Question - seat interchangeabe
Rome
Rome is offline
PostPosted: Sat Sep 30, 2017 8:48 pm    Post subject: Re: Question - seat interchangeabe Reply with quote
The '73 style Beetle seat tracks went all the way to the end of US Beetle production for the '79 model year (which would've been a SuperBeetle cabriolet). Although the style appears similar to a '75 and later Rabbit/Golf, the vertical C shaped tracks themselves are spaced slightly wider apart on those cars. To make a seat from the Rabbit/Golf fit a Beetle, the down-arms need to be repositioned slightly closer together via welding. I think only one of the down-arms needs to be repositioned. You "can" bend one of the arms inward slightly to reduce the spacing, but that also brings the outer arm faces out of vertical on which the plastic slider spacers are positioned into the seat tracks. Not ideal on such an important safety item.
Horance
Horance is offline
PostPosted: Sat Sep 30, 2017 8:30 pm    Post subject: Re: Question - seat interchangeabe Reply with quote
I was at my local bone yard this morning and saw some 92 golf seats the bottom tracks look like my 73 beetle seats does any one know how far forward the seat track design goes for after 73?
i would like these seats if they would fit.
greenterbo
greenterbo is offline
PostPosted: Sat Apr 01, 2017 12:47 pm    Post subject: Re: Question - seat interchangeabe Reply with quote
Great thank you
Q-Dog
Q-Dog is offline
PostPosted: Sat Apr 01, 2017 12:45 pm    Post subject: Re: Question - seat interchangeabe Reply with quote
Seat tracks changed for '71-72 model year, and while the seats will fit onto an older track, they will wobble and not work well. If you can weld, you can install the later sliders in your older car.
The short answer is no, 1971 seats will not work properly in a 1969.
Also, seats mounts changed again for the 1973 model year.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
greenterbo
PostPosted: Sat Apr 01, 2017 12:15 pm    Post subject: Question - seat interchangeabe Reply with quote
What years of seats are interchangeable? Will 71 seats fit in a 69?
