Valve clearance?
Mr.Duncan
Mr.Duncan is offline
PostPosted: Thu Dec 26, 2013 7:36 am    Post subject: Valve clearance? Reply with quote
I just noticed in my owners manual that it says set the valve clearance (all valves) to .004"
Why has everyone recommended doing .006"?
Should I switch to maybe doing a .005" ?
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
johnnypan
johnnypan is offline
PostPosted: Thu Dec 26, 2013 8:59 am    Post subject: Reply with quote
Use the 'go-no go" to achieve a dead on .006..if a .005 slides in (go) but a .007 doesn't (no go) then you are exactly .006..
IMO don't set .004,these engines close valve gap with wear..an exact .006 is as tight as I would go.
ashman40
ashman40 is offline
PostPosted: Thu Dec 26, 2013 9:35 am    Post subject: Reply with quote
If you are accurate and diligent, you can use 0.004" for your valve gap. This as the published standard in the late '60s. The maintenance calls for checking and setting valve gap at each oil change (3months/3000mi).
Most people failed to check THAT often and the valve adjustment went too long between checks. The valve gap would drop to zero and the valves would not fully close. Since the primary way valves release their heat is through the valve seats the valves would overheat and burn/crack. All because the owners failed to maintain the proper valve gap. VW changed the spec to 0.006" which allows more time between valve adjustments and fewer burned valves.
(at least this is the story I heard).
BTW, this is one of the reasons most car makers switched to hydraulic lifters instead of solid lifters. Hydraulic lifters are basically self adjusting.
AshMan40
Mr.Duncan
PostPosted: Thu Dec 26, 2013 9:40 am    Post subject: Reply with quote
I check/adjust mine every 2k miles
1966 Ghia (sold)
1966 Red Beetle
andk5591
andk5591 is offline
PostPosted: Thu Dec 26, 2013 10:35 am    Post subject: Reply with quote
This is all assuming you have stock pushrods and not chromoly........Those get set to loose 0.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
Mr.Duncan
PostPosted: Thu Dec 26, 2013 10:53 am    Post subject: Reply with quote
yes stock.
1966 Ghia (sold)
1966 Red Beetle
gt1953
gt1953 is offline
PostPosted: Thu Dec 26, 2013 2:10 pm    Post subject: Reply with quote
If everything is stock on the engine the do set the Valves to .006. Like described above. .005 fits and .007 does not its OK.
72 type 1
72 Squareback
Mr.Duncan
PostPosted: Thu Dec 26, 2013 2:14 pm    Post subject: Reply with quote
cool.
Just understanding:
.005 Slides in SUPER EASY (yet falls out if I let go of the feeler gauge set)
.006 slides in slightly firm (yet hangs & does not fall if i let go of the set)
.007 Does not go in AT ALL (even with firm pressure will not slide in)
1966 Ghia (sold)
1966 Red Beetle
Glenn73
Glenn73 is offline
PostPosted: Thu Dec 26, 2013 2:23 pm    Post subject: Reply with quote
Also keep a log of when and what they measured at before and after each adjustment.
If you have one that keeps closing up then you have a stretching valve or pounded seat. Two that get loose on opposite sides of the motor, bad cam or lifters.
1973 Super Sat from 93-2008
1986 Vanagon thread Sat from 2005-2017 https://www.thesamba.com/vw/forum/viewtopic.php?t=719692
VW Transporter production film https://www.youtube.com/watch?v=rceTqDtGgz8
Tim Donahoe
Tim Donahoe is offline
PostPosted: Thu Dec 26, 2013 3:29 pm    Post subject: Reply with quote
Seems like the .004 gap was for older engines where the gap actually increased as the engine warmed up to .006. Seems weird to me, though.
I've always set my valves to .006.
Tim
drs1023
drs1023 is offline
PostPosted: Thu Dec 26, 2013 7:03 pm    Post subject: Reply with quote
Huh? Haven't heard that one. As engine heats up, the valve lash will close up due to metal expanding when heated. Back in the late 70's, I had a service booklet (not Bentley's or Muir) which called for .004" exhaust and .008" on the exhaust.
gt1953
gt1953 is offline
PostPosted: Thu Dec 26, 2013 7:28 pm    Post subject: Reply with quote
Mr.Duncan
I like your description the feeling of the feeler gauge. That's about how I have done it.
