tfelzq Samba Member
Joined: February 27, 2017 Posts: 26 Location: Austin, TX
Posted: Sat Apr 01, 2017 9:04 pm Post subject: Broken Heater Hose - How Do You Think Is Best To Fix It? |
Alright team - I've come to you a few times during this engine rebuild of this 1980 VW Vanagon aircooled, and I'm back for more. Tonight, when lifting the engine and transmission back onto the frame, we broke this...I'm looking for suggestions on how to fix it.
I'm a novice, so i could be wrong, but I believe it's the connection for the heater.
Below are 3 pictures, each one zoomed out from the previous. My plan was to use the silver duct tape as is used in actual duct work. I'm sure that you will have a better idea..
What do you guys think is the best way to fix? |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5874 Location: Wamego, Kansas, USA
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8555 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Apr 02, 2017 6:50 am Post subject: Re: Broken Heater Hose - How Do You Think Is Best To Fix It? |
Full disclosure: I'm not an AC guy, but that looks like a great candidate for full replacement.
If you do the duct tape treatment, I must recommend 3M CLEAR...in my experience, much
more heat resistant & much less adhesive residue if/when it needs to be removed...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Sun Apr 02, 2017 12:59 pm Post subject: Re: Broken Heater Hose - How Do You Think Is Best To Fix It? |
A good used tubes would be the best way to go. From my experience the aftermarket tubes tend to melt through though there may be good brands out there. Don't think there are major differences between Bay tubes and Vanagon tubes except maybe for the length and it is easy enough to take a longer tube and shorten it.
Air preheat hose will work in a pinch but doesn't hold up well to abuse. You can also get silicone hoses from small aircraft parts houses. Remember to check the condition of the silicone gaskets that fit inside the ends of the tubes before ordering parts. |
Posted: Sun Apr 02, 2017 3:56 pm Post subject: Re: Broken Heater Hose - How Do You Think Is Best To Fix It? |
| 61Scout wrote: |
| ... silicone tape would be the best option as far as repair goes... |
Indeed. Another vote for this option (which I had forgotten to remember)...  _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17389 Location: Brookeville, MD
