1970 bus trailer hitch install
Page: Previous  1, 2, 3
chabanais
chabanais is offline
PostPosted: Wed Nov 23, 2016 3:11 pm    Post subject: Re: 1970 bus trailer hitch install Reply with quote
I have the same Vintage Speed exhaust and would be curious whether this application fits.
"I spud therefore I yam."
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Tue Dec 06, 2016 3:59 pm    Post subject: Re: 1970 bus trailer hitch install Reply with quote
My new one bar design will work with the stock style Vintage speed exhaust. I Thought I have a photo of the setup but I can't find it. It will not work with the lowered bus style.
Why buy what you can build.
earlybayjim
earlybayjim is offline
PostPosted: Sat Oct 27, 2018 6:00 pm    Post subject: Re: 1970 bus trailer hitch install Reply with quote
Has anyone confirmed the vintage speed exhaust fitment? I have this exhaust sitting here ready to go and wondering...
1971 Chianti Red Westfalia x2
1985 Westfalia
1984 tintop
earlybayjim
PostPosted: Mon Mar 18, 2019 3:14 pm    Post subject: Re: 1970 bus trailer hitch install Reply with quote
I finally got around to fitting your trailer hitch with the VS exhaust! It fits great! Great job.
1985 Westfalia
1984 tintop
MonkeySee
MonkeySee is offline
PostPosted: Tue Mar 19, 2019 8:20 am    Post subject: Re: 1970 bus trailer hitch install Reply with quote
Anyone know the turnaround time on an order?
earlybayjim
PostPosted: Wed May 08, 2019 5:09 am    Post subject: Re: 1970 bus trailer hitch install Reply with quote
Here is one of Jeremy's early bay hitches doing some work!
1985 Westfalia
1984 tintop
MonkeySee
PostPosted: Sat May 11, 2019 1:00 pm    Post subject: Re: 1970 bus trailer hitch install Reply with quote
What motor are you running to pull that trailer?
earlybayjim
PostPosted: Tue May 21, 2019 6:12 am    Post subject: Re: 1970 bus trailer hitch install Reply with quote
1776 with dual 40hpmx carbs.
1985 Westfalia
1984 tintop
Lionhart94010
Lionhart94010 is offline
PostPosted: Fri Jul 19, 2024 12:30 am    Post subject: Re: 1970 bus trailer hitch install Reply with quote
Would you happen to have a through the bumper 68 to 71 Bay model picture?
And do you know if that puts the hitch too high?
I have an extra bumper that is a bit reinforced as well that I could use and Keep the original should ever need to change back to stock🙂
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
CaptainHaddock
CaptainHaddock is offline
PostPosted: Fri May 16, 2025 9:52 pm    Post subject: Re: 1970 bus trailer hitch install Reply with quote
I Received the Hitch from Jeremy a few weeks ago, finally had a chance to install it on my ‘71 with VS exhaust. It was a 2 beer difficulty level-The hardest part was scraping off the 50 year old factory rustproofing (I put some POR15 on too) then cleaning it out of the bolt holes and tapping them. The hitch fits perfectly and is very sturdy and well finished. I have an 8’ utility trailer I occasionally pull, and was hoping to carry a small dirt bike on the back.
Thanks Jeremy for a great product and follow up.
Billions of Bilious Blue Blistering Barnacles!
Last edited by CaptainHaddock on Mon May 19, 2025 8:58 am; edited 2 times in total
richparker
richparker is offline
PostPosted: Sun May 18, 2025 6:45 am    Post subject: Re: 1970 bus trailer hitch install Reply with quote
^You might want to think about re-indexing your rear spring plates to carry that bike.
I’m 6 years in with my hitch from Jermery. It’s been great, I use it all the time. My Thule bike rack pretty much lives on it and when it’s not I’m towing my 1973 Allstate trailer. It was an excellent purchase!
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
CaptainHaddock
PostPosted: Sun May 18, 2025 1:03 pm    Post subject: Re: 1970 bus trailer hitch install Reply with quote
I checked out a photo of your trailer Rich, pretty cool. It would only be very occasionally putting the bike on the back, so if I re-indexed the spring plates how would that affect the ride without the bike the rest of the time?
SGKent Premium Member
SGKent is offline
PostPosted: Sun May 18, 2025 1:13 pm    Post subject: Re: 1970 bus trailer hitch install Reply with quote
adding to what Rich already said, the rear shocks are held on by captive nuts that are welded into weak steel. They are near impossible to repair if they rip out. You do not want the rear shocks either bottoming or topping out in any situation, and you do not want any form of shocks or helper springs in the rear that increase the load on that captive nut. Most likely you will need to play with the rear torsion bar tension to find a happy medium.
I pulled a 2000 lb boat with my 1971. Not much power on grades etc., but it was possible. Even so that was only about 120 lbs tongue weight. I also pulled a small camping trailer than only put about 50 lbs tongue weight on the hitch. That motorcycle and carrier is a lot of weight hanging back there - the proverbial tail that wags the dog. You would be better off with a lite trailer for it where only the tongue weight was on the hitch.
George Carlin:
Skills@EuroCarsPlus:
CaptainHaddock
PostPosted: Mon May 19, 2025 8:48 am    Post subject: Re: 1970 bus trailer hitch install Reply with quote
Thanks for the input guys, I just installed new rear sachs/boge shocks a few months ago. I’ll try it around town and see how it feels. If not I have a good utility trailer and the bus has a 1776 set up.
I just removed the dirt bike carrier pic as it leading to mission creep on the thread. There are a few threads on the carrier already, I just wanted to show the hitch mounting. Cheers
Page 3 of 3
