0.004 or 0.006 valve adjustment every 3000 miles ?
Ofir
Ofir is offline
PostPosted: Thu Oct 19, 2006 6:10 am    Post subject: 0.004 or 0.006 valve adjustment every 3000 miles ? Reply with quote
Hi,
I adjust the valves every 3000 miles , it's O.K. and safe to adjust them 0.004 instead 0.006 ? or should I stay with 0.006 ?
I'll notice any improvement when adjusting 0.004 comparing to 0.006 ?
I read that VW switch from 0.004 to 0.006 due too faulty exhaust valves resulting from lack of maintainance.
It's stock 1600cc engine
Thanks
Ofir
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Oct 19, 2006 6:12 am    Post subject: Reply with quote
For the stock aluminum push rods, use the 0.006".
Ofir
Ofir is offline
PostPosted: Thu Oct 19, 2006 6:14 am    Post subject: Reply with quote
Hey Randy - thanks.
there is any added value for doing this ?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Oct 19, 2006 6:22 am    Post subject: Reply with quote
Some people set the intake to .004" and the exhaust to .006" since the intakes don't get as hot.
If your valves are too tight then they won't fully seat. They need to fully seat so they can transefer the heat to the head and away from the valve.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
veedubcrazy
veedubcrazy is offline
PostPosted: Thu Oct 19, 2006 6:26 am    Post subject: Reply with quote
Ofir wrote:
Hey Randy - thanks.
About 20 hp.... Shocked Laughing
1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer"
Vayabroder
Vayabroder is offline
PostPosted: Thu Oct 19, 2006 6:56 am    Post subject: Valves Reply with quote
Ofir; Glenn is right on. I say with these cars, with valve adjustment it's "better loose than sorry" because it's safer as it helps cool the engine a little better.
Ofir
Ofir is offline
PostPosted: Thu Oct 19, 2006 7:10 am    Post subject: Reply with quote
Thanks.
What you guys doing set the intake to .004" and the exhaust to .006" ?
Or all valves .006" ?
Mr. 010
Glenn is offline
PostPosted: Thu Oct 19, 2006 7:41 am    Post subject: Reply with quote
I had chromoly, so I set them to a "loose zero".
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Dave
Samba Elder
Dave is offline
PostPosted: Thu Oct 19, 2006 7:59 am    Post subject: Reply with quote
What Glenn means by "loose zero" is that he adjusts the valves so there is no movement between the rocker arm and the valve tip ( you can't see or feel any movement there) but the pushrod still turns freely. As Glenn said, he has chromoly pushrods, which don't expand as much as the stock, aluminum pushrods. The idea between the .004 or .006 on the stockers is to give them room to expand and grow as they heat up, and have very little lash when fully warmed up.
A little O/T, but did you know that the VW 36 horse pushrods had WOOD in them? I kid you not ( or "knot" LOL)
2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter"
Mr. 010
Glenn is offline
PostPosted: Thu Oct 19, 2006 8:05 am    Post subject: Reply with quote
Isn't having some wood a good thing? Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Vayabroder
PostPosted: Thu Oct 19, 2006 8:52 am    Post subject: Adjustment Reply with quote
Ofir wrote:
Thanks.
You can do either one but the later editions of the VW Service Manual suggested .006" for all valves; it's also easier that way because you're only using one type of feeler gauge for all adjustments.
Randy in Maine
PostPosted: Thu Oct 19, 2006 9:07 am    Post subject: Reply with quote
That is called "morning wood".
I set them all (stock aluminum push rods) to 0.006". I love that engine sound, sort of like a turbocharged sewing machine. Sweet.
jamestwo
jamestwo is offline
PostPosted: Thu Oct 19, 2006 9:23 am    Post subject: Reply with quote
I do .004 on intake and .008 on exhaust, except on new engines, then I go .006 on itakes and .008 on exhaust.
The extra clearance is just insurance until the vlves settle in.
Ofir wrote:
Thanks.
hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY.
Bruce
Bruce is offline
PostPosted: Thu Oct 19, 2006 12:51 pm    Post subject: Reply with quote
VW went for many years with the spec of .004". The only reason they increased it to .006" was to prevent the damage done by negligent owners that didn't follow the recommended adjustment schedule. Since the recommended valve adjustment interval is 6000 miles, if you are doing it every 3000 miles, you will be perfectly safe setting them all to .004". Then make observations the next time. If the lash does not change, that confirms it is perfectly safe to set them at .004".
Setting them to .004" instead of .006" will make the engine a bit quieter since there will be less valve clatter.
Ofir
Ofir is offline
PostPosted: Thu Oct 19, 2006 1:33 pm    Post subject: Reply with quote
Bruce thanks for your clear to the point answer. ( as usual )
Ofir
MTIguy
MTIguy is offline
PostPosted: Thu Oct 19, 2006 3:04 pm    Post subject: Valve adjustment Reply with quote
Ofir,
I set the valves at .006, intake and exhaust. I too asked this question many times, all of my manuals state .006 for 1500-1600. Once you set them once you will get the feel for it. I find that the feeler guage is a pain in the arse.
If you hear the mechanical tick to still seem prevelant, watch your oil type for the climate and readjust every 1500. Gaskets are cheap and the practice will help. I tried and tried untill I was satisfied. Don't get frustrated.
Good Luck
Brian
Alan_U
Alan_U is offline
PostPosted: Fri Oct 20, 2006 8:24 am    Post subject: Reply with quote
Get some good quality german cork valve cover gaskets. Glue them in with some permatex "right stuff" or the Ultra grey. Now you can use those valve cover gaskets many many times without changing them.
You should take a peak at the valve lash frequently.
You may find the valve lash is consistant. Run them at .004 if you see that they dont get tight.
Problem with people is that people with feeler guages sometimes may set the lash too tight depending on how they use the feelers. Slight friction is what you need to set them at. Too tight a friction may make a .006 valve lash actually a .0055 or even tighter.
11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's.......
nextgen
nextgen is offline
PostPosted: Fri Oct 20, 2006 9:18 am    Post subject: Reply with quote
Even though I run a T-4 In my bug,I am still using the T-1 fanhousing so I fear #3 may be getting less cooling. Not that I have ever seen a Converted T-4 overheat. BUTTTTTTTTTTTTTTT--- things happen real fast and setting the valves at .004 for 3k freaks me out. Fan belt gets loose or breaks,within minutes you can lose an engine. That happened to me in the dead of a winter snowstorm at -6f and it took minutes from when the gen light went on till I could get to a safe place to park and a rod came though the case.
I ran too many T-1's and seen too many #3 valves burnt. I will stick to .008 on the exhausts. Hay how many cars today do you valve noise and the aircooled fan whinnnnne! Ha!!! That's what makes us different!!!
Joe
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
Vayabroder
PostPosted: Fri Oct 20, 2006 11:20 am    Post subject: Cooling Reply with quote
Get yourself a DTM shroud and forget about it!!...
aztoaster
aztoaster is offline
PostPosted: Fri Oct 20, 2006 12:00 pm    Post subject: Reply with quote
thanks for the tip...I'll keep this in mind whilst dialing in the valves. I've been setting them at .006 and check with the .008 feeler. If the .008 slides through, I tighten it down some more. I failed to think of the other end of spectrum.
