KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Thu Jun 29, 2017 1:17 pm Post subject: Maybe a dumb T34 question - engine bay size |
Looking at this picture of an original, early T34, I am intrigued by the engine bay sheet metal. On other Type 3 cars, the engine bay is very open to the elements. This photo makes it look more like the sealed engine bay design of the Type 1 and 2.
Furthermore, the sheet metal on my '71 seems odd for a non-sealed bay, especially the front tin, which is pretty useless and adds a certain PITA factor the engine R&R. The curve does not match the engine bay.
Here is a gallery photo, non-stock in some respects but it shoes how open-air the T3 bay is:
So my question is, are the T34 engine bays pretty well sealed?
Erik G Samba Member
Joined: October 16, 2002 Posts: 13546 Location: Tejas!
Erik G Samba Member
KTPhil  Samba Member
Posted: Thu Jun 29, 2017 2:14 pm Post subject: Re: Maybe a dumb T34 question |
Does the front tin fit the body better on those early cars? There is like an inch gap on late models, which makes it pretty useless. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Thu Jun 29, 2017 2:38 pm Post subject: Re: Maybe a dumb T34 question |
I've always assumed they kept the front tin as a handy place to anchor the fuel lines and accelerator cable, and for mounting the fuel pressure regulator on injected cars. You're correct in that it really doesn't seal the airflow in any way. _________________ 71 Elm Green FI A/T Squareback |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4619 Location: Pasadena CA/DTLA soon China
Posted: Thu Jun 29, 2017 3:20 pm Post subject: Re: Maybe a dumb T34 question |
Not a dumb question at all, I asked the same thing when I got my '63 type 34.
https://www.thesamba.com/vw/forum/viewtopic.php?t=594736&highlight= _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23375 Location: Kimball, Mi
Posted: Fri Jun 30, 2017 10:10 am Post subject: Re: Maybe a dumb T34 question |
Donnie strickland wrote: |
I've always assumed they kept the front tin as a handy place to anchor the fuel lines and accelerator cable, and for mounting the fuel pressure regulator on injected cars. You're correct in that it really doesn't seal the airflow in any way. |
I think that tin is a modified bug piece, although it has a 311 part number. I know I modified a bug one when I was building my blue Square years ago. It wasn't hard to do either, just 3 cuts and a bend, then weld in 2 side flaps to close the sides. VW did it all as a stamping though. That was for the oil cooler outlet air.
If you think about it, Donnie nailed all but that one when he listed what it does.
You should try a bus front tin, if you want to block off the opening at the front. They sit a full 1.5 inches taller, and close off a lot more. But... it's not made for a t-1 based engine. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4507 Location: Illinois
Posted: Fri Jun 30, 2017 11:51 am Post subject: Re: Maybe a dumb T34 question |
The stock front tin on my 64 fit very well against the body. I don't have any pics of it though. |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
