Brent Samba Member
Joined: April 28, 2010 Posts: 1622 Location: San Tan Valley, AZ
Posted: Thu Jul 08, 2021 6:11 pm Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? |
_________________ 69 Fastback Build
Berg5 Build |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23398 Location: Kimball, Mi
Posted: Wed Jul 07, 2021 12:00 pm Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? |
Tvättbjörn wrote: |
What are you guys are using? Each door seal has two of these plastic studs for holding the door seal in place in the upper A-pillar area. What will work? Any Napa or ..... part number I can use? Mine are missing and I finally found the spot where the water gets in Any info is great. I did not find any information with search. Thanks |
Nothing in the "help" section? Usually to can find something with a round head that could be trimmed to fit. The hard part is finding the right size to fit the hole in the steel. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4631 Location: Pasadena CA/DTLA soon China
Posted: Tue Jul 06, 2021 9:33 am Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? |
I tried.  _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
Tvättbjörn Samba Member
Posted: Mon Jul 05, 2021 9:55 pm Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? |
Yes, I did see it, but one of the used clips is cracked in the center and the new clips are on the other side of the planet. I was hoping there is a similar clip which could be used. I know the square head is important for the support of the seal. |
Posted: Mon Jul 05, 2021 7:29 pm Post subject: Clips / plastic studs for door seal for upper a-pillar area ?? |
