easy e Samba Member
Joined: May 28, 2008 Posts: 3939 Location: 1 hr north of Santa Barbara
Posted: Sat Dec 17, 2016 3:19 pm Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Ya right... to back that up.... please post a picture of you wearing the hat with some sunglasses on... touching a voltage regulator or something.
_________________ aka: Evan
“They are about as worthless as the tits on the boars that live in the woods behind their junk yard.” -Weatherly |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1592 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Sun Dec 18, 2016 5:26 am Post subject: |
Eric&Barb wrote: |
Very cool! Got one of those hats and did not know that they were that early. It might have come out of the Buffalo NY dealership that was closed about 1960 due to conflict between dealership owner and VOA. Bill D. bought out the entire contents back in the early 1990s. |
Was that the Jim Kelly dealership? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25986 Location: Olympia Wash Rinse & Repeat
Posted: Sun Dec 18, 2016 9:44 am Post subject: |
peecee69 wrote: |
Do not know the name of the dealership, just the location. _________________ In Stereo, Where Available! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4776 Location: St Charles, MO
Posted: Sun Dec 18, 2016 10:07 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
I've got one of those hats in NOS condition too in my collection. I'm afraid to put it together and try it on!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
victorvant4 Samba Member
Posted: Sat Feb 04, 2017 4:55 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Hi!
I´ve restored my governor in a 1500SP engine. the K screw is not tight to keep the intake clap as open as possible. I don´t know if it´s right.
So, at slow motion (no foot in the pedal) the RPM aren´t stable. It goes up and down (800-100-800-...) all the time.
Does anybody have the same problem? Is it right? Vac leak maybe?
It has no seal or loctitte in the front top, is it right?
I´ve read the hole thread and there´s a great info here. Congrats!!
Thank you very much!! |
Joined: April 27, 2002 Posts: 6771 Location: Pentwater, Michigan
Posted: Sat Feb 04, 2017 5:13 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Hi back attcha, Welcome to The Samba! the picture on the left doesn't look right. the tension spring does not appear to be attached to anything. It does sound like you have a vacuum leak. Try sealing the cover to the housing as originally done. _________________ Roads Scholar
Member# 2059 |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23905 Location: NYC/Upstate/ROW
Posted: Sat Feb 04, 2017 5:57 am Post subject: |
peecee69 wrote: |
Eric&Barb wrote: |
Jim Kelly's was open well after 1960... Must have been another?? _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Sat Feb 04, 2017 7:58 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Hi again!😅
The left pic is before i restored it! The left one is how it is now...
I'll try to seal the front cover.
Thank you tasb!! |
Posted: Sat Feb 04, 2017 10:05 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
victorvant4 wrote: |
Two lefts do not make a right! Think second sentence should be "right" instead of left. _________________ In Stereo, Where Available! |
Posted: Sat Feb 04, 2017 11:38 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Eric&Barb wrote: |
Two lefts do not make a right! Think second sentence should be "right" instead of left. |
Right!! 😅
What do you think about leave soft K screw to keep the intake clap opener?
Is it ok? |
Posted: Sun Feb 05, 2017 11:15 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Eric&Barb wrote: |
Right!! 😅
Is it ok? |
Seeking to undersand what you are saying/asking here _________________ Roads Scholar
Member# 2059 |
Posted: Sun Feb 05, 2017 1:50 pm Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
tasb wrote: |
Seeking to undersand what you are saying/asking here |
I´m sorry.
In the first pic you can see how i´ve put the K screw. It´s not tight to keep the intake clap as open as possible.
I don´t know if it´s right or not.
That´s my question.
Thank you Everett! |
Posted: Sun Feb 05, 2017 2:00 pm Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
If you increase the tension on the top main spring the butterfly (flapper) will not close as quickly. There's also and adjustment screw missing from the bottom that will keep the arm from coming down fully. Sounds like you are trying to install the governor but not have it do any work? That's common now a days and better than just curtting/removing the butterfly which destroys the governor. _________________ Roads Scholar
Member# 2059 |
Gwdghiaguy Samba Member
Joined: December 06, 2013 Posts: 340 Location: Greenwood, SC
Posted: Sun Oct 01, 2017 7:42 pm Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
any reason I can't drop this in my carb cleaner like it is? Should I put the cover back on first? thanks
byron _________________ 1957 Oval Window
1963 Alabama Camper Bus
1971 Ghia
1971 Baywindow Bus
Posted: Mon Oct 02, 2017 8:50 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Go ahead, there's nothing that can be hurt by a brief dunk. Make sure you relubricate, of course. It's good practice to reseal the cover too, so that its air tight. _________________ Roads Scholar
Member# 2059 |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15242 Location: Casa de Oro, California
Posted: Mon Oct 02, 2017 8:55 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Gwdghiaguy wrote: |
any reason |
It looks too clean to dip in the gnarly cleaner stuff. One reason not to dip it would be that there is a permanently sealed chamber with the piston in it that can get its seal eaten by the cleaner. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71543 Location: Phoenix 602
BarryL  Samba Member
Posted: Mon Oct 02, 2017 9:22 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
EverettB wrote: |
I think it might only be a metal cylinder? |
So no gasket where it has the body rivets?
Anyway I bet it would be hard to get the icky carb-dip out if it got in the chamber. |
Posted: Mon Oct 02, 2017 9:39 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
EverettB wrote: |
I was wondering if there is a seal in there too.
A seal could get damaged by carb. cleaner
I think I'll just put the cover back on and scrub it by hand. Thanks for everyone's input. byron _________________ 1957 Oval Window
1971 Ghia
1971 Baywindow Bus
Posted: Mon Oct 02, 2017 3:35 pm Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
BarryL wrote: |
EverettB wrote: |
I don't see anything there on the ones I looked at.
I have one that has the cap loose, here's what it looks like with the cap removed:
It's had the entire valve removed too _________________ How to Post Photos