72 type 1
72 Squareback
flyboat
flyboat is offline
PostPosted: Thu Dec 26, 2013 7:37 pm    Post subject: Reply with quote
If you hang around your engine long enough, you'll find that .005 or even .004 will work best on your engine. There is a good amount of variances in these engines. Depending on how yours is set up, the lash could vary .001.002 for best performance. I would look at .004 for intake and maybe just a touch more for exhaust.. Again, the more you do it the more you learn what your engine likes.
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car
wayne1230cars
wayne1230cars is offline
PostPosted: Thu Dec 26, 2013 8:15 pm    Post subject: Reply with quote
The 1958-1960 Bentley manual specifically states that valve clearance increases as the 36 hp engine warms up. I was really puzzled by this claim but I have tested it and found it to be true especially for the exhaust valves.
This of course is not true for the newer engines where valve clearance decreases as engine warms up. I have heard the suggestion that this was because of the different style of push rod that 36 hp's had with a wooden interior core?? Not sure.
The Bentley manual even gives a different valve clearance for when the 36 hp engine is not stone cold to compensate for the increasing clearance. With a cold engine, suggested clearance was .004. I have tried both the .004 and .006 adjustments on my 36 hp and really can't really feel much of a difference, perhaps a little noisier with .006.
The .006 clearance with engine stone cold is good advice.
1960 beetle
1970 beetle convertible
wayne1230cars
PostPosted: Thu Dec 26, 2013 8:24 pm    Post subject: Reply with quote
Even the owner's manual for 36 hp equipped cars stated that "valve clearance increases as engine warms up. ( 4th paragraph under 'Valve adjustment')
1960 beetle
drs1023
drs1023 is offline
PostPosted: Fri Dec 27, 2013 5:29 am    Post subject: Reply with quote
I have only actually seen two 36 HP engines in my life, and I didn't work on either. Thanks for your correction.
Juanito84
Juanito84 is offline
PostPosted: Fri Dec 27, 2013 9:45 pm    Post subject: Reply with quote
My 1971 manual states .004" for both intake and exhaust. I have a Haynes manual that says VW changed their tolerances for all previous .004" lashes to .006".
If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine?
AirDirect
AirDirect is offline
PostPosted: Fri Dec 27, 2013 10:54 pm    Post subject: Valve clearance Reply with quote
Noah's owners manual for the 1972 Std Beetle has a pasted in supplement that changes it from .004 to .006 on both intake and exhaust valves.
It also has a sticker on the doghouse just behind the A/C compressor that shows valve clearance of .006 .
https://www.thesamba.com/vw/gallery/pix/1103641.jpg
Aussiebug
Aussiebug is offline
PostPosted: Fri Dec 27, 2013 11:54 pm    Post subject: Reply with quote
Most people failed to check THAT often and the valve adjustment went too long between checks. VW changed the spec to 0.006" which allows more time between valve adjustments and fewer burned valves.
Ashman is exactly right.
If you check your valve clearances regularly, then you can safely use .004 on most aircooled VW engines.
The standard setting was changed to .006 to allow for some slackness in maintenance.
I have always used .004 on all my engines (1200 40hp, 1500sp and 1600 twin port), checking them every 3000 miles, and have never had any valve issues. The engines run a bit quieter with the .004 setting.
Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com
goober
goober is offline
PostPosted: Sat Dec 28, 2013 6:14 am    Post subject: Reply with quote
I like to set mine to the loose side. With the cylinder at TDC on compression, I place a .006" feeler gauge between the adjusting screw and valve stem. I rock the rocker arm back and forth and adjust until I feel no more play. This makes for a free-feeling .006". I may leave the exhausts with even a slight amount more play in summer. I adjust my valves every 6000 miles, sometimes more. For the life of the engine, I've never had to add clearance, only had to take up clearance.
This may create a little more wear on the valve train although the screw tips still have a nice radius (I use OEM harden screws). I've always felt that when I didn't hear the valves clacking away I would be in trouble. I'd trade a little noise and wear for a sucked valve any day.
