Jeff67sqbk Samba Member
Posted: Tue Sep 18, 2018 7:58 am Post subject: 67' Dual Carb Idle Too High |
'67 Sqbk, stock dual Solex carbs. Just rebuilt motor (by AVP).
Set carbs at the defaults, 1/2 turn idle, 1 1/2 turn mixture screws.
Idles at about 900 RPM.
Checking carb flow with Unisyn reveals that left carb flow significantly more than right.
Adjusted left carb as low as it can go (then adjust mixture) still 900 RPMs.
Can adjust right carb (then adjust mixture) to match left flow brings idle to 1100 RPM.
Not sure what to change or adjust now to get idle lower.
Jeff '67 Sqbk stock
Nevada City, CA |
sqbk1971 Samba Member
Joined: October 27, 2016 Posts: 134 Location: Dallas, Texas
Posted: Tue Sep 18, 2018 10:24 am Post subject: Re: 67' Dual Carb Idle Too High |
I had similar issue after rebuild. Have you tested for vacuum leaks around manifold and head. I found that the shape of my manifolds did not seal well with generic metal gaskets that comes in a standard engine rebuild kit. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23358 Location: Kimball, Mi
Posted: Wed Sep 19, 2018 8:59 am Post subject: Re: 67' Dual Carb Idle Too High |
Jeff67sqbk wrote: |
Jeff '67 Sqbk stock
Nevada City, CA |
You might want to have a look at this thread.
https://www.thesamba.com/vw/archives/manuals/t3dualcarbtuning/index.php
It goes into detail about dialing in the carbs. It might also help you find your problem.
Also, never use the metal gaskets for the intake manifolds commonly found in the standard "complete" gasket kits. This is mostly because they don't seal very well, and have a tendency to loosen up with time (causing leaks). They also transfer heat into the intake manifold.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
DQDan Samba Member
Joined: October 24, 2016 Posts: 356 Location: Cleveland OH
Posted: Wed Sep 19, 2018 4:00 pm Post subject: Re: 67' Dual Carb Idle Too High |
"Also, never use the metal gaskets for the intake manifolds commonly found in the standard "complete" gasket kits."
I'm getting ready to bolt up two 32PDSIT's on my 66 build and was going to use those metal crush washers at the base of the intakes. What do you suggest as substitutes? TIA |
Posted: Thu Sep 20, 2018 8:12 am Post subject: Re: 67' Dual Carb Idle Too High |
DQDan wrote: |
Thick paper gaskets available from good VW parts suppliers like CB Performance, Air Cooled.net, and others. I think the last set I used were Bug Pack gaskets. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13545 Location: Tejas!
Posted: Thu Sep 20, 2018 9:08 am Post subject: Re: 67' Dual Carb Idle Too High |
and if you need it in a hurry, your flaps will have gasket material by the roll. They may actually have the gaskets too, you'd be surprised. For beetles and buses, the "heater hose" from autozone is great from the shroud to the heater box. better than the crap at the VW shop _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Thu Sep 20, 2018 8:55 pm Post subject: Re: 67' Dual Carb Idle Too High |
I replaced the manifold and carb gaskets with proper paper style ones tonight.
My local VW FLAPS, Parts for Imports, had the thick paper manifold gaskets, and I cut the carb gaskets from gasket material.
It still runs rich in the left carb.
Looking down into it I can see liquid fuel in the the left carb, whereas in the right one I don't see any liquid.
Closing the mixture screw didn't change it at all.
Thoughts?
Jeff '67 Sqbk stock
Nevada City, CA |
Erik G Samba Member
Posted: Thu Sep 20, 2018 9:06 pm Post subject: Re: 67' Dual Carb Idle Too High |
Check you floats (one may have a hole) the needle valves, float height, fuel pressure
I think you probably have a stuck needle valve or a float that ain't floating. You can shake it and hear it, or weigh it. Or put in gas and look for bubbles _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Fri Sep 21, 2018 1:42 pm Post subject: Re: 67' Dual Carb Idle Too High |
Agreed, check your float and needle and seat valve on the left carb. It sounds like the float isn't sitting right allowing fuel to continue to dump when it should stop the flow.
