Rear Hatch Spring Rubber Isolator
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Mon Oct 15, 2018 3:09 pm    Post subject: Rear Hatch Spring Rubber Isolator Reply with quote
Im just cleaning out my bus for paint and found a small chunk of rubber laying there. Turns out it was a piece of the spring isolator rubber. One is gone completely and the other is as you see it here:
So...who sells these little trinkets? And has anyone ever changed them?
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
easy e
easy e is offline
PostPosted: Mon Oct 15, 2018 3:19 pm    Post subject: Re: Rear Hatch Spring Rubber Isolator Reply with quote
I don't see anybody advertising them by the part number (2 required): 211-829-147b
aka: Evan
flemcadiddlehopper
PostPosted: Mon Oct 15, 2018 5:04 pm    Post subject: Re: Rear Hatch Spring Rubber Isolator Reply with quote
Thanks for that. I couldn't find them through regular source either.
I guess I could give the parts dept. at VW dealership a call and see how good their vintage parts search is.?
Gordo.
mdege
mdege is offline
PostPosted: Tue Oct 16, 2018 12:43 am    Post subject: Re: Rear Hatch Spring Rubber Isolator Reply with quote
Maybe you could use the rubber mounts for the Vanagon power steering lines. They have a similar shape.
- Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
BarryL Premium Member
BarryL is offline
PostPosted: Tue Oct 16, 2018 6:48 pm    Post subject: Re: Rear Hatch Spring Rubber Isolator Reply with quote
You could go back to the previous version that was a hose on one of the torsion rods.
Do you have the press board that goes above the rods?
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Tue Nov 28, 2023 7:26 pm    Post subject: Re: Rear Hatch Spring Rubber Isolator Reply with quote
ISP West has them now
https://vwispwest.com/torsion-spring-rubber-buffer-211829147b/
Stocknazi
Stocknazi is offline
PostPosted: Wed Nov 29, 2023 9:17 am    Post subject: Re: Rear Hatch Spring Rubber Isolator Reply with quote
I've never seen any Masonite boards in this area. You think those are factory fitted?
WANTED:
Thomas Jefferson
BarryL is offline
PostPosted: Wed Nov 29, 2023 6:54 pm    Post subject: Re: Rear Hatch Spring Rubber Isolator Reply with quote
Those are. All original '67 Kombi. Anyone else out there verify? It's soft pressboard.
