Need some help with possible Vanagon Intermittent Syndrome
ericpmurphy
ericpmurphy is offline
PostPosted: Sun Oct 19, 2014 7:03 am    Post subject: Need some help with possible Vanagon Intermittent Syndrome Reply with quote
Not sure if what I have going on is the known intermittent syndrome or something else so figured I'd see if anyone could shed some light. I just bought an 1987 Vanagon Westy and the previous owner let me know before hand that it had symptoms similar to VIS. He would be driving along lose power restart and be good to go... it seems like it has gotten worse though as now its hard to go a mile or two without needed a restart. I've compiled a list based on the records I received with the van of what has been replaced, checked, etc.. I tried to keep the list to things related to VIS but some other things may be in there as I'm not a great mechanic by any means! Any insight would be greatly appreciated.
Also the AFM was replaced with used unit and I will be able to try a friends working AFM in next few days.
Sorted by most recent
2014
-Installed Volt regulating Diode ito wiring for temp sensor
-R&R Fuel Pump
2013 (approx mileage 154k)
-Tracing and testing wiring harness
-Replaced ECM Unit
-Installed Signal Filter between Mass Air Flow Sensor and main wiring harness
-Added ground from distributor to engine block
-R&R Mass Air Flow Sensor (with used one so this could still be issue)
-R&R Thermostat
-R&R Water temp sensor
-R&R ECM Unit
-R&R Starter and Bushing
-R&R Instrument Cluster and Changed out Voltage Reducer (used part) Traced our wiring and grounds
-Cooling System flushed
-Set Idel and R&R Both Coolant Temp Sensors
-R&R Aux Fan Switch and Fan Resistor Control
2011 (approx mileage 153k)
-R&R Spark Plugs, Distributor Cap, and rotor button
-New O2 sensor
2008 (151k mileage) (looking at records it looks like the syndrome started about here)
-R&R Water pump and temp sensor
-New Belts
2000 (103k miles)
-R&R Cylinder heads, fill corroded surface on cycle head, resurface, new head gasket
ericpmurphy
PostPosted: Tue Oct 21, 2014 7:09 am    Post subject: Another issue i did not mention Reply with quote
The van also has an erratic idle which when I bypass the Idle Control Unit (small black box behind rear tail light) gets better but not perfect...
planning on cleaning out the idle valve
Also yesterday tested the AFM with ohm meter but there isn't very much info out there as to what is normal.. mine changed through arc for about half of arc then went back towards starting point through finish of arc.
hdenter
hdenter is offline
PostPosted: Tue Oct 21, 2014 8:40 am    Post subject: Reply with quote
A good AFM should show a smooth change in reading through the entire arc. It is best to do this with an analog needle tester so that you can watch the motion of the needle. If you are sure you did not lose contact with the leads while you where testing it, then you have part or all of your problem right there.
Good Luck!
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
vanonimous
vanonimous is offline
PostPosted: Tue Oct 21, 2014 10:19 pm    Post subject: Reply with quote
I once had an intermittent cutout that over time turned into a stall. When it stalled I felt compelled to solve the problem. The culprit was high resistance in cable from coil to distributor. That cable in Bosch version houses a 1k Ohm resistor and over time it turned out to about 8k Ohms just enough to cause trouble on longer drives.
If happiness is being a mechanic, owning a Vanagon is nirvana.
Lighting upgrades: https://www.thesamba.com/vw/forum/viewtopic.php?t=578291
ericpmurphy
PostPosted: Wed Oct 22, 2014 6:32 am    Post subject: Reply with quote
Updated.
Put in a known working AFM which did not change anything.
Tried running with no o2 plugged in and no change.
When we start the van it will idle ok for a minute then start searching for idle then stall out (this has been without driving the car just starting it).
Going to test o2 sensor today as this seems to be common culprit to running problems and seemingly easy to troubleshoot.
Thanks for input thus far.
Perales
Perales is offline
PostPosted: Wed Oct 22, 2014 7:51 am    Post subject: Reply with quote
Not the O2 sensor. It needs to be up to temp before it does anything and won't get there in a minute.
Look at the idle control valve. try blasting some carb cleaner through it to clean it out, or try swaping it out with a known good one (from a friend). Mine needed replacing and solved a similar problem.
-- 1987 Westfalia automatic (Captain Vino)
ericpmurphy
PostPosted: Sat Oct 25, 2014 5:58 am    Post subject: more update Reply with quote
o2 sensor was wrong sensor and only had one plug of 3 so changed that, but there is a huge exhaust leak before the sensor so thats running super rich when plugged in.
Idle still tends to surge or search once van warms up. Took it for a spin yesterday and after a few minutes lost power.. turned off and back on and drove back to shop with no problems.
Will get that exhaust leak fixed as that could obviously be part of some problems but would it be causing the "syndrome" of losing power?
thanks
eric
Rekker
Rekker is offline
PostPosted: Sat Oct 25, 2014 4:34 pm    Post subject: Reply with quote
It must be that time if year or something... My '87 WBX started doing the same exact thing 5 days prior to you posting. Started hesitating when I gave it gas and within a hundred feet I had no response at the pedal. Coasted off to the side and turned it off, after checking oil and restarting it got me back home no problems. Changed the plugs, rotor, distributor, oil and filter today hoping it was the fouled plugs/distributor but no luck. Took it for a drive and as soon as I got going it lost power. At one point I had no response at all from pedal, had to listen to make sure van was still running(it was), the OXS and Battery indicators lit up for a few seconds. After sitting for dinner it seems it's running better... 'ish.
