VWTortuga336 Samba Member
Posted: Tue Jul 31, 2018 2:35 pm Post subject: How to: Tail Light Conversion - Late to Early |
I couldn't find a detailed how to guide when I did my tail light conversion on my 72, so I wanted to provide a step by step write up. Overall, it wasn't a difficult process, but it can be nerve wracking cutting up a "perfectly good" fender. I figured this post would help others not feel so anxious about doing it. It took me about 3 hours per side (not including filler and body work). You can probably get it done in less time if you are better at panel fitting and welding than I am (not hard to be better than I am ).
One of the first things to note is that the curve from the tail light to the engine compartment is different on later cars, so I had to be careful to cut out the entire transition.
Since you now need to maintain the stock transition area, make sure you cut out as little as possible from the old tail light.
From here, test fit your new piece and put a level across the vertical points. Mark on the fender where the level point is.
Cut the fender, test fit again, weld in place.
Now make a patch panel for the inside section.
Finished!
_________________ Stop dead photo links! Post your photos to The Samba Gallery! |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2932 Location: Auckland, New Zealand
Posted: Tue Jul 31, 2018 3:26 pm Post subject: Re: How to: Tail Light Conversion - Late to Early |
An expert can make anything look easy and you've just proved that.
Great tutorial. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4113 Location: In Molinya Orbit
art_lessing Samba Member
Joined: February 20, 2014 Posts: 157 Location: Sacramento
Posted: Tue Jul 31, 2018 5:12 pm Post subject: Re: How to: Tail Light Conversion - Late to Early |
this is awesome...can you please document your battery tray fix as well? I want to copy all the steps. My tray is rotted out exactly where yours is...especially where the b-tray meets the rear tray....
Thanks in advance
DQ |
Posted: Tue Jul 31, 2018 5:21 pm Post subject: Re: How to: Tail Light Conversion - Late to Early |
djkeev wrote: |
Thanks for the tutorial!
I must ask though, would it be prudent to measure how far rearward the tail light is before welding it?
What point would you measure from? I'd guess the top of the door opening?
This would be the same distance on the Coupe and on the Convertible.
Dave |
I just used where the fender and the bottom of the tail light section meet as a reference point. It pivots from here when you test fit to get it level.
Circled here.
Posted: Tue Jul 31, 2018 5:36 pm Post subject: Re: How to: Tail Light Conversion - Late to Early |
art_lessing wrote: |
Thanks in advance
DQ |
Sure, no problem _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Wed Aug 01, 2018 2:15 pm Post subject: Re: How to: Tail Light Conversion - Late to Early |
VWTortuga336 wrote: |
From here, test fit your new piece and put a level across the vertical points. Mark on the fender where the level point is. |
It is worth pointing out that before you use the level to check panels you need to check that the body and dolly are level both lengthways and sideways. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Joined: August 31, 2013 Posts: 13289 Location: North Carolina
Posted: Wed Aug 01, 2018 3:04 pm Post subject: Re: How to: Tail Light Conversion - Late to Early |
It would appear that to conform to the later model fender structure that the new hybrid tail light protrudes rearward another 1"-2", that's really gonna screw with folks later on.
Are you going to fill the bumper reliefs? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Aug 01, 2018 4:00 pm Post subject: Re: How to: Tail Light Conversion - Late to Early |
TDCTDI wrote: |
Are you going to fill the bumper reliefs? |
I filled the bumper refliefs, not the best pic but you get the idea.
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8236 Location: San Dimas
