jwsnlutz Samba Member
Posted: Mon Mar 06, 2023 7:14 pm Post subject: short shifter needed |
79 bay window bus, have heard good feedback from short shifter installations
looking to replace stock shifter, any recommendations from satisfied customers,
would something like this be a wise buy? -->.EMPI Hurst Style Gear Shifter: Baywindow 1968-1979 --> from heritage parts
Thank You |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42370 Location: at the beach
Posted: Mon Mar 06, 2023 7:25 pm Post subject: Re: short shifter needed |
been driving stick shifts much of my life. Usually when a bay shifter feels sloppy it is not solved with a short shifter. Once all the other issues are sorted out and fixed, the one most people who want one get is the Berg model. http://www.geneberg.com/product_info.php?cPath=17_476&products_id=1194 _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
richparker Samba Member
Joined: November 24, 2011 Posts: 7489 Location: Durango, CO
Posted: Mon Mar 06, 2023 7:42 pm Post subject: Re: short shifter needed |
Kent is right, you should replace the shift coupler and the rod bushing first.
If you’re still dying for a short shifter after that I’d recommend one from Vintage Speed. They have 3 different models for your year bus. Here’s one of them.
https://store.vintagespeed.com.tw/BLACK-23-RHD-68-...p132902447
I can’t remember the reason, but I was told by my builder that a bay window transaxle will Not like a short shifter for any extended period of time. Unlike a bug transaxle, which has no issues with a short shifter. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Mon Mar 06, 2023 7:50 pm Post subject: Re: short shifter needed |
Thanks for info, I dont have any problem shifting, just that the short shifter makes it much easier, from what I am told, I have seen many bay windows with them, I have heard it cuts down the shifting manuvers by 40% . Hoping to make sure it is better as they say! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17615 Location: San Diego, California
Posted: Mon Mar 06, 2023 8:45 pm Post subject: Re: short shifter needed |
Empi parts are generally thought of as inferior. Berg on the other hand is generally thought of as top notch. I have no experience with vintage speed.
My 1971 bus has a Berg. I’ve installed several Berg shifters and everyone likes them. The directions Berg sends tells you that in order for their shifter to work well, the rest of your linkage needs to be in good order. In other words… it’s not to be used to solve poor shifting issues.
Berg offers several variations of the bus shifter, for instance
T handle
Ball handle
Black
Chrome
Locking base (locks you into reverse)
Inscribed with Berg
The price can start around $300 and climb up to about $600. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent  Samba Member
Posted: Mon Mar 06, 2023 10:33 pm Post subject: Re: short shifter needed |
grab the shifter 2/3 to half way down, the throws will be real short. See if you like it. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Xevin  Samba Member
Posted: Tue Mar 07, 2023 2:37 am Post subject: Re: short shifter needed |
I run an EMPI short shifter in my bug. I like it. I use stock shifters in the buses.
Read this link and then do what you are comfortable with.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...8d1d6e3130 _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin...  |
skills@eurocarsplus wrote: |
SGKent wrote: |
riverart Samba Member
Joined: September 20, 2017 Posts: 55 Location: Pomona
Posted: Tue Mar 07, 2023 10:08 am Post subject: Re: short shifter needed |
I just replaced my stock shifter for my 1971 Deluxe project. I ended up buying a Vintage Speed shifter from a local vendor. I had a VS shifter in my 1967 bug and wasn't too thrilled about it...it felt very metallic and the shift pattern didn't feel very defined. But I also think the shifter bushing was toast in the tunnel.
My new shifter feels solid, and I am happy I went with it. Unfortunately, can't tell you how it drives as my engine is being built. In terms of new VS shifter vs old, night and day difference. The stock one was simply too loose and sloppy. I did change bushing in the front. After I switched to VS, much better, tighter feel. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3300 Location: Hamble, Hampshire, UK
Posted: Tue Mar 07, 2023 10:21 am Post subject: Re: short shifter needed |
I have driven with an EMPI shifter for the last 13 years because that was what was fitted in my bus by a PO, I think in 2005.
It has broken once and worn out once in that time, needing skill to keep it going - reverse lockout plate fell off, needed welding because spot welds broke, shifter plate (integral with shifter) needed a strip of metal welded on one side because the shifter plate wore about 1/32" each side.
Really, if you have a well setup stock system with a CSP shift coupler and the front shifter bushing in good condition, and a non-worn ball on the hockey stick in the gearbox nosecone, it will be just as good.
The EMPI shifter still hits the handbrake handle when the rear brake drums need adjustment. _________________ Ancient vehicles and vessels
mikewire  Samba Member
Joined: March 22, 2010 Posts: 835 Location: San Antonio, TX
SGKent  Samba Member
Posted: Tue Mar 07, 2023 11:36 am Post subject: Re: short shifter needed |
These are common problem areas in the shift mechanism that have to be dealt with before changing the shifter.
worn or missing front bushing
broken stop plate
Loose grub screws
worn out / bad coupler
Worn hockey stick
Worn ball inside nosecone
Broken or cracked selector bracket in nosecone
Worn nosecone that lets 4th gear pop out _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
