Stupid question of the day...
TonyPgh
TonyPgh is offline
PostPosted: Wed Jul 31, 2013 11:40 am    Post subject: Reply with quote
Excellent! I need to print these out. Mine is a 6-72. I imagine the 71 are the same
1968 Type 1
https://youtube.com/c/SladesVWBeetle
View user's profile Send private message Visit poster's website Facebook Classifieds Feedback
ashman40
ashman40 is online now
PostPosted: Tue Jul 30, 2013 4:55 pm    Post subject: Reply with quote
The original VW fuse box diagram for '71-'72 is wrong! Surprised
Here is the (incorrect) VW diagram from the Wiring Diagrams section on this site:
The give away is the headlight fuses. Since the beginning of the late model body style ( '68 ) the headlights have always been fuses 3 thru 6. The full wiring diagram correctly shows them connected to these fuses.
Kabasue updated the fuse box diagram and corrected for the fuse placement. He also added the proper fuse color and created a inverted diagram that can be posted in the trunk for reference :
AshMan40
TonyPgh
TonyPgh is offline
PostPosted: Tue Jul 30, 2013 2:54 pm    Post subject: Reply with quote
Oh man. Thats it! Thanks Joel. I appreciate it!!
1968 Type 1
TonyPgh
TonyPgh is offline
PostPosted: Tue Jul 30, 2013 2:53 pm    Post subject: Reply with quote
1968 Type 1
Joel
Joel is offline
PostPosted: Tue Jul 30, 2013 1:51 pm    Post subject: Re: Stupid question of the day... Reply with quote
TonyPgh wrote:
When looking at the order of the fuses, compared to the photo below.
Does number one fuse on the chart start left "drivers side", to right, like looking up under the dash? If that made sense?
I am asking because when I blew a fuse yesterday while working on it..
"my fault", the front turn signals and parking lights were out, and it was on number one fuse, clear to the left "drivers side", while looking up at the fuse panel under the dash.
But..... my warning lights and fuel gauge were still on, and they went out when I removed the last fuse to the right number 12?
I have a 1972 Standard
THe above diagram is when looking at the trunk side of the fuse box where all the wiring is not the fuse side, which was really dumb on VWs part as you dont look at that side when replacing fuses.
If you look at the fuse side in the interior of the car it will be opposite way around to the diagram as you already found out.
I'd say it was just a misprint in the manual as VW didnt change the 70s fuse lay out, heres a correct one
TonyPgh
TonyPgh is offline
PostPosted: Tue Jul 30, 2013 1:06 pm    Post subject: Reply with quote
Oh I see whaf you mean. Thank you very much!!
I was trying to make sure my fuses were right. Which ones were 8&16 amps. I think I better double check. I put them in according to the diagram.
1968 Type 1
Volks Wagen
Volks Wagen is offline
PostPosted: Tue Jul 30, 2013 12:59 pm    Post subject: Reply with quote
Leave them alone. The #1 & #12 fuses seem wired right from this '72 standard diagram -
http://www.thesamba.com/vw/archives/info/wiring/bug_std_super_72.jpg
Your fusebox diagram in first post seem to not be right for your car.
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
TonyPgh
TonyPgh is offline
PostPosted: Tue Jul 30, 2013 12:14 pm    Post subject: Reply with quote
Sorry. I should have put that down. I was puttinv on a mexican bumper. It was the front signals. Seems like someone rotated some wires around. I dont know if I should start changing them back or leave them alone. The fuses blew due to me messing around.
1968 Type 1
TonyPgh
TonyPgh is offline
PostPosted: Tue Jul 30, 2013 12:13 pm    Post subject: Reply with quote
1968 Type 1
djkeev
djkeev is offline
PostPosted: Tue Jul 30, 2013 12:11 pm    Post subject: Reply with quote
Yes,
AS WIRED FROM THE FACTORY #1 is the the left side of the car.
That being said, it's been multiple decades and multiple owners, The wiring may have been rearranged by a PO at some point.
Dave
Ghia
Vanagon
Beetle
TryToBeOriginal
TryToBeOriginal is offline
PostPosted: Tue Jul 30, 2013 11:58 am    Post subject: Reply with quote
sounds like someone didn't like the way Germans wired things. By parking lights I'm assuming rear tail lights and the two flashers. It sounds like someone wired the flashers correctly but put the right and left tail light one 1 as well and moved speedo and fuel gauge to 12.
TonyPgh
TonyPgh is offline
PostPosted: Tue Jul 30, 2013 11:44 am    Post subject: Stupid question of the day... Reply with quote
1968 Type 1
