40 IDF Unresponsive
HereToGo
HereToGo is offline
PostPosted: Fri May 27, 2016 2:40 pm    Post subject: 40 IDF Unresponsive Reply with quote
Need some expert advice regarding my 40 IDF setup. Engine is a 1904/100cam/stock size valves.
• Cylinder #1 is not responding to any mixture inputs
• Idle jets are all clear
• Idle circuits are clean and cleared out
• No vacuum leaks at either carb base or manifold
• Getting a constant popping out of the exhaust (no leaks at any joints)
• Swapping plugs and wires (1& 2) makes no difference
Carbs have been thoroughly disassembled and soaked with rebuilt gaskets all over.
Is there anything I might have overlooked?
Derek Cobb
Annoying
Derek Cobb is offline
PostPosted: Fri May 27, 2016 4:28 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
Leaky throttle shaft?
stan_tichomirov
stan_tichomirov is offline
PostPosted: Fri May 27, 2016 4:46 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
Choke plunger missing or stuck open?
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build
sled
sled is offline
PostPosted: Fri May 27, 2016 5:26 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
Stan
Yup, that's what it was on my 40 idfs.
If you flip the carb over you can see the enrichment circuit port, I drilled and tapped it and ran some allen set screws to stop any future leaking
drive your split.
HereToGo
HereToGo is offline
PostPosted: Fri May 27, 2016 6:01 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
Stan
I'll check on that, thanks.
HereToGo
HereToGo is offline
PostPosted: Fri Jun 03, 2016 11:43 am    Post subject: Re: 40 IDF Unresponsive Reply with quote
Stan
Update:
• Enrichment circuits are OK and closed
• Throttle shafts aren't bent or leaking
The carb is still not responding to mixture screws (open or closed) and pulling spark plug wires won't kill the cylinders.
Tried swapping carbs left to right and the problem followed the carb. Spits and sputters like it's lean (50 idle jets / 130 mains / 28 vents). If I pull spark plug wires on the 'good' carb, it kills the engine. There are no vacuum leaks.
Just thoroughly disassembled the carb and soaked it again and the idle circuits are still clean. It squirts fuel from both nozzles when opened.
The gasket at the top of the carb is good and not blocking the idle circuits.
Bottom line: one carb works, the other doesn't. Getting ready to put the single solex back on if I can't get this to work.
subhuman
subhuman is offline
PostPosted: Fri Jun 03, 2016 12:31 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
double check intake gasket at the head, chased a similar problem last year, turned out the gasket slid slightly when i put the intake on and had an air leak that did not show up when spraying starter fluid at it!
63 restomod build
http://s431.photobucket.com/albums/qq37/johnnysubhuman/?albumview=slideshow
you can have everything you want, just don't want so much!
"the wrong way always seems the more reasonable."
george moore
1963 type1
2002 Subaru Wrx
never argue with an idiot, they will only drag you down to their level and beat you with experience!
Mark Twain
stan_tichomirov
PostPosted: Fri Jun 03, 2016 12:54 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
How about o-rings on the idle jet holder and idle mixture screw?
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
HereToGo
HereToGo is offline
PostPosted: Fri Jun 03, 2016 2:16 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
Stan
Yep, they're present.
Doesn't matter at this point, the POS setup is coming off and the Slo-lex is going back on. I'm done fiddle-farting with these touchy carbs.
madmike
madmike is offline
PostPosted: Sat Jun 04, 2016 2:57 am    Post subject: Re: 40 IDF Unresponsive Reply with quote
you have a plugged idle circuit,, compressed air will clear it
not a piddly little can of carb clearner,, Rolling Eyes take it to,,, o never mind you want a stock POS carb,, that will give u piss poor mileage & performance Rolling Eyes
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
HereToGo
HereToGo is offline
PostPosted: Sat Jun 04, 2016 7:54 am    Post subject: Re: 40 IDF Unresponsive Reply with quote
I have blown compressed air through them after soaking them (5hp compressor) and can feel air moving through all of the passages, top and bottom.
Running out of options. I have worked with Kadrons, FRD's and 42 DCNF's, so this isn't my first rodeo with duals.
Open to other suggestions.
[email protected]
john@aircooled.net is offline
PostPosted: Sat Jun 04, 2016 8:09 am    Post subject: Re: 40 IDF Unresponsive Reply with quote
there are 2 circuits in the idle, the fuel circuit and the air circuit. You must make sure both are clear.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
chrisflstf
chrisflstf is offline
PostPosted: Sat Jun 04, 2016 8:31 am    Post subject: Re: 40 IDF Unresponsive Reply with quote
I would examine the idle jets under magnification. I had some that I repeatedly concluded were clean. If you looked at the hole, it was not round due to crap buildup that chemicals/compressed air would not remove. It took a fine wire brush to remove the deposit. Problem gone. You could swap idle jets from carb to carb as a test also
udidwht
udidwht is offline
PostPosted: Tue Jun 07, 2016 12:00 am    Post subject: Re: 40 IDF Unresponsive Reply with quote
Time for a leak down test.
But prior to that re check all the valves lash adjustment. Then recheck the mixture screw/s at idle.
You could also swap the carbs from side to side and see if the issue moves.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
HereToGo
HereToGo is offline
PostPosted: Mon Jun 27, 2016 1:19 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
Found the problem and fixed it.
One of the four mixture screws was the wrong type (see illustration). After ordering the correct one, it runs properly now.
Bought the carbs used, so lesson learned, don't take anything for granted.
sled
sled is offline
PostPosted: Mon Jun 27, 2016 5:06 pm    Post subject: Re: 40 IDF Unresponsive Reply with quote
excellent resolution.
now are you happy you kept at it, and didn't regress to a stock carb?
that engine should run awesome with some 28 or 30 vents and proper jetting.
drive your split.
