Swing Tranny Reinfocement
Schrauber jan
Schrauber jan is offline
PostPosted: Thu Mar 11, 2021 10:55 am    Post subject: Swing Tranny Reinfocement Reply with quote
I once saw an Article in an old Mag about the Old Swing axle
someone took two HD Side Plates and screwed out ten of the Studs
fife on each side bored throug the Case from one side to the other and used fife long Bolts to put everything back together!
It developed like a cage around the Diff and i guess they told it´s to prevent the Tranny to brake in two!
I´ve searched the whole Forum and the Internet but couldn´t find anything about what and how to do?
only thing i found was one Threat with a pict about two differnt style HD Plates and one extra 10mm Bolt drilled thoug.
I gues i saw Youtube Vid from EZGZ he mentioned Gene Berg and a Book were it should be explained!
Can someone please lead me the way about it and what and how to do this Mod?
I only need to know what bolts needed to be drilled out were to run the Fife bolts!
and maybe were to look for. Rolling Eyes
maybe the Pro and cons about that Mod. Question
Clatter
Clatter is offline
PostPosted: Thu Mar 11, 2021 1:50 pm    Post subject: Re: Swing Tranny Reinfocement Reply with quote
You might search the word girdle..
Bus Motor Build
It does not exist!
AlteWagen
Troll
AlteWagen is offline
PostPosted: Thu Mar 11, 2021 2:18 pm    Post subject: Re: Swing Tranny Reinfocement Reply with quote
Member Gears (pablo) showed a through bolt (head stud) mod used on autocraft and rhino cases.
Official Dual Carb Thread
Ohio Tom
Ohio Tom is offline
PostPosted: Thu Mar 11, 2021 2:26 pm    Post subject: Re: Swing Tranny Reinfocement Reply with quote
Was popular years ago. Some still do it.
You can still bust the case in half thou. Seen it many times. Usually the front section of the case separates from the diff housing area. Gear oil on the track.
Mostly, folks weld on big gussets any more that tie the front half of the case to the diff housing. Helps in a big way from shattering a case.
buguy
buguy is offline
PostPosted: Fri Mar 12, 2021 5:10 am    Post subject: Re: Swing Tranny Reinfocement Reply with quote
Tom do you have any photos/links of this? I recently bought a rebuilt trans and plan to install it in a couple days. I could find time to make some gussets if it would help.
gears
gears is offline
PostPosted: Fri Mar 12, 2021 5:16 am    Post subject: Re: Swing Tranny Reinfocement Reply with quote
Threat of case breakage can be eliminated by limiting forward pinion movement, and to a lesser degree, side cover lift-off.
The ONLY through-bolt that does anything constructive is the one added in that photo. None of the OE studs is in the correct position.
I've yet to see a broken case from a trans that had those two major modifications performed.
aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com
buguy
buguy is offline
PostPosted: Fri Mar 12, 2021 5:23 am    Post subject: Re: Swing Tranny Reinfocement Reply with quote
I don't know what those things are but i will do some research.
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Fri Mar 12, 2021 6:41 am    Post subject: Re: Swing Tranny Reinfocement Reply with quote
https://shoptalkforums.com/viewtopic.php?t=89944
Imo, .003 is a little tight for backlash on a street car, but it’s give/take if you are to the point of needing all the mods in the post.
buguy
buguy is offline
PostPosted: Sat Mar 13, 2021 9:44 am    Post subject: Re: Swing Tranny Reinfocement Reply with quote
Thanks i will read through that.
nsracing
nsracing is offline
PostPosted: Mon Mar 15, 2021 10:53 am    Post subject: Re: Swing Tranny Reinfocement Reply with quote
The thru-bolt is nice idea but too much way above where it is suppose to give support. IMO.
Where it breaks is across the bottom of the sump. That area can be reinforced w/ an aluminum plate welded on it.
Also - I shuffle-pinned the side covers. SEems to hold up thru the years. The side-covers cannot shimmy or the backside of the tunnel will twist and rip across at the bottom.
Ohio Tom
Ohio Tom is offline
PostPosted: Mon Mar 15, 2021 12:25 pm    Post subject: Re: Swing Tranny Reinfocement Reply with quote
https://weddleindustries.com/products/6421R/6421R
