CB cheater cam or engle 100 in a stock 1600
clooney
clooney is offline
PostPosted: Sun Jul 03, 2011 10:39 am    Post subject: CB cheater cam or engle 100 in a stock 1600 Reply with quote
would there be any big difference iof i were to use these 2 cams in a stock 1600 motor?
reason i am asking is because my son dropped the only stock cam I have and it broke into 2, so i have to buy a cam anyway.
am i just wasting my time and better off to buy another stock cam?
motor will just be a stock 1600, new KS 85.5 pistons, stock crank, rods full flowed, mildly ported stock heads, dual 36 DRLAs. lightweight bug, stock ratios.
daily driver for my son.
borninabus Premium Member
Samba R&D Dept.
borninabus is offline
PostPosted: Sun Jul 03, 2011 10:55 am    Post subject: Reply with quote
yes there will be a huge difference.
especially if you use them both Wink
seriously though: the 100 has a great low end. the only thing i didn't like about mine was the not as smooth as stock idle.
88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
clooney
clooney is offline
PostPosted: Sun Jul 03, 2011 10:58 am    Post subject: Reply with quote
yours had stock carburation and what compression?
[email protected]
john@aircooled.net is offline
PostPosted: Sun Jul 03, 2011 11:26 am    Post subject: Re: CB cheater cam or engle 100 in a stock 1600 Reply with quote
that engine is screaming for an Engle 110 or Web 163
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Matthew
Matthew is offline
PostPosted: Sun Jul 03, 2011 11:28 am    Post subject: Reply with quote
If you are going to use dual carbs and an extractor exhaust, you certainly would benefit from using a bigger camshaft. The dual carbs would make it idle as smooth or smoother than stock with either cam you mentioned.
Don't forget the HD rocker shafts and single HD valve springs.
1965 Beetle sedan
Click to view image
DarthWeber
DarthWeber is offline
PostPosted: Sun Jul 03, 2011 12:50 pm    Post subject: Re: CB cheater cam or engle 100 in a stock 1600 Reply with quote
After dropping the original cam and breaking it in two his son doesn't rate either of those cams. Wink
jk Laughing
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
bsairhead
bsairhead is offline
PostPosted: Sun Jul 03, 2011 2:10 pm    Post subject: Reply with quote
So the son drops the cam and it breaks. Sounds like he did your engine a favor.
Derek Cobb
Annoying
Derek Cobb is offline
PostPosted: Sun Jul 03, 2011 2:24 pm    Post subject: Reply with quote
"Dad, I dropped the Carburetor and broke it. Can we get those dual Webers now?" Wink
clooney
clooney is offline
PostPosted: Sun Jul 03, 2011 3:49 pm    Post subject: Reply with quote
ok . 110 it is.
can i stick with the stock compression? or do i need to bump it up?
with this cam in a stocker like this, what sort of RPM range i should be looking at? 5K?
[email protected]
PostPosted: Sun Jul 03, 2011 3:51 pm    Post subject: Reply with quote
tighten the deck height to .040" and run it.
Matthew
Matthew is offline
PostPosted: Sun Jul 03, 2011 3:56 pm    Post subject: Reply with quote
This assumes there is no step in the head. If so remove the step as well. Total deck = distance from top of piston to flat area in combustion chamber. Alot of people just measure distance from top of piston to top of cylinder at TDC.
1965 Beetle sedan
Click to view image
spencerfvee
spencerfvee is offline
PostPosted: Sun Jul 03, 2011 4:02 pm    Post subject: Re: CB cheater cam or engle 100 in a stock 1600 Reply with quote
guys he said all stock motor .come on a engle 110 cam for a stock motor that hes going to put around town in not ever one wants a race motor lol .my self i am running a cb cheater cam .love it it pulls great to 4,000 rpm if you want it to . pulls hills like there not there very street friendly cam . i have driven bugs with engle 100 cams . i like the cb cheater cam better .for a all stock motor .just my two cents spencerfvee......................
Samba R&D Dept.
PostPosted: Sun Jul 03, 2011 5:26 pm    Post subject: Reply with quote
yes. stock 34PICT3 and 8.0 compression in a bus.
it pulled strong but I shoulda used a counterweighted crank.
it beat itself to death in about 60,000 miles.
[email protected]
PostPosted: Sun Jul 03, 2011 5:44 pm    Post subject: Re: CB cheater cam or engle 100 in a stock 1600 Reply with quote
Spencer,
what part of "Dual 36 DRLAs with lightly ported heads" is "stock"?
66brm
66brm is offline
PostPosted: Sun Jul 03, 2011 8:21 pm    Post subject: Reply with quote
Hell yeah w110 all day long, it'll love ya for it
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
Buellistic
Buellistic is offline
PostPosted: Sun Jul 03, 2011 9:46 pm    Post subject: Reply with quote
This CB Cheater Cam. Is it the Eagle 2235? If so... damn!
I picked the 2235 in an attempt to not over-cam my 1776 build. Collector exhaust, Weber Progressive carb, 35.5/32 heads with cleaned up ports.
modok
modok is offline
PostPosted: Sun Jul 03, 2011 9:48 pm    Post subject: Reply with quote
The cb cheater is the #2280
It is for a idle-4000 rpm range
If an engine has a better intake and you don't need torque down to idle, then might as well use a more radical cam. I believe the progressive is a rather large carb, so you might as well use a too big cam, that way it matches!
Buellistic
PostPosted: Sun Jul 03, 2011 9:56 pm    Post subject: Reply with quote
Ah, okay cool. *wipes sweat off brow* :p
modok
modok is offline
PostPosted: Sun Jul 03, 2011 9:59 pm    Post subject: Reply with quote
Yeah, it should be awright
I have not tried that particular CB grind, but the numbers look pretty good.
clooney
clooney is offline
PostPosted: Thu Jul 07, 2011 12:55 am    Post subject: Reply with quote
ok thanks for all the advice. i am getting the 163.
what about pushrods? the stock aluminium is good enough or i need steel or chromoly?
if chromoly, which is good?
http://www.vwparts.net/BP4084.html
