licketysplit Samba Member
Posted: Tue Aug 08, 2017 7:30 am Post subject: Can't disconnect hand brake cable from backing plate. |
First post, so sorry if this topic has been covered, but I couldn't find info for busses. Anyway, trying to remove my backing plate on my 1966 bus. I can't figure out how the Hand brake cable disconnects from the backing plate. There is no bolt on the back side. Do I have to disconnect from the hand brake itself?
Thanks,
Toby
Clara  Samba Member
Posted: Tue Aug 08, 2017 7:53 am Post subject: Re: Can't disconnect hand brake cable from backing plate. |
licketysplit wrote: |
Thanks,
Toby
pull spring away from backing plate.
remove U shaped clip
then cable should pull through backing plate.
don't lose U shaped clip. |
Posted: Tue Aug 08, 2017 8:25 am Post subject: Re: Can't disconnect hand brake cable from backing plate. |
Thanks Clara,
So I started pulling on the u-shaped clip and noticed it cracked a little bit. I wasn't pulling on the spring at the time. Just worried that when I pull the spring, then the clip, that it might break or not be able to go back on. Do you have any advice on what to do if the clip does break?
thanks |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2195 Location: SW Nova Scotia, Canada
Posted: Tue Aug 08, 2017 8:57 am Post subject: Re: Can't disconnect hand brake cable from backing plate. |
Thanks sgellis
I looked at that thread, but it didn't say where he got that clip. I pm'd GLHTurbo, he's the one that posted the pic of the clip. Do you happen to know off hand where to pick one up?
Thanks |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3856 Location: Twin Cities, MN
Posted: Tue Aug 08, 2017 9:44 am Post subject: Re: Can't disconnect hand brake cable from backing plate. |
I've made them out of spring steel. The metal bands used on packing crates can also be used to cut one out. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10800 Location: the past
Posted: Tue Aug 08, 2017 9:53 am Post subject: Re: Can't disconnect hand brake cable from backing plate. |
use a horsehoe clip that is originally used for holding the e-brake arm mounting post to the brake shoe. crimp it slightly, enough to fit in the backing plate opening, and enough for the spring to set on it well, but not tight on the cable. fast, easy, inexpensive, works great. |
Posted: Thu Aug 10, 2017 2:18 pm Post subject: Re: Can't disconnect hand brake cable from backing plate. |
So I followed Clara's advice, but the cable would not come out of the backing plate. I was able to pull on the backing enough to get it around the spindle. Hopefully I didn't ruin the adjustment on the hand brake. Fortunately I was able to preserve the metal clip on the cable. But I bought a pack of horseshoe clips just in case.
Any other ideas on getting the cable through the backing plate?
Thanks for all the help |
Posted: Thu Aug 10, 2017 5:38 pm Post subject: Re: Can't disconnect hand brake cable from backing plate. |
The end of the cable is metal and that slips into the hole on the backing plate. They often get rusty and are hard to pull out with out some persuasion like a tap on a drift from the inside to push it out or at least loosen it. Heat or a good spray penetrate like kroil is another option.
The whole works including the spring on the cable will come out. |
Posted: Thu Aug 10, 2017 5:55 pm Post subject: Re: Can't disconnect hand brake cable from backing plate. |
it's also a lot easier to work with if the backing plate is still bolted to the reduction box. |
grizpdx Samba Member
Posted: Thu Aug 10, 2017 6:25 pm Post subject: Re: Can't disconnect hand brake cable from backing plate. |
I swear by this stuff. Far better and far faster results than PB Blaster.
Begins buying stock in deep creep. |
