Rusted64 Samba Member
Posted: Thu Jun 03, 2021 8:08 am Post subject: Pulling the Front Inner Fender Forward |
I'm having a tough time pulling my passenger side inner fender the last 1/4 inch on my '64 beetle. It was apparently bumped in the past and bent back slightly. I've hammer and dollied the wrinkles flat as bet as could but the nose still needs to come forward a bit more.
the picture with the white fender is after hammering, the others are before.
Has anyone had any luck slide hammering using the bumper mount?
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8856 Location: Sunset, Louisiana
Posted: Thu Jun 03, 2021 8:32 am Post subject: Re: Pulling the Front Inner Fender Forward |
You need steady pressure. Put it on something, like a frame rack, or between two trees/posts, and pull from the bumper mounts while working the wrinkles.
Or cut it off and replace it. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Sat Jun 05, 2021 7:45 am Post subject: Re: Pulling the Front Inner Fender Forward |
Bolt the bumper iron in place tightly. Wrap a chain around it securely and the other end around a tree or concrete post. Reverse the car away in a straight line or pull it back until there is a strain on the chain. With a hammer and dolly hammer the wrinkles flat and release the tension. Repeat until lined up _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
