JBong Samba Member
Joined: February 24, 2012 Posts: 138 Location: Goodyear AZ
Posted: Thu Oct 03, 2013 11:30 pm Post subject: Do VW have stock adjustable Beams? |
I am not sure if I am going crazy or just plain ol be silly but I was looking under the VDub and noticed that I seem to have a adjustable beam. But I cant see any weld markings. Can someone please verify that this in fact is a adjustable beam.
Sorry this is not a very good photo and looks like I need to start cleaning up the poor girl under the front.
JBong Samba Member
Posted: Thu Oct 03, 2013 11:48 pm Post subject: |
| never mind, found out from a friend that they are Puma Beams. Now how do I lower this Dub... |
Dodgy Samba Member
Joined: January 30, 2006 Posts: 523 Location: Leicester, UK
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Fri Oct 04, 2013 4:26 am Post subject: |
| Don't forget to check alignment after it has been lowered. You may need to add a set of caster shims if you go to low. |
hectorotani Samba Member
Joined: February 05, 2013 Posts: 231 Location: san antonio texas
Posted: Fri Oct 04, 2013 5:05 am Post subject: |
my bug has those  |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3543 Location: Houston, TX
Posted: Fri Oct 04, 2013 9:24 am Post subject: |
You have a regular "Fuel line" type hose feeding your master cylinder brake fluid from the brake fluid container up top.
I would change those to the Blue hydraulic hoses that are made to stand up to that fluid.
Otherwise you will slowly get more and more black goo crap in your MC/ Brake lines. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Fri Oct 04, 2013 4:26 pm Post subject: |
| JBong wrote: |
Those are actually Avis adjusters which is what the Puma beams use.
They fit without cutting the beam. |
