
Joined: November 26, 2011 Posts: 2580 Location: formerly NY currently NC
Posted: Mon Sep 30, 2013 4:30 am Post subject: |
it just needs a tune up.... |
zombiebug Samba Member
Joined: August 18, 2011 Posts: 1241 Location: Webster, MA
Posted: Mon Sep 30, 2013 5:22 am Post subject: |
I already adjusted valves. _________________ '74 Super |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Mon Sep 30, 2013 5:28 am Post subject: |
Running good when it was parked. |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3543 Location: Houston, TX
Posted: Mon Sep 30, 2013 6:13 am Post subject: |
Personal one- "my brakes are fine" _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Mon Sep 30, 2013 6:34 am Post subject: |
the fan belt isn't tight enough and/or something is caught up in the fan... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
DJ Bill Samba Member
Joined: May 13, 2012 Posts: 102 Location: Central Texas
Posted: Mon Sep 30, 2013 6:51 am Post subject: |
Points are fine I changed them last spring.... Must be the carb then, huh?
I don't need that wire to the idle solenoid, cuz all that emissions stuff is better left unhooked or left off. |
Cusser Samba Member
Posted: Mon Sep 30, 2013 11:59 am Post subject: |
Cusser wrote: |
You mean like "famous last words" ? |
One of favorites (non air-cooled VWs):
AC only needs a recharge
...that means that there's a leak, which must be found and repaired, and usually not so straightforward, then evacuation and recharge. And sometimes a guess on how much refrigeration oil to add back.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2931 Location: Germany
Posted: Mon Sep 30, 2013 12:10 pm Post subject: |
...just surface rust on the fenders _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
Volks Wagen wrote: |
...just surface rust on the fenders |
"just patina" _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Posted: Mon Sep 30, 2013 12:12 pm Post subject: |
My favorite. "Just needs a tune up" -Personally said to myself.
Meanwhile, 1 whole engine rebuild later, I finally have a nice running bug. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
sb001 Samba Member
Posted: Mon Sep 30, 2013 7:35 pm Post subject: |
An ignition coil wire  _________________ I'm the humblest guy on this board.
1600 SP engine
camaroboi13 Samba Member
Joined: February 22, 2013 Posts: 902 Location: San Bernardino, CA
Posted: Mon Sep 30, 2013 9:06 pm Post subject: |
It just needs a wheel balance...
3 wheel motion is scary when you don't expect it! _________________ 69 bug 1600sp buckpack ceramic header w mondo muffler, riviera wheels, 185/65 front 205/70 rear, dual baby webers, big stereo in the works.
2001 Yukon Denali 6.0l AWD 24s TVs surround sound playstation 6 disc dvd etc etc.
2005 Nissan Maxima 3.5l stock mama's car
FFL GUN DEALER! PM ME FOR SOCAL TRANSFERS! |