The needles and seats (for the float) are known to cause problems too. If you still have the old ones, put them in and try it again. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Sep 22, 2018 10:00 am Post subject: Re: 67' Dual Carb Idle Too High |
Float floats, no holes and moves freely. Replaced float valve and no change. Still too much fuel getting through.
Jeff '67 Sqbk stock
Nevada City, CA |
Posted: Fri Oct 12, 2018 8:38 pm Post subject: Re: 67' Dual Carb Idle Too High |
Update. I replaced the left carb with another I had hanging around. It is a 32PDSIT instead of the 34 that was installed.
Same exact problem with this carb too! Too much fuel getting into the left head.
As someone suggested it might be high fuel pressure, so I swapped the fuel lines left to right hoping that there might be an obstruction.
No dice, same problem, again. Maybe I'll have to try the other spare carb I have. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5286 Location: Southern AB
Posted: Sat Oct 13, 2018 5:48 am Post subject: Re: 67' Dual Carb Idle Too High |
put a gauge on it to find out what the fuel pressure is. too much pressure will push past some needle valves. some stock pumps can put out 7-10 psi when you only need 2.5psi _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Sat Oct 13, 2018 11:32 am Post subject: Re: 67' Dual Carb Idle Too High |
Yup, like I mentioned to Monte, use paper pump to bakelite gaskets to lower fuel pressure. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Mar 06, 2019 2:58 pm Post subject: Re: 67' Dual Carb Idle Too High |
I swapped floats around and the amount of fuel flowing at idle was reduced.
I added paper gaskets to the fuel pump and now I don't see any fuel dripping into the carb looking down inside while running.
However even with the idle screw not touching at all, the lowest idle I can set is about 1200 RPMs.
According to the Unisyn, the left carb is still the source of the extra fuel.
What is the next step to try and get a reasonable idle? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18042 Location: Eugene, OR
Posted: Thu Mar 07, 2019 2:31 pm Post subject: Re: 67' Dual Carb Idle Too High |
It's probably maladjusted rods. There is a procedure for setting them All in proper order Correctly.  _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Thu Mar 07, 2019 3:32 pm Post subject: Re: 67' Dual Carb Idle Too High |
Mike Fisher wrote: |
It's probably maladjusted rods. There is a procedure for setting them All in proper order Correctly.  |
Yup, see the link I posted near the top of this thread. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Posted: Thu Mar 07, 2019 3:35 pm Post subject: Re: 67' Dual Carb Idle Too High |
Bobnotch wrote: |
Yup, see the link I posted near the top of this thread. |
This would of been the first thing to check as the idle drop down cam under the choke needs to be able to let go or the idle stays high.  _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23034 Location: Northwest of Normal
Posted: Thu Mar 07, 2019 11:35 pm Post subject: Re: 67' Dual Carb Idle Too High |
DQDan wrote: |
'66 is single port and uses the crush washers. '67 is dual port and those are the gaskets they are talking about. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Those who can't? Subaru. |
Posted: Thu Mar 07, 2019 11:41 pm Post subject: Re: 67' Dual Carb Idle Too High |
notchboy wrote: |
Bobnotch wrote: |
This would of been the first thing to check as the idle drop down cam under the choke needs to be able to let go or the idle stays high.  |
Yup. If that cam isn't dropping off the offending carb will pull. This adjustment is the bent rod that has two 7mm nuts at the threaded section at the bottom through a linkage lever off the base of the carb. Adjust the length of the rod by using the nuts so that it's the same length as the right side. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Posted: Sat Apr 13, 2019 5:56 pm Post subject: Re: 67' Dual Carb Idle Too High |
Got it!
Adjusted the rod on the carb and managed to get the idle lowered enough to balance carbs and again at higher revs.
Took it out for a quick spin around town. Feels nice to drive it again after many, too many years of not being able to!
Thanks all!
Here's a picture of the cobbled together stuff I use to hold the RPMs high for balancing carbs.
The threaded piece has a 90 degree bend to fit into the open wrench, the other piece is a bent tent peg. Wing nut for adjustment.
