Broken pencil in cylinder while finding TDC
rmr2122
rmr2122 is offline
PostPosted: Sun May 15, 2016 10:20 am    Post subject: Broken pencil in cylinder while finding TDC Reply with quote
1971 Super, stock engine. I was doing a simple distributor swap and did the pencil test to confirm TDC. The pencil broke and the eraser end is now lost in my #1 cylinder. What's the fastest and easiest way to get it out? I can't feel it down the hole so tweezers are not going to work.
Thanks in advance.
Agent47
Agent47 is offline
PostPosted: Sun May 15, 2016 10:46 am    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
You could try a shop vac with the smallest attachment you have, it may be able to pull the piece out.
Personally, I would take the head off and ensure all the foreign materiel is removed; it would be work the extra work not to damage my engine.
rmr2122
rmr2122 is offline
PostPosted: Sun May 15, 2016 10:55 am    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Thanks! Do I need to remove the engine to take the head apart?
Cusser
Cusser is offline
PostPosted: Sun May 15, 2016 10:56 am    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
1. I can't believe that you did this - you had received poor information, maybe from the Compleat Idiot book. A plastic drinking straw is a tons better choice !!!
2. Others have done this too, and posted their sob stories and fixes here.
http://www.thesamba.com/vw/forum/viewtopic.php?t=626188&highlight=pencil+broke
http://www.thesamba.com/vw/forum/viewtopic.php?t=415893&highlight=pencil+broke
http://www.thesamba.com/vw/forum/viewtopic.php?t=225356&highlight=pencil+broke
Thanks in advance.
rmr2122
rmr2122 is offline
PostPosted: Sun May 15, 2016 11:04 am    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
whobba
whobba is offline
PostPosted: Sun May 15, 2016 11:08 am    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Ugh. That's no fun. Try one of those mechanic's grabber tools like this: http://www.amazon.com/Flexible-Claw-Automotive-Mechanic-Generic/dp/B000RB7AGY
**SUPPORT THE SAMBA**
http://www.thesamba.com/vw/donate.php
http://www.thesamba.com/vw/products/
Q-Dog
Q-Dog is offline
The job would be much faster if you remove the engine.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
rmr2122
rmr2122 is offline
PostPosted: Sun May 15, 2016 12:15 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Thanks for the troubleshooting. I live in Brooklyn and my car is parked on the street, so dropping the engine is a bigger deal than if it were in a driveway or garage.
I'm going to try the shopvac and grabber methods. If they don't work, I'm going to fire it up and let the damn thing burn. I'm sure there will be some disagreement with this method, but I seriously double the damage capabilities of a thin piece of metal wrapped around the end of the pencil on this tank of an engine.
Dougy Dee
Dougy Dee is offline
PostPosted: Sun May 15, 2016 12:17 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Wont a magnet work on the eraser end of the pencil?
slalombuggy
slalombuggy is offline
PostPosted: Sun May 15, 2016 12:30 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Have you ever seen what a wafer thin lock washer will do to a head and piston? Don't think that it will pop right out, you will do damage to your motor no ifs ands or buts. If it doesn't come out with a vacuum pull the head or fk up your engine, your choice.
brad
Tim Donahoe
Tim Donahoe is offline
PostPosted: Sun May 15, 2016 12:32 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Use the shop vac, or any vacuum cleaner. Tape up a clear hose to the vacuum suction--a hose that will fit into the spark plug hole. Stick the hose in and turn on the vacuum. Watch the clear hose for the eraser head.
However, if no eraser shows up in the hose, the eraser may simply be stuck to the hose end, so gently pull out the hose with the vacuum still operating.
Tim
Let's do the Time Warp again!
Richard O'Brien
johnnypan
johnnypan is offline
PostPosted: Sun May 15, 2016 12:44 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Tim
Uhh,if the rings are good you wont draw the eraser out....correcting stupidity should cause pain,it keeps the process from repeating..yard out the engine,take off the head.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun May 15, 2016 1:06 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
[/quote]
Take the pulley bolt off and turn the engine so the key way is at 9:00. Now it is at TDC on either #1 or #3. Reinstall the nut, remove the valve covers and rock the engine back and forth observing the rockers on #1 and #3. If the #3 rockers are moving, it's at TDC on #1. If the #1 rockers are moving, it's at TDC on #3.
No need to stick anything inside the cylinder.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Volks Wagen
Volks Wagen is offline
PostPosted: Sun May 15, 2016 2:12 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Yes, a rubber magnet.
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
Mr. 010
Glenn is offline
PostPosted: Sun May 15, 2016 2:22 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Maybe a wood magnet would be better.
The metal around the eraser is most likely aluminum.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Dougy Dee
PostPosted: Sun May 15, 2016 2:46 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
ALUMINUM! Then that wont work. I should have checked more pencils than the old one I found in the back shop... It was steel/magnetic.
Danpa
Danpa is offline
PostPosted: Sun May 15, 2016 3:00 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Could he/she remove the bolts in the rear of the frame fork and lower the engine/trans enough to get the head off? Might not have to completely remove the engine that way.
Just a thought,
Dan
Old n' slow
Old n' slow is offline
PostPosted: Sun May 15, 2016 3:11 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
Take it from me, I've worked on enough old junk on Queens N.Y. streets. If you can't possibly pull the engine and you have 115 volt out there on the curb, do the shop vac with the tiny hose, etc. but don't fire it up, just turn it over by hand and hopefully crunch it up enough separating the aluminum band from most of the wood. Then do the shop vac again until you at least get the metal piece. Any wood left shouldn't be too bad if it's in small enough pieces. It's not the right way but sometimes you gotta do what you gotta do.
Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel .
Volks Wagen
PostPosted: Sun May 15, 2016 3:26 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
I wonder would pouring oil in the plug hole fast cause it to float up and out?
Mr. 010
Glenn is offline
PostPosted: Sun May 15, 2016 3:48 pm    Post subject: Re: Broken pencil in cylinder while finding TDC Reply with quote
So is the cast iron cylinder.
I'd get a borescope and one of those 3 finger grabbing things on a flexible shaft.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
