Oxygen sensor necessary?
Paulbeard
Paulbeard is offline
PostPosted: Tue Sep 01, 2015 8:58 am    Post subject: Reply with quote
insyncro wrote:
The biggest issue for those not running a CAT and or oxygen sensor....you are wasting gasoline every time you run the vehicle.
AND polluting OUR environment, with it blowing straight out your tailpipe.
Please have your EVAP hooked up, emissions systems compliant and keep the driveline serviced.
If you cannot afford to properly maintain a 20+ year old vehicle...get a bicycle.
That's I am trying to do: it was like this when I got it but we're making progress. It's not my daily driver so there's that. I get irritated when I find that someone else's remedy is to cut the wire or stick duct tape over the hole but that's what I'm finding.
Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
Git 'r DONE!
— dhaavers
insyncro
Banned
insyncro is offline
PostPosted: Tue Sep 01, 2015 6:50 am    Post subject: Reply with quote
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Aug 31, 2015 11:58 am    Post subject: Reply with quote
No, the argument is more like why worry about something that "could" help the the engine in the long run if you don't first worry about immediate threats. So don't add the fire suppression system unless you first deal with the likely causes of a fire, like replacing old fuel hoses and making sure any new ones are right for the job.
mark
newfisher
newfisher is offline
PostPosted: Mon Aug 31, 2015 11:53 am    Post subject: Reply with quote
Or the " why would I spend $99 on a blaze cut supression system when my van didnt come with one from the factory" argument.
crazyvwvanman
PostPosted: Mon Aug 31, 2015 11:34 am    Post subject: Reply with quote
That reminds me, just recently someone mentioned adding an oil cooler to their van, just before the van blew a hose and destroyed the engine. Why spend money and effort for something the van made it 30 years without? Sure, in theory the cooler may add some small additional life to something that already lasts for decades but then a hose blows and game over in spite of the cooler. Wonder if it was an old hose or one of the hoses added for the cooler?
Mark
Merian wrote:
I agree there is a lot of penny wise pound foolish attitude (along with "I spent thousands on upgrades, and nothing on maintenance")
newfisher
PostPosted: Mon Aug 31, 2015 11:23 am    Post subject: Reply with quote
And then there are the Prius owners. Dont get me started.
?Waldo?
?Waldo? is offline
PostPosted: Mon Aug 31, 2015 11:02 am    Post subject: Reply with quote
You either have a bad translator or an incorrect definition of 'literally'.
Merian
Merian is offline
PostPosted: Mon Aug 31, 2015 10:59 am    Post subject: Reply with quote
well, that kills my nascent theory - I was thinking that VW owners were cheap because it is an economy brand - the German name literally translates as "Cheap people's Car" Laughing
jimf909
jimf909 is offline
PostPosted: Sun Aug 30, 2015 10:19 pm    Post subject: Reply with quote
There's a corollary with BMW riders: "the only cheap part on a BMW motorcycle is the wingnut attached to the handlebars".
- Jim
Butcher wrote:
Guilty as charged.
Merian
Merian is offline
PostPosted: Sun Aug 30, 2015 9:56 pm    Post subject: Reply with quote
not here - both have posted on several threads about the cheapness of Vanagon owners
jimf909
jimf909 is offline
PostPosted: Sun Aug 30, 2015 9:19 pm    Post subject: Reply with quote
Merian wrote:
Can we make a stickie out of the comments by insyncro & Terry Kay??
Dang, did I miss a winner?
- Jim
Butcher wrote:
Guilty as charged.
Paulbeard
PostPosted: Sun Aug 30, 2015 8:17 pm    Post subject: Reply with quote
I'd guess it's the right one but somehow was never connected to the ECU. Not sure where it would connect, given that this is a Rev A ECU from the Tiico kit, back when no one had worked out how to take the South Africa-targeted ECU and make it work elsewhere. That took til Rev E, this year.
Now I have to wonder if the cat is operational. I'm thinking I'll worry about that later. The muffler is my first problem project, followed by the updated fuel rail that the updated ECU will need to work properly. Then we'll see if the O2 sensor is worth anything. They (FAS) spec a four wire one.
Git 'r DONE!
— dhaavers
Wildthings
Wildthings is offline
PostPosted: Sun Aug 30, 2015 7:58 pm    Post subject: Reply with quote
A '87 should have had a heated sensor so maybe you don't have the correct one in there. It should still work just takes longer to come on line. Likely it is pretty old and either it wasn't functioning correctly or there were other problems that cause a PO to disconnect it.
Edit: Oops, missed that you have a conversion. Crying or Very sad
Paulbeard
PostPosted: Sun Aug 30, 2015 5:07 pm    Post subject: I have similar question… Reply with quote
It looks like my O2 sensor is disconnected. I was looking at mufflers to replace mine with (I'll share the before and after: it will be entertaining) and the cats I saw displayed have a space for the O2 sensor where I have a dangling wire…
As an 87, mine is exempt from smog testing so I have no idea how nasty it's breath is. But it sounds like that should maybe be connected and I assume that means a wire run back to the ECU.
Just went out to refresh my memory and it's a single wire sensor, the wire being about 4 inches long.
Git 'r DONE!
— dhaavers
Merian
Merian is offline
PostPosted: Sun Aug 30, 2015 11:25 am    Post subject: Reply with quote
djkeev
djkeev is offline
PostPosted: Sun Aug 30, 2015 8:46 am    Post subject: Reply with quote
jimf909 wrote:
Just curious as to why you're (OP) curious about this.
I'm guessing needs a new Cat and wants to save the $$'s for the O2 mounts into the Cat.
Dave
Ghia
Vanagon
Beetle
jimf909
jimf909 is offline
PostPosted: Sun Aug 30, 2015 8:43 am    Post subject: Reply with quote
- Jim
Butcher wrote:
Guilty as charged.
Wildthings
PostPosted: Sat Aug 29, 2015 9:08 pm    Post subject: Reply with quote
Most people are going to be way ahead running the sensor. As others said the system will default to just reading the output from the AFM with the O2 sensor disconnected, so if your AFM isn't 100% on you may have drivability issues and suffer poor gas mileage. You may also find all those vacuum leaks that have been accumulating over the years that the Bay Window guys are forever fighting to eliminate. If lean enough you could also see valve damage and will be more likely to crack the header pipes.
fraggle00
fraggle00 is offline
PostPosted: Sat Aug 29, 2015 8:36 pm    Post subject: Reply with quote
Integral part to keep the engine running correctly. This isn't some part that's just for emissions control.
'91 Vanagon Carat
'87 Porsche 928S4 DOWN
'12 Fiat 500 Abarth
bluebus86
Banned
bluebus86 is offline
PostPosted: Sat Aug 29, 2015 7:01 pm    Post subject: Re: Oxygen sensor necessary? Reply with quote
VWNaught wrote:
I have an '84 Vanagon with a 2.1 litre installed in it. Please, what are the pros and cons of running without an oxygen sensor ? Thanx.
the brain will run in a default condition if the oxygen Sensor is removed, the default condition is a bit rich, so you will burn more fuel, wear the engine faster and shorten the life of the catalyst, you will also likely fail a smog test, and the van will pollute more.
I would not intentionally run with no O2 sensor.
