Quick 23-window headliner bow/rod question
thom
thom is offline
PostPosted: Sat Jul 12, 2025 6:30 am    Post subject: Quick 23-window headliner bow/rod question Reply with quote
How many headliner bows (or rods) would my 1957 23-window have? Most of the headliner was gone when I got the bus. I tried searching, and found lots of discussion about installation, but not much about the hardware.
My bus had 3 short bows in the remnants of the headliner, and one attached to the rear section of the roof. I had stashed everything away 18 years ago when I disassembled it all, but today I'm not sure if I have all of the parts.
Here's the single bow that I have that isn't part of the sunroof. It seems to fit that space, and has a 90° bend on one end.
The reason I'm unsure is I had a front roof clip from an early 60's standard, and it had a very small bow on either side of the air box; I kept those two before I gave it away, but I don't see where they would go on the '57. This thread says there's only one bow https://www.thesamba.com/vw/forum/viewtopic.php?t=779241 but it didn't feel authoritative.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
edgood1
edgood1 is offline
PostPosted: Sat Jul 12, 2025 9:23 am    Post subject: Re: Quick 23-window headliner bow/rod question Reply with quote
I'm pretty certain it's just that one between the sunroof and the rear hatch, not counting the shorter rods in the sunroof headliner.
1987 Syncro Westfalia powered by Subaru
'65 Westfalia
John Ghia
John Ghia is offline
PostPosted: Sun Jul 13, 2025 9:34 am    Post subject: Re: Quick 23-window headliner bow/rod question Reply with quote
How long is that headliner bow? I need to make one.
BUS BOYZ
thom
thom is offline
PostPosted: Mon Jul 14, 2025 6:30 am    Post subject: Re: Quick 23-window headliner bow/rod question Reply with quote
Mine is roughly 56 1/2 inches
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
bcs
bcs is offline
PostPosted: Mon Jul 14, 2025 11:59 am    Post subject: Re: Quick 23-window headliner bow/rod question Reply with quote
Hello Thom,
there is only one tunnel for a bow in the headliner (near to the luggage-compartment-door). The distance is approx 60cm from the sunroof-opening:
This is not an original headliner. I will try to find additional photos.
_____________
benjamin
John Ghia
PostPosted: Mon Jul 14, 2025 9:19 pm    Post subject: Re: Quick 23-window headliner bow/rod question Reply with quote
Thanks for the info
BUS BOYZ
