ronbug73 Samba Member
Posted: Wed Mar 21, 2018 2:00 pm Post subject: Aluminum subframe bushings solid mount kit |
Hi samba
what do you think about the ALUMINUM SUBFRAME BUSHINGS SOLID MOUNT KIT?
thank you
Ron |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7561 Location: Santa Cruz
Posted: Wed Mar 21, 2018 2:10 pm Post subject: Re: ALUMINUM SUBFRAME BUSHINGS SOLID MOUNT KIT |
Where did you see this?
A couple of thoughts:
1. In a high-powered car, especially a drag car, especially with slicks,
The rubber sub-frame bushes can cause wheel hop, and badly.
In these type of applications, a solid mount kit can be mandatory.
2. For a street car, with street manners,
The rubber mounts isolating the vibration/noise from the axle/suspension/drivetrain assemblies, at both ends,
makes the car more quiet, comfortable, smooth, and luxurious, even?
The difference in ride quality between the Beetle, with its solid mounted beam and torsion assembly, and the rubber-mounted Type 3, is noticeable.
3. There have been bushings made from Delrin (IIRC), or some other material stiffer than rubber, that can be a sort of compromise between solid and rubber, for a high-powered car, that can still maintain some if its ride quality..
Faintly remember Type 3 Detectives in the UK selling these,
Not sure if that is still true.. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Wed Mar 21, 2018 2:24 pm Post subject: Re: ALUMINUM SUBFRAME BUSHINGS SOLID MOUNT KIT |
Hi Clatter
i bought them from isp 4 years ago
i was thinking to use them on the restoration
this summer. i understand the ride will become more like a beetle
where can i buy new rubber?
Thank you
Ron |
Posted: Thu Mar 22, 2018 2:40 pm Post subject: Re: ALUMINUM SUBFRAME BUSHINGS SOLID MOUNT KIT |
ronbug73 wrote: |
Thank you
Ron |
You can't.. _________________ Bus Motor Build
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
Posted: Thu Mar 22, 2018 4:22 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
I remember seeing the delrin ones too, but can't remember from who. I wish I can get a 3d scan of those aluminum bushings so I can make some with my CNC router. _________________ 68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323 |
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Thu Mar 22, 2018 5:12 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
Type 3 Detectives sold the Delrin bushings. I bought two sets from them years ago. I have a set in my Notchback now, and I wouldn't have it any other way. If you're going to have some power pushing your car and would like to have some fun with it, then use them. So what, they might make a little extra road noise... Are you going for a 100% original resto? Or mild performance? If you install the original rubbers (which can be worn out BTW.. and can cause your subframe to sit wonky..) the first time you take off from a stop light all balls out and you get tons of wheel hop/chatter.... you'll wish you went ahead and used the aluminum bushings.
My two cents. _________________ Justin |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21521 Location: Oklahoma City
Posted: Fri Mar 23, 2018 7:19 am Post subject: Re: Aluminum subframe bushings solid mount kit |
If I had a choice....personally.....I would use glass filled delrin. Not aluminum.
The stiffness of a glass filled delrin bushing and an aluminum bushing used in this function will be equal.
The problem with aluminum....is that it will be sandwiched between steel in an area prone to water spray and chemical contamination. Galvanic corrosion risk is high.
Those look to be anodized.....which goes a long way toward being less prone to galvanic corrosion. Just keep an eye on them over time. They look very nicely made!
Ray |
Brent Samba Member
Joined: April 28, 2010 Posts: 1617 Location: San Tan Valley, AZ
Posted: Fri Mar 23, 2018 11:22 am Post subject: Re: Aluminum subframe bushings solid mount kit |
I have a set of those ISP aluminum bushings.
