Rekey Ignition switch
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sun Jul 19, 2009 2:42 pm    Post subject: Reply with quote
I can't remember how I got mine off now, but to put it back on, I recall that I used a hollow drift or made something similar out a piece of metal pipe, to pop it back on.
Bruce
Bruce is offline
PostPosted: Sun Jul 19, 2009 2:29 pm    Post subject: Reply with quote
I use an old dental pick.
EDragnDean
EDragnDean is offline
PostPosted: Sun Jul 19, 2009 6:51 am    Post subject: Reply with quote
glutamodo wrote:
I switched my cylinder from one switch to another on my 62 once. But it's been so long now that I can't remember what I did to get that small retaining clip off the end of it. Maybe just tapped on it with a punch/hammer. I just searched the Gallery and found Bruce's photo of an older switch!
Thanks Glutamodo, that makes sense. Looking at the ignition, it has got to be damn near impossible to get the clip off that cylinder.
EDragnDean
PostPosted: Sun Jul 19, 2009 6:49 am    Post subject: Re: Rekey Ignition switch Reply with quote
Bruce wrote:
EDragnDean wrote:
....Send an ignition to Gabe for a rekey. Rekey works great, ignition switch does not. ......
Didn't he test it?
Have never had an issue with Gabe. Tumblers turn (his task) but ignition switch won't engage the starter, acc works. Put the original (after market ignition switch) back in and it works fine. Therefore, bad switch.
The Android
PostPosted: Sat Jul 18, 2009 11:33 pm    Post subject: Reply with quote
Bruce
Bruce is offline
PostPosted: Sat Jul 18, 2009 11:25 pm    Post subject: Re: Rekey Ignition switch Reply with quote
Didn't he test it?
EDragnDean
PostPosted: Sat Jul 18, 2009 10:30 pm    Post subject: Rekey Ignition switch Reply with quote
Short version. Send an ignition to Gabe for a rekey. Rekey works great, ignition switch does not. I have another switch... question is how do you remove the cylinder on the ignition switch? I would assume I could then just swap the guts, problem solved.
