MrBreeze Samba Hitman
Joined: October 06, 2002 Posts: 5656 Location: Lawn Guyland, Noo Yawk
Posted: Sat Mar 18, 2006 8:29 pm Post subject: The Tire Sticky FAQ |
| Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=162278]The Tire Sticky FAQ[/url]
The Tire Sticky
Ok, it's all yours......debate, argue (be nice), and inform. Anyone asks about tires, send 'em here
Enjoy!
Original tire specifications from the 1969 Owner's Manual
Or
185R14 C-Rated.
185R14 = 185/82/14 _________________ -=Rob
WTB: Bay Shore or Queensboro VW Frames
HBB 1984-2009
RW 1943-2011
ER 1964-2023 |
steponmebbbboom Samba Member
Posted: Sat Mar 18, 2006 8:44 pm Post subject: |
Continental CR21 185r14 reinforced
Thread done, lock er down.  |
Posted: Sat Mar 18, 2006 8:46 pm Post subject: |
| steponmebbbboom wrote: |
Somehow I don't think it's gonna be that easy  _________________ -=Rob
HBB 1984-2009
RW 1943-2011
ER 1964-2023 |
SoSlo Samba Member
Joined: March 18, 2004 Posts: 10 Location: Spokane WA
Posted: Sat Mar 18, 2006 9:03 pm Post subject: The Tire Sticky |
another option:
Hankook RA08 185R14 8 ply...I love mine.
let the debate...continue! _________________ Tom
'70 Westfalia "Hergie" |
Randy in Maine Samba Member
Posted: Sat Mar 18, 2006 9:19 pm Post subject: |
Good one! Thanks! _________________ -=Rob
HBB 1984-2009
RW 1943-2011
ER 1964-2023 |
Desertbusman Samba Member
Posted: Sun Mar 19, 2006 2:25 am Post subject: |
Didn't VWBusrepairman say:
I run passenger car tires on my bus with no problems..... could the tire shops get away with selling me these tires for my VW Bus?_________________________________________________________________________
Of course. Always trust all of the tire shops. They might be like all the other wonderful retail stores. They probably are unquestionably ethical, moral, highest technically oriented, and only care about the clients welfare and not at all about the evening dollar tally. And they most definately are Bus experts. And they always use the torque wrench. And just for fun, ask the wrench guy what the setting is.
Or, you could go by the tire requirements, the tire ratings and all that.
P.S. Undoubtably, there are some shops that are great and above board. _________________ 71 Superbug
71 Westy |
jberger Samba Member
Posted: Mon Mar 20, 2006 2:08 pm Post subject: |
| Quote: |
There are plenty of passenger tires that meet the load requirement needed for our busses. |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Mon Mar 20, 2006 7:21 pm Post subject: |
| jberger wrote: |
| Quote: |
Time for show and tell!
SHOW me a passenger tire in the CORRECT 185R14 size that has a max load weight rating of 1540 lbs. minmum!
The CORRECT 185R14 tire is either a reinforced sidewall OR a 185R14C. The C means Commercial.
ANY PASSENGER tire you put on a bus MUST have the max load weight divided by 110%. THAT is FEDERAL LAW!!!!
S4.2.2.2 below. And then you need to read S4.2.2.3(a) after that.
http://a257.g.akamaitech.net/7/257/2422/05dec20031...71.110.htm
S4.2.1 Tire load limits for passenger cars.
S4.2.1.1 The vehicle maximum load on the tire shall not be greater
than the applicable maximum load rating as marked on the sidewall of the
tire.
S4.2.1.2 The vehicle normal load on the tire shall not be greater
than 94 percent of the load rating at the vehicle manufacturer's
recommended cold inflation pressure for that tire.
S4.2.2 Tire load limits for multipurpose passenger vehicles, trucks,
buses, and trailers.
S4.2.2.1 Except as provided in S4.2.2.2, the sum of the maximum load
ratings of the tires fitted to an axle shall not be less than the GAWR
of the axle system as specified on the vehicle's certification label
required by 49 CFR part 567. If the certification label shows more than
one GAWR for the axle system, the sum shall be not less than the GAWR
corresponding to the size designation of the tires fitted to the axle.
S4.2.2.2 When passenger car (P-metric) tires are installed on an
MPV, truck, bus, or trailer, each tire's load rating is reduced by
dividing it by 1.10 before determining, under S4.2.2.1, the sum of the
maximum load ratings of the tires fitted to an axle.
S4.2.2.3 (a) For vehicles equipped with P-metric tires, the vehicle
normal load on the tire shall be no greater than the value of 94 percent
of the derated load rating at the vehicle manufacturer's recommended
(b) For vehicles equipped with LT tires, the vehicle normal load on
the tire shall be no greater than 94 percent of the load rating at the
vehicle manufacturer's recommended cold inflation pressure for that
tire.
So you have your spiiffy Maypop brand of Pmetric passenger tires that are max rated on the sidewall of 1300 lbs. Already they are 240 lbs below minimum. Now divide that 1300 by 1.10.... bet you feel good at 1182 lbs.?? But wait..... you can only load that tire to a max of 94%.
WOW, that is now 1111 lbs. max weight you can put on that tire. Feel safe now??
If you can't dazzle them with brillance, then buffalo them with bullshit. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Tue Mar 21, 2006 1:05 am Post subject: |
| Karl wrote: |
Jeeze, Karl, a little strident are we? Dazzling caps and exclamations does not change the reality for many of us that we have enough experience to select appropriate tires for our cars. I use passenger car tires on my bus, they beat your 110%!!!! FEDERAL LAW!! and they are INCORRECT! (who cares?) 205-75-14s made by Michelin. I feel safe and I have done the math. Every other car in my driveway weighes more than my bus, and the GVWR of the bus exceeds the BMWs by only 70 lbs.
