Max Welton Samba Member
Joined: May 19, 2003 Posts: 11035 Location: Black Forest, CO
Posted: Tue Mar 09, 2010 4:21 pm Post subject: |
Hmm ... I used a modified ring-expander for the big crankshaft snap-ring.
Searching...
http://www.sears.com/shc/s/p_10153_12605_009454870...921x00003j
So duckbills are like needle-nose pliers but with lots more leverage. Got it.
But I don't have one.
Alright ... time to refocus. This little effort was simply to make the breather look as nice as the rest of the engine. Trying to get the car road-worthy to drive to the BOR in Phoenix later this month.
I can't afford the amount of calendar time I'm spending on this. The options are:
A) Leave it alone.
B) Bead-blast it as it is, flush the insides very well (to get the glass bead out) and repaint the black parts while masking off the rest.
I choose B.
Thanks guys.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Mar 09, 2010 7:29 pm Post subject: |
If you have the breather off assembly off, you should be able to push the sleeve out from below.
The pliers I was talking about was this kind. I guess they are called C-ring pliers.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
FASTBACKDON The other insensitive jerk like Neil
Joined: October 08, 2004 Posts: 3592 Location: TORRANCE CALIF
Posted: Wed Mar 10, 2010 9:34 pm Post subject: |
Max that breather is incredible. I know where to send mine to get restored Damn. I am just glad the tool worked. If the breather is any indication of what the rest of your engine will look like wow is all I can say.
Don _________________ FUCK CANCER FUCK CANCER FUCK CANCER!!
Mom 25 months of standing up to Cancer R.I.P I miss you so much.
Buy my best friends stuff
http://www.thesamba.com/vw/classifieds/search.php?username=56TIMOTEO
(21:10:42) Jennepher: Russell is our proudest achievment. I feel like Samba created him from a little nugget of crap into a full blown adult. |
TommyBoyGomes Samba Member
Joined: May 28, 2005 Posts: 1535 Location: L.A./Dublin, Irl
Posted: Fri Apr 23, 2010 6:52 am Post subject: |
Tommy I already have the correct tool to remove the breather just come over and get it. _________________ FUCK CANCER FUCK CANCER FUCK CANCER!!
EverettB  Administrator
Joined: April 11, 2000 Posts: 71491 Location: Phoenix 602
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3068 Location: Portland, Oregon
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Sat Apr 24, 2010 10:08 am Post subject: |
I've never seen this sleeve on the engines that I've pulled apart. I swear, I always learn something new in this forum that I didn't know before.
I do have quite a few engines that are completely original, that I've never pulled apart at least. Will be interesting to see if the sleeve is inside. _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Mon May 10, 2010 11:58 pm Post subject: |
Hey Max,
I've dissassembled and painted my breather assembly as well (btw, thanks for stealing my silver-and-black painting scheme ) and had a question. What gasket did you use between the stand and the breather? I see on ispwest's website that there's a gasket that goes between the two, but in my elring set, I only see a metal washer (similar in style to the one on the oil relief valve) that could fit the diameter of the stand throat. Is this metal one the right gasket to use underneath the breather? If not, where'd you get the right one? Did you permatex it? Thanks! |
Posted: Tue May 11, 2010 9:50 am Post subject: |
That gasket does not come in the gasket set.
You will have to make one.
Finish off that box of Wheaties, and get your scissors out. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
RAIDER SS Samba Member
Joined: November 21, 2003 Posts: 270 Location: Fairport, New York
What is that brillo pad? I do not have one in my '72....should I?
I have a light tension spring between the plastic cap and the lower washer.....is that correct for the '72 breather box assy? _________________ 1972 SquareBack.....recycled back to life......
"Elwood" |
Posted: Tue May 11, 2010 3:04 pm Post subject: |
Ah, got it Russ. Good thing I just finished some frosted mini wheats! |
Posted: Tue May 11, 2010 3:28 pm Post subject: |
RAIDER SS wrote: |
I have a light tension spring between the plastic cap and the lower washer.....is that correct for the '72 breather box assy? |
That scrubby is an oil seperator.
It is something for the oil to condense on.
When they went to the closed vent system, and not the road draft tube, VW did away with the scrubby. Figured they did not need to worry about it dripping on the ground, or your garage floor. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Tue May 11, 2010 4:17 pm Post subject: |
Russ, what have you used in the past as a substitute for the oile filter/nest/brillo pad looking thing? I'm hesitant to use thick steel wool and risk some of the steel falling into the engine. I'd sure like the oil to condense on something rather than the air filter I'm putting on the end of the breather. Anything you'd recommend? Thanks! |
Posted: Tue May 11, 2010 4:20 pm Post subject: |
Do you know those body washing things your girl friend/wife uses?
I have used a piece of one of those before. Do not pack it too tight, or it will cause back pressure. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Tue May 11, 2010 4:22 pm Post subject: |
you mean a loofah? (sp?) Most of those are some type of polymer or nylon I thought... Wouldn't want that to melt. Or do you mean more of a sponge material? |
Posted: Tue May 11, 2010 4:23 pm Post subject: |
It does not get that hot there. Probably not over 100-120* at the breather. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
