nukeworker Samba Member
Joined: September 21, 2005 Posts: 490 Location: Area 51
Posted: Sun Apr 12, 2009 7:47 pm Post subject: Zenith Carb |
Hi. Just bought a Zenith 32 NDIX. I don't know squat about Zeniths except Jeff Hibbard says they're great. I'm looking for information/help. Anyone know web sites, books, anything where I can learn from. I've done some internet searching and all I can find is a couple of places that refurbish them. I want to know how to install, adjust, etc. Thanks. |
QRP Samba Member
Joined: April 27, 2008 Posts: 1887 Location: NORTH HOLLYWOOD,CA
Posted: Sun Apr 12, 2009 7:53 pm Post subject: |
Hey nuke just give me a call I will PM you my # |
baja1967 Samba Member
Joined: August 28, 2005 Posts: 221 Location: Murrieta, California
Posted: Sun Apr 12, 2009 8:52 pm Post subject: |
Ditto. I'll help any way I can. Wouldn't run anything else!!!! |
thefladge Samba Member
Joined: July 25, 2005 Posts: 1294 Location: Anaheim, CA
Posted: Sun Apr 12, 2009 9:50 pm Post subject: |
Who still sells parts for the Zenith? _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
Posted: Sun Apr 12, 2009 9:55 pm Post subject: |
I just about always stumble on them. I have a bin of jets, linkages, and spare parts. I also have a complete carb for a spare. I get my rebuild kit from my local vw shop, Relic VW Parts. |
JonF Samba Member
Joined: December 16, 2005 Posts: 2030 Location: Oklahoma
Posted: Sun Apr 12, 2009 10:16 pm Post subject: |
i also have a zenith 32 ndix. i havent got around to putting it on the baja yet because i am unsure of how to tune it. so please tell guys any tips you might have on tuning them. _________________ 68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix |
Posted: Mon Apr 13, 2009 5:12 am Post subject: |
Thanks Guys. I will take you up on those pms after I install it. My was missing a return spring. Ordered a couple last night from some Porsche parts place. |
zancat Samba Member
Joined: July 30, 2008 Posts: 51 Location: Ramona, California USA
Posted: Mon Apr 13, 2009 6:35 am Post subject: |
I have a set of duals I am thinking about fixing up but had the same questions. How big of a motor would these work well with?
Zancat _________________ Desert-Craft inc.
www.desert-craft.com
Pro-Tools Dealer |
XxonValdez Samba Member
Joined: February 01, 2008 Posts: 264 Location: San Diego, CA
Posted: Mon Apr 13, 2009 8:45 am Post subject: |
I was curious too, I have three sets of venturis, 32-24's, 32-28's, and a set of 32-25's?? never heard of these anyone have any input? |
QRP Samba Member
Posted: Mon Apr 13, 2009 8:26 pm Post subject: |
Hey nuke I posted some pics of the brackets in the off road gallery. |
Posted: Mon Apr 13, 2009 8:36 pm Post subject: |
Nice. Thanks.  |
1970DARKNESS Samba Member
Joined: April 29, 2006 Posts: 59 Location: Placerville, CA
Posted: Mon Apr 13, 2009 9:32 pm Post subject: |
i run a zenith too i could not find anyone who had smaller jets for it so my friend and i soldered them shut and redrilled them a bit smaller. worked good for me but it is still a little rich but not bad. It had jets on it to feed a 2332cc and i have a 1600dp. A little overkill on fuel. |
Green bug Guy Samba Member
Joined: May 31, 2007 Posts: 538 Location: temecula, CA
Posted: Tue Apr 14, 2009 11:05 am Post subject: |
ayy diet danny P, alisa got one of them bad boys in compleat! manifold and all. thought id let you know so you can go swoop that thing up like all the other ones you find! |
Posted: Tue Apr 14, 2009 6:38 pm Post subject: |
I'll call her tomorrow...... |
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Tue Apr 14, 2009 7:31 pm Post subject: |
Make sure you have functional preheat for the manifold. Use an aluminium one if you can. They can be jetted for almost any size engine. Bigger engines give up top end. Mine is on a 2180 with a WEB VZ 30 style cam. The 356 registry has detailed rebuild instructions. |
Posted: Tue Apr 14, 2009 7:39 pm Post subject: |
Aluminum manifold? Do you know if the stock solex heater tubes would fit the zenith manifold? |
perrib Samba Member
Posted: Tue Apr 14, 2009 8:30 pm Post subject: |
They don't. |
perrib Samba Member
Posted: Tue Apr 14, 2009 8:52 pm Post subject: |
Aluminium intake
You might be able to adapt progressive weber preheat tubes.
Preheat I added to a Tri Mil. Made from 1/2 tube and pre heat block offs.
QRP Samba Member
Posted: Tue Apr 14, 2009 9:34 pm Post subject: |
nukeworker wrote: |
the only aluminum manifolds I have seen are the plenum type.
stick with the divided intake for a small motor like you'rs |
