Outfront/KEP adapter plate with a Small Car engine mount?
JoeVanagon
JoeVanagon is offline
PostPosted: Fri Sep 10, 2010 10:35 am    Post subject: Outfront/KEP adapter plate with a Small Car engine mount? Reply with quote
Hey all, does anybody know or has anybody done a conversion that uses a KEP or Outfront Motorsports adapter plate with a Small Car engine mount? Or does the Small Car mount only work with their bellhousing? Thanks!
Joe Vanagon
1990 Carat with EJ25 SOHC
Rhinoculips
Rhinoculips is offline
PostPosted: Fri Sep 10, 2010 10:40 am    Post subject: Reply with quote
it will work. Most likely you will have to move the moustache bar, that the mounts connect to, back about an inch or so. This is no big deal. That is what I did.
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
edgood1
edgood1 is offline
PostPosted: Fri Sep 10, 2010 10:43 am    Post subject: Reply with quote
I'm running an outfront adapter kit with the small car mount on my syncro. no problems at all.
1987 Syncro Westfalia powered by Subaru
'65 Westfalia
syncrodoka
syncrodoka is offline
The motor mount and the bellhousing/adapter plate are two different items and they don't work together. You will have to redrill where the factory engine hanger bolts to the frame with any of the options including the bellhousing.
JoeVanagon
PostPosted: Fri Sep 10, 2010 11:39 am    Post subject: Reply with quote
Thanks guys. I like the Small Car mount and oil pan but I don't plan on getting the bellhousing (not a big fan of hydraulic thowout bearings). I want to make sure the different combinations of components I'm looking at will work before I take the plunge.
Joe Vanagon
purplepeopleeater
purplepeopleeater is offline
PostPosted: Fri Sep 10, 2010 6:36 pm    Post subject: Reply with quote
Hmmm, I have a KEP plate with a small car mount.... Question
Last edited by purplepeopleeater on Sat Sep 11, 2010 7:20 am; edited 1 time in total
fatboypaul
fatboypaul is offline
PostPosted: Fri Sep 10, 2010 10:52 pm    Post subject: Reply with quote
I've run a KEP plate and SC mount for years..... 2.2....no problems.
bbaca75
bbaca75 is offline
PostPosted: Mon Jul 14, 2025 5:57 pm    Post subject: Re: Outfront/KEP adapter plate with a Small Car engine mount? Reply with quote
What exhaust/headers did you use to make this work on a syncro? Smallcar has the skid plate extension so I'm hoping to use that but not sure what kind of headers I need to make sure that works. I hear that you can even use the original splash guards with their kit? Is that right?
Current van:
'87 Westy full camper A/T
Old vans:
'87 Westy full camper (subaru 2.2l) M/T - SOLD
'86 Syncro high top camper M/T - SOLD
