ToughBug Samba Member
Joined: July 22, 2014 Posts: 354 Location: Carlisle, Pennsylvania
Posted: Sat Jan 13, 2018 10:33 am Post subject: Back seat in, no start. Out, all good. Funny. |
Had a good time driving around today. Thought I'd put the rear seat in. I've had it out so I can watch the shift rod working.
Funny thing. The car wouldn't start. Not even turn over. I guess I've been at this a little while now because I sorta knew to take the seat out, or just lift it up a bit.
Then all was good. (I looked like a total genius too)
I'm clearly shorting something. I'll check the battery terminal cover. Or maybe it is somewhere else.....?
Anyone else have this happen?
Tom _________________ 1973 chassis + 1974 body = super beetle saved |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Jan 13, 2018 10:58 am Post subject: Re: Back seat in, no start. Out, all good. Funny. |
Check to see if you have a hard start relay with a wire that the seat has somehow messed with. There may also be a wire running over the tunnel near the seat rail that holds the seat in. Check that, too.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
vamram Samba Member
Posted: Sat Jan 13, 2018 11:38 am Post subject: Re: Back seat in, no start. Out, all good. Funny. |
Post a pic of the rear section without the seat so that we can see the battery and wiring. May be to help u diagnose it better with a visual. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6623 Location: Houston, Texas
Posted: Sat Jan 13, 2018 1:17 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
Make sure your seat bottom isn't touching your battery top and shorting it. _________________ www.vwnos.com [email protected]
Cusser Samba Member
Joined: October 02, 2006 Posts: 31390 Location: Hot Arizona
Posted: Sat Jan 13, 2018 2:30 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
kawfee wrote: |
Make sure your seat bottom isn't touching your battery top and shorting it. |
Absolutely !!! A short there would cause 3 Zillion electrons to pass through directly to ground, likely would cause a fire. VW batteries have an insulator over the positive terminal for just this reason, better than a pizza box or piece of wood. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
alex857 Samba Member
Joined: December 26, 2010 Posts: 714 Location: Stuttgart/Germany
Posted: Sat Jan 13, 2018 3:18 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
There is a white plastic cable connector in the well under the back seat on the driver´s side. It connects rhe starter. Check if that came loose. |
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Mon Jan 15, 2018 4:10 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
Not to mention all that old sisal/seat padding is perfect dry kindling! |
allenw Samba Member
Joined: September 20, 2016 Posts: 221 Location: Dalton, GA
Posted: Mon Jan 15, 2018 4:43 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
I ride without my backseat bottom installed as I am the only one in the car all the time. I have been looking at the local pick and pull for a positive terminal cover that will work. |
miller0358 Samba Member
Joined: November 07, 2007 Posts: 1200 Location: northford,ct
Posted: Mon Jan 15, 2018 4:48 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
I put a rubber mat over the battery then the seat. Jeff |
Cusser Samba Member
Posted: Mon Jan 15, 2018 6:23 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
miller0358 wrote: |
I've used a heavy plastic bag and a pizza box ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Jan 16, 2018 1:10 am Post subject: Re: Back seat in, no start. Out, all good. Funny. |
What ever works. I like a little more protection than just the caps on the terminals. Especially when people sit in the back. Jeff |
bluebus86 Banned
Posted: Tue Jan 16, 2018 10:02 am Post subject: Re: Back seat in, no start. Out, all good. Funny. |
friends car caught fire becuase of no lid over the battery. Seat was a flaming wreck after fatso sat over the battery.
Get the correct stock vw cover over the battery. the cover is also an integral part of the battery tie down battery must be securely connected to car to prevent movement, and cover must protect the positive terminal.
good luck, Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
AlmostHeavenWV_VW Samba Member
Posted: Wed Jan 17, 2018 3:18 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
my 2cents on covering the battery/reducing fire risk & sparking hazards with rear seat
1 roll of rubberized kitchen drawer mat, some zip ties, and a lid from a storage container.
put rubber mat on top and bottom of lid
also got a battery box and cut it short enough to fit under the seat (prevent that dreaded battery tray cancer)
and got a neat stretchy velcro strap to hold the lid in place
Then just took lengths of the rubber mat and zip tied to the springs
_________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7032 Location: Clyde, TX
Posted: Wed Jan 17, 2018 4:08 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
ToughBug wrote: |
Tom |
So it's been four days, have you figured out what the problem was yet? _________________ 1960 Ragtop w/Semaphores "Inga" |
unclewede Samba Member
Posted: Mon Jan 22, 2018 11:43 am Post subject: Re: Back seat in, no start. Out, all good. Funny. |
There is a battery cover???? |
cloverskull Samba Member
Joined: April 08, 2014 Posts: 10 Location: San Francisco Bay
Posted: Mon Jan 22, 2018 12:49 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
Slightly OT, but I got the fiberglass battery box from JBugs (actually to prevent corrosion on the tray). Would this be enough to prevent a fire if a fat person sits on the seat above the battery? |
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Mon Jan 22, 2018 1:35 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
cloverskull wrote: |
Only if the positive post is covered. You don't want anything live to get touched as the metal springs can touch both battery posts with a heavy enough person.
I took care of this issue by getting some 1/4" hard board from Home Depot and made a cover to lay across the whole bottom. Gives the seat a bit of firmness and no risk of sparky sparky action. |
Posted: Mon Jan 22, 2018 3:34 pm Post subject: Re: Back seat in, no start. Out, all good. Funny. |
Chochobeef wrote: |
The hardibacker for tile? Does it fit flush or did you have to "modify" it in spaces? |
Posted: Tue Jan 23, 2018 7:01 am Post subject: Re: Back seat in, no start. Out, all good. Funny. |
Nope its just wood hard board. I had to cut a small notch out where a latch loop is, but other than that once the length and width are cut it sits on the cross bar.
Here is a link to the type of material. Looks like its 1/8th of an inch. |
Posted: Tue Jan 23, 2018 11:58 am Post subject: Re: Back seat in, no start. Out, all good. Funny. |
Chochobeef wrote: |
Not available in stores, and not online Maybe the chalkboard surface they have will work in it's place?
Lowe's has it in 4x8 sizes, and there are 50+ in my local store. Weekend project.
I told my son he couldn't have any back seat passengers until we get this done. |
