Safaris discussion thread
Page: Previous  1, 2, 3 ... 40, 41, 42 ... 62, 63, 64  Next
emersonbiggins
emersonbiggins is offline
PostPosted: Wed Oct 30, 2013 9:03 pm    Post subject: Reply with quote
21-window wrote:
Anyone have any experience with the EIS safari's yet?
Thinking of getting some, but can't find much actual feedback on em yet.
Just looked at EIS website and they are out of stock. Just when I was thinking of buying a set.
Stocknazi
Stocknazi is offline
PostPosted: Mon Dec 02, 2013 6:18 pm    Post subject: Reply with quote
does anyone know when flat top dash tabs stopped being used?
WANTED:
Thomas Jefferson
campingbox Premium Member
campingbox is offline
PostPosted: Mon Dec 02, 2013 7:29 pm    Post subject: Reply with quote
Probably around the same time the vent wing tabs changed, sometime in 1957.
BulliBill
BulliBill is offline
PostPosted: Sat Dec 07, 2013 8:59 pm    Post subject: Reply with quote
Has anyone ever come up with the lineage/history of the slight variances in "one-eye-ducks" ? I have a couple here with different shapes in the "mouth" area to hold the wiper blades. Also in height. It may be here already, but I didn't turn up anything in my search.
Here you can see the height difference between the two I have here...
From the side you can see the differences in the mouth opening to hold the wiper blades.
The back-sides...
I just didn't want to duplicate it if the info is here somewhere already. Thanks!
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
nigel naughton
nigel naughton is offline
PostPosted: Wed Feb 12, 2014 12:09 am    Post subject: Reply with quote
Ok..I know it is only February but time to start thinking about summer..and summer = safaris.
So has anyone tried these yet?
they say they are 'new'!!
My windshield is cracked and I am thinking of finally just giving in and getting safaris.
http://www.eisparts.com/EIS-3040OE/Safari+Kit%2C+V...oated.html
thanks!
easy e
easy e is offline
PostPosted: Wed Feb 12, 2014 1:25 am    Post subject: Reply with quote
This has info on some various ducks:
http://www.thesamba.com/vw/forum/viewtopic.php?t=462315
aka: Evan
easy e
easy e is offline
PostPosted: Sat Mar 01, 2014 4:28 pm    Post subject: Reply with quote
I had bought some repro 55-64 pivots from a samba member & thought they were a little sloppy. In the video... see how the metal is thinner and how the repro sags when I start to depress the shaft. The reproductions I had were missing a stabilizing pin that keeps them operating tightly & wearing out prematurely due to sloppy fit.
See vertical pin & corresponding hole, down at the lower part.
aka: Evan
Pacmanfever
Pacmanfever is offline
PostPosted: Sat Mar 01, 2014 4:48 pm    Post subject: Reply with quote
thanks!
I bought a set but have not installed them yet. The only space in our garage is tied up with an engine teardown at the moment.
The quality looks great out of the box, I'll do a write-up when I install them.
nigel naughton
PostPosted: Sat Mar 01, 2014 10:46 pm    Post subject: Reply with quote
thanks!
Well get to it!!! Very Happy Very Happy
I look forward to your review of them but good to know visually they look high quality. Did they ship quickly or did you have to wait a while. I'll be stoked it they turn out to be nice.....thanks!
easy e
easy e is offline
PostPosted: Sun Mar 30, 2014 4:06 pm    Post subject: 55-64 safari pivots Reply with quote
I've got a 55-64 pivot with a tattered shaft.
I disassembled an NOS one to get dimensions to make a new shaft & wanted to share some info. (Edit to info below: the 4.95 mm is actually 0.1955")
Next three pics just show how things are a little eccentric.
Washer goes to the top of spring & is 0.035mm thick & is almost a snug fit.
Spring:
Free length = 11mm
Compressed length = 4.5mm
Spring constant = 37 lb/in
OD = 7.05mm
Wire dia. = 0.86mm
aka: Evan
schnidlee
schnidlee is offline
PostPosted: Tue Apr 01, 2014 3:33 am    Post subject: Reply with quote
I bought a set of those too. They are S$%t. I was told by the seller that they were OEM. I think the main issue is the "disengaging tab" is too high. If you compare the red arrow on the NOS one to the same spot on the repros you can see it is a smaller gap. This means it takes a greater distance to get to the point where the arm is being pushed out of the spindle. I'm going to try and drill out the spot welds and move the tab and see if that helps.
easy e
easy e is offline
PostPosted: Tue Apr 01, 2014 7:06 am    Post subject: Reply with quote
Ya, OEM... original equip. mat'l. True, it's brass/bronze & steel... still leaves plenty to be desired. Did you install & recognize an issue or just a bench top evaluation like me? I've yet to hear any feedback from installed aftermarket '55-'64 disengagers.
That lower gap is a fuzz too large on our repro disengagers. The problem is exacerbated by the loose tolerances at the pivoting arm center hole & shaft.
Might consider trying to take the roll pin out (just past the shaft & not all the way out) & putting thin bronze fender washer at the bottom of the gap you highlighted.... sandwich the bronze washer between the bracket & pivoting arm.
Could probably mock up a test with a piece of sheet metal with a shaft width slit cut out of it to test for effectiveness at taking out the slop prior to disassembly & trying to find that special washer (or thin section of a bronze round with the right size hole drilled in it).
aka: Evan
lumber-baron
lumber-baron is offline
PostPosted: Tue Apr 01, 2014 3:29 pm    Post subject: Reply with quote
I must have bought the last ones. I haven't installed them yet, just wanted to fit them prior to painting. Here's what I've seen so far:
1) I was told the color would match beige grey, it doesn't, but, it doesn't matter because the quality of the finish is piss poor, I would have had to repaint them anyway.