That said, it is the responsibility of a bus pilot to know how much his bus weighes at both axles, his tire ratings and current condition, and current inflation pressures. That is just common sense. I have seen some pathetic little beat up tires on buses and bring it to the attention of the owners. But I am not a jack-boot knee-jerk tire hysteric, I appreciate the fact that some of us here may have to get only what we can afford.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
Posted: Tue Mar 21, 2006 5:15 am Post subject: |
| In an emergency avoidance maneuver, what one can afford right now versus what one should have waited and saved up for can make the difference between life, and death. |
Karl Samba Member
Posted: Tue Mar 21, 2006 7:21 am Post subject: |
I am stating facts.
You guys can go out and buy whatever you can afford to put on your bus. You know you will. You don't give a damn as long as it is black, round, holds air, and are proud because you got a deal. I just don't want to be behind you people on the freeway because you guys are ignorant cheapskates.
I kept out of this sticky because of this.
The ONLY reason I said anything was because jberger wrote:
"There are plenty of passenger tires that meet the load requirement needed for our busses." Bullshit.
Line 'em up, jberger. Show and tell time.
And Colin, you can belly up to the bar too. Tell us what the specs are on your passenger car tires that you are so proud of. Ford and Firestone must love you guys. Their tire people were experts!!!
sailorkh Samba Member
Joined: March 29, 2004 Posts: 288 Location: Alameda, Ca
Posted: Tue Mar 21, 2006 8:32 am Post subject: |
| MrBreeze wrote: |
Somehow I don't think it's gonna be that easy  |
Ya think??
I am very happy with my Hankook RA 08's. The load rating and size is correct, and the price was right too. Only time will tell but when I am looking for tires again, they will be at the top of the list. _________________ Kris
1971 Deluxe
1978 Westfalia |
WileyVW Samba Member
Joined: November 02, 2004 Posts: 361 Location: Fort Lauderdale Florida
Posted: Tue Mar 21, 2006 8:50 am Post subject: 68 camper |
| I put these on mine and the highway handling is way better than the passenger tires that came with mine, also seems to ride better. MICHELIN AGILIS 81 185R 14C |
EdW Samba Member
Joined: January 13, 2005 Posts: 2385 Location: Unemployment Office
Posted: Tue Mar 21, 2006 9:43 am Post subject: |
| Karl wrote: |
I am stating facts.
C'mon Karl, you're just a buzzkill coming in here and polluting this place with FACTS.  _________________ 20‰
| Quote: |
| I would call him a dick, but a dick has a head on it |
Posted: Tue Mar 21, 2006 10:18 am Post subject: |
| Quote: |
I resemble that remark
How about the Cooper Weather Master 1521lbs per
78 Westy GVWR for the front is 2227 lbs. and the rear is 2800 lbs. So, "S4.2.2.3 (a) For vehicles equipped with P-metric tires, the vehicle
cold inflation pressure for that tire. " the 1521 more than meets the requirement. Check your facts before you call bull shit on me, looks to me that the spec is 94%, and the loads I am talking about are for a late model westy, aren't the passenger models sprung softly with lower GVWRs?
By the way, I run Yoko Y356D with a 1850lb rating. |
VWBusrepairman Samba Member
Posted: Tue Mar 21, 2006 11:32 am Post subject: |
| Desertbusman wrote: |
P.S. Undoubtably, there are some shops that are great and above board. |
not exactly, I said this:
| VWBusrepairman wrote: |
I run passenger car tires on my bus with no problems. I'm sure there are passenger cars which weigh comparable to that of the VW Bus otherwise, could the tire shops get away with selling me these tires for my VW Bus? Spend the money on the sound system. |
this was before I was aware that the bus needed light truck tires. I will continue to run these tires until it's time for a new set. It's not so critical now since the bus isn't driven daily any longer. It is just for fun now. glad this was finally made into a sticky so the others will be aware. |
Posted: Tue Mar 21, 2006 1:22 pm Post subject: |
Who ever started this thread opened up a can of worms. Just checked my tires and - Oh' crap. The PO had them put by the local good guys tire chain store. I doubt that they have 1,000 miles total, they look wonderful, but they are about 10 years old. This had been bugging me since a recent topic on the news has been tire old age. But they do look great. So, just checked the descriptions and -woops! P205/75 R14 with load rating 12 lbs. higher than the owners manual. But the max inflation pressure is considerably less than the owners manual. And side wall plys are less.
Early bay ('71) has different description (7.00 x 14) and ratings in the owners manual than you guys are mentioning. And then Bentley has requirements for 3 different Bay year groups and models.
So what I'm learning:
-I had been happy with my tires but not now, particularly since finally it's getting close to hitting the highway.
-The PO was as blind as I have been.
-The wonderful tire store isn't that wonderful.
-This reminds me why I've always liked a lowered ride and wide stance wheels. It tends to slide and not roll when things go wrong.
-Need more money! _________________ 71 Superbug
71 Westy |
MarkTime Samba Member
Joined: August 05, 2005 Posts: 94 Location: Austin, Texas
Posted: Tue Mar 21, 2006 6:42 pm Post subject: |
| Karl wrote: |
I am stating facts.
IMA Believer, Thanks! _________________ http://www.AdBirds.com
News: Brazil Ends Air Cooled Kombi Production
http://www.cbsnews.com/stories/2005/12/21/ap/business/mainD8EKS1901.shtml
