john_lessard Samba Member
Joined: September 12, 2017 Posts: 117 Location: Boston, MA
Posted: Thu Sep 05, 2019 6:59 am Post subject: Removing A Carat Interior - What do I need? |
I have a great opportunity to remove the interior from a Carat and attempt to fit it in my 1986 GL Tin Top. I will not have much time with this Carat and will be removing everything remotely. I already have a Carat bench seat / bed in my van (a couple inches shorter in width to fit between the larger plastic panels).
I am only taking the bed hardware, side panels, and foldable table. I don't think I would use the jump seats.
Is there a list of parts I will need to complete the conversion? Is there a procedure to remove the plastic panels? The table and table bracket / hinge seemed obvious, but how to I remove the panels without damaging anything? Will I need to cut any welds behind this panel?
I am also aware of relocating the latch pin but understand part of the panel would need to be trimmed if I used the adapter bracket. Has anymore tried welding in a pin to the stock Carat location?
Thanks!!! |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2724 Location: Philly, mang
Posted: Thu Sep 05, 2019 7:33 am Post subject: Re: Removing A Carat Interior - What do I need? |
the carat panels are in a channel at the top, make sure you get that. make sure you take a picture of the table mounting hardware so you can get it mounted in your GL - i believe you will have to make a brace.
i'd love to get a set of the panels and table for my GL... _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Thu Sep 05, 2019 7:50 am Post subject: Re: Removing A Carat Interior - What do I need? |
Be prepared to drill out lots of rivets holding the upper channel and table bracketry. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4252 Location: Redwood City, California
Posted: Thu Sep 05, 2019 7:55 am Post subject: Re: Removing A Carat Interior - What do I need? |
Are you grabbing the Recaro seats as well? Don't forget the mounting plate that the table attaches to as well as the lower mounts as well. It's all pretty staright foraward.
As previously mentioned, get rerady to drill some Pop Rivets out.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Thu Sep 05, 2019 9:02 am Post subject: Re: Removing A Carat Interior - What do I need? |
16CVs wrote: |
Stacy |
Good eye! Those Recaro seats are for sale but I was not planning on picking them up. I spent all my money on the Carat interior and performance upgrades off this van.
Good to know about the rivets. I'll be sure to take drills and an abundance of drill bits. |
Posted: Thu Sep 05, 2019 9:04 am Post subject: Re: Removing A Carat Interior - What do I need? |
dabaron wrote: |
i'd love to get a set of the panels and table for my GL... |
Any idea how to remove the panel from that channel? Are there clip in fasteners similar to the normal door panels that must be popped out first? Then just pick the panel up and out of the channel?
Sorry for the simple questions but I will be on a time constraint when I'm am disassembling this van. |
Posted: Thu Sep 05, 2019 9:32 am Post subject: Re: Removing A Carat Interior - What do I need? |
john_lessard wrote: |
the panel is held in place at the top using the C channel, and it secured at the bottom with door panel clips which pop out. remove the table, remove the clips, pull on bottom edge toward you (oh, remove the bed!) and then slide panel out of channel.
it's not a 5 minute job. _________________ 1991 Vanagon GL Camper
Posted: Thu Sep 05, 2019 9:50 am Post subject: Re: Removing A Carat Interior - What do I need? |
dabaron wrote: |
it's not a 5 minute job. |
Thanks! Looks like getting the bed out will be the hardest part since we need to lift it up and over that engine sitting in the middle of the van.  |
Posted: Thu Sep 05, 2019 10:38 am Post subject: Re: Removing A Carat Interior - What do I need? |
bed is 4 bolts. pull bed forward and up. climb in from behind and remove the 4 bolts. put bed back down but don't latch the back... lift one side and pivot. then have helper lift and take out the slider. i managed to do it solo but having a helper would have been way quicker. _________________ 1991 Vanagon GL Camper
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Posted: Fri Sep 06, 2019 6:36 pm Post subject: Re: Removing A Carat Interior - What do I need? |
Here is a picture of the big Items:
This photo shows the 87 Woulfsburg that was available without AC along side the Carat panels that were only available with AC AFAIK
This picture shows a bunch of the hardware, the two brackets that the seat posts screw into are welded in and need to be cut out, then there are the 4 block spacers for the 4 rear seat bolts that must be removed.