2) The fit isn't very good at all, they don't match the opening, I would say the run out about 1/4" diagonally.
3) The seals suck, they are bundled up and cinched ridiculously tight with a cable tie that has left creases in the rubber that haven't settled out after several weeks and they are about 2" too long.
4) The joint on the frames could fit a little better, but they tell me that these are the closest match to original safaris Rolling Eyes
nigel naughton
PostPosted: Tue Apr 01, 2014 8:34 pm    Post subject: Reply with quote
I know you just got them but your first impressions don't seem to hold much promise for these. That's unfortunate. I have been looking at these for some time now and was hoping they would get a good review...well there is still hoping right?
schnidlee
PostPosted: Tue Apr 01, 2014 8:55 pm    Post subject: Reply with quote
Thankfully i realised after a bench test too. The idea of adding a piece of sheet metal is probably the best way to go. I just re-inspected them and can see what you mean about the slop on the centre hole. Ill let you know if i find a good fix.
Matt
Shane6
Shane6 is offline
PostPosted: Mon Apr 14, 2014 4:28 pm    Post subject: Reply with quote
I've been running mine since christmas 2013. The first installation I couldn't get them to disengage without opening the doors, reaching one hand behind the dash and pulling the wiper out with the other hand. I've since removed them and bent the metal tab that releases the lever closer. Now one disengages pretty easily and the other it takes a little wiggling.
I would love to have a set of original ones after seeing the above video of how much better they are.
'63 Turkis beetle convertible '64 Turkis Caravelle camper '64 1500s sunroof Pearl Weis
Scotts 63 23
Location: Somewhere in my mind... The Real er Laguna Beach :)
Scotts 63 23 is offline
PostPosted: Mon Apr 14, 2014 7:55 pm    Post subject: Reply with quote
Scott's '63 23 wrote:
Just an update on my contact with CE. Mandy mailed me their epoxy to reattach the hinge but it never arrived. She feels it never made it through customs because of its liquid state.
I purchased 3M's Scotch-Weld 3501 Epoxy Adhesive (supposed to be the ultimate metal-to-metal epoxy) and made the repair. Back on the road.
LittleThunder wrote:
I reglued the hinges with the glue supplied to me by CE. I called them about the problem and the aircraft epoxy they use was at my door in 4 days. I glued them per the instructions and it's holding up nicely. He explained to me that they had one bad batch from a couple of years ago that didn't cure properly due to the cold weather over there in the winter. Since then they haven't had any failures. You're best bet would be to give Dave at CE a call and talk to him about your best option. Personally though, I don't have any problem with the glued hinges.
I moved this to the Safari thread after starting it in the Split Bus forum:
My CE safari hinge popped just like Little Thunder's. Contacted CE and they are sending me some of their epoxy to reattach. Thanks for everyone's help.
The photo below shows the hinge plate popped up off the frame:
Just a follow-up on this repair. I received a private message from someone asking me how this repair held up. I had forgotten all about the repair until this email came in. It's been 3 years and 4 months and it is perfect. Open them all the time and it's as strong as new.
When I made the repair, since the old epoxy could't be dissolved off, I removed most of it with a chisel, slowly and carefully. I then sanded it completely smooth before applying the epoxy. I also marked it precisely so that I could put it back together exactly as it was originally. Since I clamped it together after applying the epoxy, I wanted the marks to be seen on the outside of the clamp job, reassuring me that the pieces didn't move during the clamping.
'63 23 Daily Driver
www.scottmooreart.com
55samba
55samba is offline
PostPosted: Thu Apr 17, 2014 10:01 pm    Post subject: Reply with quote
OK my buddy brought over a set of EIS and early OG to compare and test fit.
I have personally owned and installed:
- Izzy
- Wolfgang
- NOS
Pros:
- Double channel
- We could interchange top and bottom frame with OG
- Laminated glass
- Frames appear good quality overall
Negatives:
- Hinges are mounted to high
- Hinges were not mounted even, this seems to be the fit issue
Note, they did fit but were way close on one bottom edge
- Powder coating appears low quality
- Glass was loose inside
- Hand grinding on frames is very apparent
Overall, fix the hinge and they are the best repo by far. Edit, never tried the aluminum ones since nobody seems to sell them in the states.
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Thu Apr 17, 2014 11:51 pm    Post subject: Reply with quote
The hinge position was placed half way between a early and a late set to make them more universal. They fit tighter on the bottom on an early bus. The seals were messed up by the manufacturer.
I have had to take the frames apart and give a little tweak to square them up.
I have installed 6 sets to date, the powder coated ones seem to vary. I have had perfect and marginal ones. The primered ones I take apart and glass bead blast them, epoxy prime then paint.
Overall a good product and I'm sure the next run will be even better, they are the closest to original.
"no more hacking my sig line"
cru62
cru62 is offline
PostPosted: Fri Apr 18, 2014 2:46 pm    Post subject: Reply with quote
WOW! Those are very nice. I don't think the average person will appreciate how difficult it is to form the raw frame material. It can take 2 dozen or more separate stations on a roll forming line to make even simple shapes. The fact that these will interchange with OG frames is huge. If EIS has their supplier address the issues mentioned above and get closer to the OG frame fit in the opening they will have a runaway hit.
I have only ever had one set of Wolfgang frames in my hands and never even tried to mount them. Of course, this was in the pre-OG latch days with the snap-off latches. I have since had 5 or 6 complete sets of OG safaris and never even entertained the thought of using WG or Izz's. I have helped others mount both of those windows in friends buses and always thought they were junk. These look like the new kid on the block is packin'!
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Page 41 of 64