Rekker
Rekker is offline
PostPosted: Mon Oct 27, 2014 2:03 pm    Post subject: Reply with quote
Did a compression check today, readings are within acceptable limits from Bentley manual. The "front" cylinders looking at engine are at 140 left and right, the "rear" are at 120 left and right. Manual states compression pressures are 85-135 psi with a difference differential of 42 psi. Not sure if the 140 was me cranking it too many times or if it's actually over limit, or for that matter if it is normal... A mechanic I am not. While cranking, I noticed a puff of light smoke from the area of the left exhaust pipe. Looking closer the pipe is pitted and worn and it looks like the gasket it just... Not there.
Is that the same location you noticed your leak before the O2 sensor?
Would this cause the rough running (almost stalling now) and power loss?
-Rick
dspieg
dspieg is offline
PostPosted: Wed Oct 29, 2014 8:51 am    Post subject: Try replacing the coil Reply with quote
When I had "suspected Vanagon syndrome" it turned out to be an intermittently bad coil. After testing and/or replacing just about every other potential culprit, I noticed the tach needle starting to twitch just before the start of another "episode". Since an engine can't change RPM that quickly and the tach gets its signal from the coil, the smoking gun was identified. Replaced the coil, car runs perfectly since.
Rekker
Rekker is offline
PostPosted: Wed Oct 29, 2014 9:28 am    Post subject: Re: Try replacing the coil Reply with quote
Is there a specific name for the coil? Trying to find it in the Bentley.
Perales
Perales is offline
PostPosted: Wed Oct 29, 2014 9:42 am    Post subject: Re: Try replacing the coil Reply with quote
Ignition coil
http://www.van-cafe.com/home/van/page_685_236/coil-bosch-fits-1985-through-1991.html
Rekker
Rekker is offline
PostPosted: Wed Oct 29, 2014 9:44 am    Post subject: Re: Try replacing the coil Reply with quote
Perales wrote:
Ignition coil
Thank you! I actually just found it in the Bentley when your post came through. Very Happy
devesvws
devesvws is offline
PostPosted: Wed Oct 29, 2014 9:56 am    Post subject: Re: Try replacing the coil Reply with quote
lol like this Arrow
THE FEW THE PROUD THE ORIGINAL VW WATERBOXER -> looking for a original 91 vanagon owners manual with 1991 on the cover http://www.youtube.com/watch?v=pmuiG2tUsP4&feature=share https://picasaweb.google.com/101290228103300323836/BostonBobFlywheelVideo#5543000332201103922
Rekker
Rekker is offline
PostPosted: Thu Oct 30, 2014 3:08 pm    Post subject: Reply with quote
I guess I'm going to have to get a voltmeter and try going through every electrical test I can find in the Bentley.
I pulled the ignition coil, which looked no where near as bad as the photo you provided lol. I went to the auto parts store thinking it had corrosion crystals in the distributor cable plug, turns out to be what appears like some kind of conductive grease I think. Advance auto wanted $75 for a coil (not even a Bosch), so I'll prolly order from vancafe ($50'ish for Bosch) after trying electric system tests.
Pulled the fuel filter and still looks good. I drained it and air passes through it both directions easily so I don't think it's clogged. I can hear the fuel pump kicking on when I turn key on and the line was under pressure when I checked the filter.
The exhaust is coming out with good pressure, no rattles when I tap at Cat...
I did try disconnecting the O2 sensor, and letting it idle. It ran the same as with it plugged in. Still hesitates when I give it gas and idles rough. Would that indicate it was faulty with no change?
I did notice after taking off the coil and fuel filter and putting them back on that now the led on the tach for the temp gauge goes off after starting the van, then starts flashing again and won't go out.
I love driving this van... But oh my god it's a fickle beast! Very Happy
Perales
Perales is offline
PostPosted: Thu Oct 30, 2014 3:22 pm    Post subject: Reply with quote
Download these VW protraining manuals. They are a good addition to the Bentley and can be a great help to debug problems.
http://www.westfalia.gomezperales.com/Documents/86%20Vanagon%20Protraining.pdf
http://www.westfalia.gomezperales.com/Documents/Vanagon%20Protraining%2086-91%20Fuel%20Systems.pdf
http://www.westfalia.gomezperales.com/Documents/Vanagon%20Protraining%20Digifant%20I%2086-91.pdf
bluebus86
Banned
bluebus86 is offline
PostPosted: Thu Oct 30, 2014 3:59 pm    Post subject: Reply with quote
to sort out the running issues in my 86 vanagon, I got the Van café injection tester, rented it them bought one. good tool for injection issues, I found several faults to repair, some would have been difficult to diagnose otherwise.
Not only did I have injection issues, but also one final issue was faulty distributor, the hall sensor was intermittent, every now and then it got funky, it was very intermittent, hard to find.
now no issues at all.
the van café tester is well worth the money in saved hours of you try to trace injection faults, you leave it on as you drive so you can catch intermittent faults as they happen, and see what is causing it. It will tell you if the O2 sensor is going bad, if voltages are low, what the temp sensors and air sensors are doing, etc..
good luck
Rekker
Rekker is offline
PostPosted: Thu Oct 30, 2014 4:45 pm    Post subject: Reply with quote
I'm reading them now, thanks for another source of info on the van!
devesvws
devesvws is offline
PostPosted: Thu Oct 30, 2014 5:23 pm    Post subject: Reply with quote
you have unplugged the sensor on top of the coolant reservoir I bet...this is a long shot but make sure the harness to the alternator isn't holding on by a thread... I think this happened to me once if I'm not mistaken...
Microbusdeluxe Premium Member
Microbusdeluxe is offline
PostPosted: Thu Oct 30, 2014 7:34 pm    Post subject: Reply with quote
Bluebus865: What's this "injection tester" at Van Cafe. I searched their site and couldn't find it. Thanks for the help.
'69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig!
