extending the leads of my timing light
noslencb
noslencb is offline
PostPosted: Tue Apr 01, 2014 1:04 pm    Post subject: extending the leads of my timing light Reply with quote
I am getting ready to check timing on the new engine I just installed in my 88 vanagon. I have a Innova model 5568 timing light. The wire leads are too short to reach from the battery to the engine. Is there any reason I cant add wire of the same AWG to the leads? Is the light somehow calibrated with the lead length it has? If extending the leads will screw up the reading on the timing light, what are my options? thanks for any help
Brian
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Apr 01, 2014 1:08 pm    Post subject: Reply with quote
You should be able to get 12v+ on the B+ terminal of the alternator. The negative cable to and ground and the spark plug probe to #1.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Apr 01, 2014 1:33 pm    Post subject: Reply with quote
Or hook it up using your jumper cables or to another car's battery.
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Apr 01, 2014 3:18 pm    Post subject: Reply with quote
In case that isn't obvious -- the terminal on the alternator for 12VDC+ is the big one (possibly has a rubber boot over it).
'Any ground' is almost any bare metal -- I usually use the body of the alternator or the bolt that attaches it.
#1 cylinder is the one on the passenger side and towards the front of the van.
Maybe you know all this, just wanted it to be clear.
nemobuscaptain
nemobuscaptain is offline
PostPosted: Tue Apr 01, 2014 4:34 pm    Post subject: Re: extending the leads of my timing light Reply with quote
No there is no reason not to do it and a few premade jumper wires is a great thing to have in the bus anyway.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
bluebus86
Banned
bluebus86 is offline
PostPosted: Tue Apr 01, 2014 5:07 pm    Post subject: Reply with quote
They tell me timing is everything, the timing light is not sensitive to cable length so long as there is enough juice to run the light with out a huge voltage drop. Same gage wire to battery should be fine. or use the alternate engine bay places to tap off the voltage using the stock lamp leads, that's what I do.
Nuthin2It
Nuthin2It is offline
PostPosted: Tue Apr 01, 2014 5:13 pm    Post subject: Reply with quote
I inherited a "Jump-N-Carry" jump starter from my brother-in-law. I never travel with it because it takes up too much room and it's heavy. But I've discovered that it's real handy to have in the garage. I use it for my timing light. It has a cigarette lighter socket in it, so I use it for my tire inflater. I attached two wires with alligator clips on the ends to a cigarette lighter plug and use it as a 12V source for testing electrical components.
1985 Westfalia 15 degree EA288 Boxeer
noslencb
noslencb is offline
PostPosted: Wed Apr 02, 2014 8:13 am    Post subject: Reply with quote
Thanks for all of the info! I think I will just hook up to the alternator and ground. Then I think I can also see the voltage off of the alternator on the timing light.
Another question is dwell? My timing light can read dwell and and its owners manual says to hook to the negative (tach) side of the ignition coil. From what I understand, the digifant doesnt have a way to adjust dwell so do I need to even bother checking this?
bluebus86
Banned
PostPosted: Wed Apr 02, 2014 8:36 am    Post subject: Reply with quote
you can check the dwell but it is not adjustable on the digifant. I have heard that there are failures of the dwell control in the ecu. Never had one fail on me however.