Ray - do you think they could be used to make a silicone mold to cast some type of urethane bushing? _________________ 69 Fastback Build
Berg5 Build |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Fri Mar 23, 2018 7:50 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
Brent wrote: |
Ray - do you think they could be used to make a silicone mold to cast some type of urethane bushing? |
You want your car to squeak like a Motel 6 bed? |
jgordon Samba Member
Joined: March 21, 2008 Posts: 162 Location: Cocoa Beach Florida
Posted: Sat Mar 24, 2018 3:43 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
heya All
i have the same set from SprintStar
i wouldn't have it any other way
my 68Square
full automatic and Small engine
i notice a little rattle at idle but once moving no issues
NO SQUEAKS
no more washing around in the rear end the original rubber ones were way too soft
i personally like em and really don't notice any additional harshness in the suspension _________________ I drive the speed limit out of spite and love of living children...but mostly out of spite. |
Posted: Sat Mar 24, 2018 5:31 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
Brent wrote: |
Sure...thats easy. But...in a perfect world. urethane is not really what you want for a suspension bushing that is not easy to change. It would work well in this location....but life kay be shorter than rubber.
Urethane is very hard to get the exact balance of rebound (density) with hardness (durometer). And....all urethanes will continue to get harder by about 3-5% per year. This increase in rate with heat.
I had urethane sway bar bushings that literally shattered at the five year mark. I hsve some pictures somewhere.
The other issue is that urethane as I noted has two properties that fight for the lead.
If you make bushings that are say 50% harder than a stock rubber bushing....which are 45 durometer. You get a 65 durometer urethane. But....the compression rebound rate is about 200% springier than Buna N. So they get too bouncy and are to elastic.
This is why most of your urethane suspension components are the common red 80 durometer or even 85 durometer dark blue. These are 80% harder than stock....which does not tell the whole story.
When the urethanes are much over 70 durometer.....the elasticity/flexibility goes away but the rebound rate does not.
It can break things.
The range of highly tuned urethane formulas are endless. Somewhere someonechas one that would be perfect.
But if you are willing to replace them when they get funky.....5-7 years is not bad.
For this type of bushing....unlike say a end link or sway bar or control arm bushing.....keeping the durometer at say 50-60 would be just fine.
You can use Flexane 80 durometer casting compound with some of their durometer reducer and get a good part. Ray |
Jason37 Samba Member
Posted: Sat Mar 24, 2018 8:30 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
Can someone post the dimensions of the front body to beam bushings? Mine were toast and need to make some out of aluminum to fit a new front clip. |
Posted: Sat Mar 24, 2018 9:58 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
I bought front new bushing from Mario T3hq
he is in the classified |
Posted: Sun Mar 25, 2018 9:00 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
I'd pay whatever the asking is for a set of harder rubber or urethane, or..?
Both front and rear..
Wheel hop breaks parts,
And a beetle don't ride all so bad.. _________________ Bus Motor Build
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1256 Location: Orange County, Ca
Posted: Sun Mar 25, 2018 10:09 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
My rubber bushings were worn out and I replaced them with the SprintStar set. Im impressed with them so far, the car feels much better. _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
Posted: Mon Mar 26, 2018 1:06 pm Post subject: Re: Aluminum subframe bushings solid mount kit |
chaosisme wrote: |
My rubber bushings were worn out and I replaced them with the SprintStar set. Im impressed with them so far, the car feels much better. |
Linky? _________________ Bus Motor Build
Posted: Tue Mar 27, 2018 10:45 am Post subject: Re: Aluminum subframe bushings solid mount kit |
Clatter wrote: |
chaosisme wrote: |
Linky? |
https://www.thesamba.com/vw/classifieds/detail.php?id=2152839 |
andybla Samba Member
Posted: Thu Mar 29, 2018 12:00 pm Post subject: Re: ALUMINUM SUBFRAME BUSHINGS SOLID MOUNT KIT |
Clatter wrote: |
ronbug73 wrote: |
Thank you
Ron |
You can't.. |
You CAN but you have to be super patient...I have all of the rubber bushings, NOS with one exception and it's a non-critical part so a used one will work fine.
Took me about 4 years to find them all. |