not pictured are the 4 floor receivers that the jump seats clip into as well as the brackets on the rear of the seat and the support brackets welded inside the seat base and wheel well. _________________ 1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24031 Location: NYC/Upstate/ROW
Posted: Sat Sep 07, 2019 4:48 am Post subject: Re: Removing A Carat Interior - What do I need? |
A rabbit _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Sat Sep 07, 2019 3:16 pm Post subject: Re: Removing A Carat Interior - What do I need? |
ajdenette wrote: |
not pictured are the 4 floor receivers that the jump seats clip into as well as the brackets on the rear of the seat and the support brackets welded inside the seat base and wheel well. |
Thank you!! These pictures are super helpful. I have AC as well as the donar van so the panels should fit. That is a lot of hardware, is that all for the panels and table? I will be sure to cut out the brackets that hold in the latch pins. |
Posted: Sat Sep 07, 2019 3:56 pm Post subject: Re: Removing A Carat Interior - What do I need? |
Other than screws to hold the panels in place, I think most of the hardware is associated with the rear seat and seat belts. I had all of my Carat panels off within the last year, and don't recall anything beyond those few items...just lots of rivets. _________________ Casey--
y u rune klassik? |
Posted: Sun Sep 08, 2019 6:29 am Post subject: Re: Removing A Carat Interior - What do I need? |
John_Lessard there is extra hardware on that table when I got my interior there was a second van with only bits of it left hence the two sets of rear panels so I made sure to grab as much of the hardware as I could and there might be some of the hardware for my weekender interior for a future project mixed in as well. _________________ 1985 2wd Westy with 2000 Subaru 2.2 current driver
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5762 Location: Bemidji, MN
Posted: Sun Sep 08, 2019 7:00 am Post subject: Re: Removing A Carat Interior - What do I need? |
pull those cup holders, go great anywhere in the Westy. then pull the following for the cruise control:
- control unit behind glove box
- speedo sender on back of speedo (take whole cluster if still there)
- brake and clutch pedal switches
- vacuum pump mounted near passenger tail light
- pull steering wheel and take stalk switch for cruise _________________ -dan
www.thefixitworkshop.com |
Posted: Sun Sep 08, 2019 7:23 am Post subject: Re: Removing A Carat Interior - What do I need? |
for Cruise control you actually want the tail light harness as there is wiring for cruise in it in cruise control vans as well as the bundle that runs from the control unit behind the glove box down the chassis with the vacuum line. _________________ 1985 2wd Westy with 2000 Subaru 2.2 current driver
Posted: Sun Sep 08, 2019 9:04 am Post subject: Re: Removing A Carat Interior - What do I need? |
Thanks guys! I am not planning on taking the cruise control system.. Thanks for the info though!
My focus is the rear bed and panels. I plan on getting back to the van tomorrow to keep moving and will b sure to take lots of pictures to share with the hive mind.
BTW this van is being parted out due to an engine fire. The Carat interior is only a small portion of the parts I am salvaging. |
Posted: Sun Sep 08, 2019 11:24 am Post subject: Re: Removing A Carat Interior - What do I need? |
grab the brake equalizer valve underneath the driver's side!! very hard to obtain and they rust internally to an inoperable state. _________________ -dan
Posted: Wed Sep 11, 2019 7:18 am Post subject: Re: Removing A Carat Interior - What do I need? |
The bounty!
Here are some reference pics from the Carat:
Notice the floor section under the "U" shaped bracket is rotted away. I should be able to make new angle brackets and bolt them to my floor easily.
I also cut off those brackets that hold the latch pins. I am hoping to weld those into place and that should be the only welding necessary.
Any suggestions for attaching the metal channel that holds the panels to the body? Should I use rivets or could I get away with countersunk sheet metal screws? |
Posted: Wed Sep 11, 2019 7:30 am Post subject: Re: Removing A Carat Interior - What do I need? |
That's quite a haul. I'd use rivets. _________________ Casey--
y u rune klassik? |
