best place for an remote mounted oil cooler
best place
under the car next to the transder the nose of the car
45%
 45%  [ 5 ]
under the nose of the car
9%
 9%  [ 1 ]
somewhere else
36%
 36%  [ 4 ]
behind the kamei
9%
 9%  [ 1 ]
Total Votes : 11
MitchS046
MitchS046 is offline
PostPosted: Thu Apr 30, 2020 6:59 am    Post subject: best place for an remote mounted oil cooler Reply with quote
I recently came in possession of a Gol cooling kit that I want to mount on an 1915 engine I'm going to build somewhere next year. I know they have a really tiny oil cooer but as I don't have it I want to go remote mounted. I don't really know where the best place is to put it. under the car next to the trans? behind my kamei frond lip? somewhere under the nose of the car? the car is a euro spec 1973 1303 known in the use as super beetle's.
kangaboy
kangaboy is offline
PostPosted: Thu Apr 30, 2020 8:42 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
Keep it in the back. You don't want all that oil line going to the front of the car and back. Placing the cooler over or next to the transaxle will do fine, if you even need it. IDK where you are located, but under normal driving conditions, a stock doghouse oil cooler will be adequate for a 1915.
-74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote:
Shocked
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out Laughing
fl59bug
fl59bug is offline
PostPosted: Thu Apr 30, 2020 8:43 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
Under the package tray, above the transaxle
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Apr 30, 2020 8:45 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
Don't use it, its designed for a forward facing front engine and they have been proven not to cool adequately in a rear engine car.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
MitchS046
PostPosted: Thu Apr 30, 2020 8:46 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
i want to use the gol cooler just for the looks and thought to keep the temps down to go with the remote mounted cooler
Slow is smooth, smooth is fast,
~ mark divine
King_vw61
King_vw61 is offline
PostPosted: Thu Apr 30, 2020 8:51 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
They work if you buy the right one and keep the lines short. I put mine drivers side under package tray. Filter under driver fender. Look up CBR dual pass cooler.
1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en
MitchS046
PostPosted: Thu Apr 30, 2020 9:52 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
did you do all plumbing in AN lines? isn't that a bit overkill and expensive?
~ mark divine
vandenabeele andries
vandenabeele andries is offline
PostPosted: Thu Apr 30, 2020 10:07 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
Above the tranny. The shorter your lines the better.
Best regards
MitchS046
PostPosted: Thu Apr 30, 2020 10:09 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
Best regards
hey Andries hoe bedoel je boven de versnellingsbak? is daar überhaupt plek voor?
~ mark divine
rens040
rens040 is offline
PostPosted: Thu Apr 30, 2020 10:32 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
Does it get enough cool air above the transmission?
What is the downside of longer lines but more cool air on let’s say a front mounted oil cooler?
MitchS046
PostPosted: Thu Apr 30, 2020 10:35 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
that is what I also was wondering as the 911 from that era also had their oil coolers up frond also you have a lot more oil in your system
~ mark divine
King_vw61
PostPosted: Thu Apr 30, 2020 11:23 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
Long lines = dry starts. The lines are about 40 each. Well worth the piece of mind. How much is a new engine when your oil line bursts??
MitchS046
PostPosted: Thu Apr 30, 2020 11:25 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
but why did almost all rear engined cars from that era have oil coolers in the frond? and couldn't that be fixed with an electric oil pump that primes the oil system just before you start the engine like an electric fuel pump?
~ mark divine
rens040
rens040 is offline
PostPosted: Thu Apr 30, 2020 11:47 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
Dont see the dry start either.
The thermostate and filter can be located close to the engine.
So When cold you have a short circuit.
Only when warmed up oil will flow to the cooler.
Well not entirely as most thermostats let some flow to the cooler even when cold...
TinCanFab
TinCanFab is offline
AN fittings have advantages and dont always have to be expensive. You can use cheap brass pushlock fittings w/rubber hose, anodized aluminum pushlock, braided hose with screw together aluminum fittings, or fully crimped Teflon hose like in his pics. Viking is running one of the most expensive type 1 NA race motors you can build that will fit into a street car. In his case, the cost is justified.
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
slalombuggy
slalombuggy is offline
PostPosted: Thu Apr 30, 2020 1:17 pm    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
You guys referencing 911s fail to take into account that system was a drysump system that held 11-14 liters of oil.
I spent over $500 on AN fittings on my turbo engine. Cheap insurance.
Nightshift
Nightshift is offline
PostPosted: Thu Apr 30, 2020 1:28 pm    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
It is just not needed in your climate or with your engine. Just because you have it does not mean you need to use it. I actually removed my remote cooler.
Vioflita1286
Vioflita1286 is offline
PostPosted: Thu Apr 30, 2020 9:40 pm    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
This is where I put it. What do you think?
wheel607
wheel607 is offline
PostPosted: Fri May 01, 2020 1:48 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
[quote="slalombuggy"]You guys referencing 911s fail to take into account that system was a drysump system that held 11-14 liters of oil.
I spent over $500 on AN fittings on my turbo engine. Cheap insurance.[/quote
They have no idea that they are talking about a dry sump system that holds 12 quarts of oil. Apples and oranges.
King_vw61
PostPosted: Fri May 01, 2020 4:40 am    Post subject: Re: best place for an remote mounted oil cooler Reply with quote
That is a remote filter... where is the cooler? Or am I missing something? Why the extra loop in the lines?
