PeteSC Samba Member
Posted: Sun Dec 22, 2019 7:15 am Post subject: Re: 1397cc 36hp engine |
Trylon wrote: |
Had to check out what you were up to. Wow! |
Thanks! It’s a fun little engine. |
Ted2 Samba Member
Posted: Fri Dec 20, 2019 10:57 am Post subject: Re: 1397cc 36hp engine |
oops, I just saw the Joe did. |
Ted2 Samba Member
Posted: Fri Dec 20, 2019 10:54 am Post subject: Re: 1397cc 36hp engine |
Pete,
Who did the coating on your case? |
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Thu Dec 19, 2019 5:37 pm Post subject: Re: 1397cc 36hp engine |
Had to check out what you were up to. Wow! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
PeteSC Samba Member
Posted: Thu Sep 12, 2019 7:41 pm Post subject: Re: 1397cc 36hp engine |
It is a cut between then numbers, but two sets of tins were used with cuts offset so they overlap and still seal. I'm not sure it's worth the mod though. While they should work in theory once the engine is built out and installed there are too many obstructions which prevent the half tin from coming out to access the dreaded 3rd manifold bolt. On the 3-4 side it might work if you remove the fuel pump, then the tin should slide towards you and up. The 1-2 side fouls on the case bolt below the generator stand and the manifold, so there's no way I can find to move the tin to get it out. I usually just end up pulling the shroud to remove one of the manifolds to get the engine out.
The thinking behind it was to get one manifold removed to make dropping the engine easier. I guess if you really wanted to pursue it I'd try it on the 3-4 side.
You can get an idea of it here:
mkbug Samba Member
Joined: October 12, 2004 Posts: 145 Location: Northern California
Posted: Thu Sep 12, 2019 1:24 pm Post subject: Re: 1397cc 36hp engine |
Pete - can you explain the modifications to the cylinder tins to make it easier to work with the manifolds? Was it as simple as just a cut between the stamped numbers?
I'm moving to Speedwell manifolds and understand that is difficult to get all the nuts tighten down.
thanks,
Martin _________________ I'm Martin
My Build: https://www.thesamba.com/vw/forum/viewtopic.php?t=667183 |
PeteSC Samba Member
Posted: Thu Sep 12, 2019 10:01 am Post subject: Re: 1397cc 36hp engine |
Thanks Erik! |
Big_E_Deluxe Samba Member
Joined: September 23, 2013 Posts: 264 Location: Charlotte, NC
PeteSC Samba Member
Posted: Thu Sep 12, 2019 6:20 am Post subject: Re: 1397cc 36hp engine |
Some minor changes-
I added a Speedwell USA Pre-A style oil breather (with an added tube for the 1/2 side valve cover vent).
Changed the distributor to an 010 in place of the 019, since the advance curve of the 010 pairs better with the Okrasa-style setup. It's a noticeable difference, especially at part throttle cruising at 2800-3000 rpms where the 010 is fully advanced. I should be able to pull down my jetting sizes some...I hope to do some wideband tuning this weekend.
Also swapped the blue coil out for a black one, mainly for aesthetics. The "Blue Screamer" 019 was NOS when I got it, and came with that blue coil, bracket, sticker, and original "Blue Screamer" box, so I wanted to put all of that back in the box for garage display.
I have a little over 4000 miles on this engine now, and drive it several times per week to work, etc. It's a really fun combo.
PeteSC Samba Member
Posted: Sun Oct 21, 2018 4:53 pm Post subject: Re: 1397cc 36hp engine |
Thanks Low Brau.
No plans to Dyno. It’s almost indetical to Shin Watanabe’s 1397 that was written up in Hot VW’s and Dyno’d. 69 hp for Shin’s; mine has larger valves/slightly higher compression so maybe a hair more than that. |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Fri Oct 19, 2018 9:39 am Post subject: Re: 1397cc 36hp engine |
PeteSC-
Do you have any plans to dyno your new toy?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Fri Oct 19, 2018 6:37 am Post subject: Re: 1397cc 36hp engine |
Absolutely beautiful looking engine. Sounds great too! _________________ Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1961 L-380 Turkis Deluxe Beetle
1985 Vanagon Country Homes Camper (work in progress - EG33 swap) |
PeteSC Samba Member
Posted: Sat Oct 13, 2018 10:29 am Post subject: Re: 1397cc 36hp engine |
Thanks Erik! Carbs sync’d this morning:
PeteSC Samba Member
Posted: Wed Oct 10, 2018 9:44 pm Post subject: Re: 1397cc 36hp engine |
Installed it tonight. Hope to fire up tomorrow.
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7229 Location: Videbaek Denmark
Posted: Fri Aug 10, 2018 7:59 am Post subject: Re: 1397cc 36hp engine |
The extra 100 cc makes the Okrasa heads engine work so much better. That you will not regret. |
PeteSC Samba Member
Posted: Mon Jul 30, 2018 12:08 pm Post subject: Re: 1397cc 36hp engine |
Thanks Erik! Appreciate all of your help and brain-picking through the build (oh, and the carbs too!). |
PeteSC Samba Member
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sat Jul 28, 2018 7:39 pm Post subject: Re: 1397cc 36hp engine |
Sweet. Never saw these before. PO just had them zip tied to the balance tube. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
