KrisBalfe Samba Member
Posted: Tue Feb 05, 2019 8:26 pm Post subject: Making my 1961 Riviera syncro |
Purchased this double door riviera out of California earlier this year and was planning on replacing belly pans, cargo floors and some other common rusted areas. Unfortunately the bus was much more of a basket case than I’d been planning on.
So I started coming up with a game plan and purchased from a friend a shorty ‘57 with much of the metal that would be required to piece the bus back together, unfortunately I’d still be required to patch in the missing frame sections from the shorty and was looking at going backwards as far as the torsion housing and transmission were concerned. So with that and some other problems in mind I scrapped hope of returning this bus to stockish. At this point it would have been more replacement metal than original which wasn’t what I was looking for in a split this time around.
I left all those plans behind and decided to use the chassis of a late bay westy I have kicking around. Reasoning could have been misguided but I believed there were benefits to doing so... then I thought to myself, I am already doing something fairly stupid here may as well go for it and make this thing a syncro.
I have purchased the shell of an ‘87 syncro and will be starting down this path if there is any interest in this project I’ll put up the progress here.
Thanks, Kris |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2659 Location: Phoenix AZ
Posted: Tue Feb 05, 2019 9:06 pm Post subject: Re: Making my 1961 Riviera syncro |
Why not just build out the syncro? I'm a split and vanagon owner, the vanagon is a far superior vehicle driving and comfortable wise _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Posted: Tue Feb 05, 2019 9:45 pm Post subject: Re: Making my 1961 Riviera syncro |
Fair question, I thought for some time on doing exactly that, in the end I didn’t see two better vehicles to attempt this with than a parted out syncro and rusted out camper... also I’ve always wanted an awd split camper. |
nineteensixtyfiveVG Samba Member
Joined: August 03, 2009 Posts: 456 Location: San Diego
Posted: Tue Feb 05, 2019 11:31 pm Post subject: Re: Making my 1961 Riviera syncro |
consider me interested |
Posted: Tue Feb 05, 2019 11:36 pm Post subject: Re: Making my 1961 Riviera syncro |
Yes an 4wd split would be rad but I have a feeling for all your efforts its not going to handle as well as a vanagon _________________ 58' pg/sg silo fridge westy
76 911S |
Busstom Samba Member
Joined: November 23, 2014 Posts: 4579 Location: San Jose, CA
Posted: Tue Feb 05, 2019 11:50 pm Post subject: Re: Making my 1961 Riviera syncro |
One reason I'd pursue the split route is to avoid the smog-check nazis...and Utah goes back to '67...ouch.
I can't tell for certain, but it also looks like you may require the safety inspection based on the stipulation for vehicles that expired in 2017 (if that includes 2017 and earlier...I'm not clear on their 2018 legislation eliminating passenger vehicle inspections). |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 27717 Location: Free State of Florida
Posted: Wed Feb 06, 2019 12:43 am Post subject: Re: Making my 1961 Riviera syncro |
Isn't the Vanagon wheelbase longer and the track a lot wider? You would either have to lengthen and widen the body, or shorten and narrow the chassis.
At any rate, let's see what you build. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
kermie Samba Member
Joined: July 24, 2007 Posts: 39 Location: The Netherlands
Posted: Wed Feb 06, 2019 2:12 am Post subject: Re: Making my 1961 Riviera syncro |
Blue Baron wrote: |
Isn't the Vanagon wheelbase longer and the track a lot wider? |
Wheelbase of a Vanagon is 2.4" longer. The track is a little over 8" wider. So some adjustment is needed  _________________ 1962 Campmobile
1964 Swedish Police sold
1965 Double Door Panel sold
1966 Sundail Camper sold |
Posted: Wed Feb 06, 2019 6:24 am Post subject: Re: Making my 1961 Riviera syncro |
I hear you all, quality points.
The ace up my sleeve is that I’ve already done this to my bay window. The wider track is my biggest concern. I don’t want to hack the wheel wells. It looks like I’ll need to remove 3” from the middle of the vanagon chassis to avoid doing so. The brake booster and pedal cluster will also have to be in the cab and I may have to put a bay window steering column in. Which would aesthetically speaking be the worst part for me, I’d like to keep the split steering wheel. |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2092 Location: Plymouth, MA
Posted: Wed Feb 06, 2019 6:32 am Post subject: Re: Making my 1961 Riviera syncro |
I'm very interested. I've thought about how I would do this conversion in the past.
If I were to do it , I'd build out a custom front subframe or modify the syncro subframe up front. This would lift the bus quite a bit since there's not a lot of room under there for the front diff. I'd relocate a lot of stuff and run most of the syncro suspension components, modified or custom to fit the custom subframe.
This would likely require a complete solution for the rear suspension as well.
A few things work towards your advantage. The gas tank is in the right place and theres a lot of room in the engine bay for an adequate power train. The frame horns would have to come out for sure.
Its a cool concept. Keep us posted. I never went forward with it because vanagons and syncros are my favorite buses and I'd rather fix them up before parting them out. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2197 Location: Bulli Klinik, Colorado Springs
Posted: Wed Feb 06, 2019 9:22 am Post subject: Re: Making my 1961 Riviera syncro |
Widen the Split to fit the Vanagoon chassis. Just like they did with the Race Taxi Bus.
Sound like a cool project. _________________ PM me about quality metal-work on your vehicle.
Mike K
Bulli Klinik
Colorado Springs |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1462 Location: Richmond, VA
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20781 Location: Sandpoint, ID
Posted: Tue Feb 12, 2019 10:53 pm Post subject: Re: Making my 1961 Riviera syncro |
I am so in on this build. DO IT! _________________ nothing |
mr white Samba Member
Joined: October 02, 2005 Posts: 1194 Location: beautiful Oregon & Mohave County, AZ
Posted: Tue Feb 12, 2019 11:42 pm Post subject: Re: Making my 1961 Riviera syncro |
Some bits from a 85-87 Audi 4000cs Quattro may help you on your quest. Good luck! |
Posted: Wed Feb 13, 2019 6:19 pm Post subject: Re: Making my 1961 Riviera syncro |
I haven't been able to get a real start on this yet.
Right when the donor syncro showed up, so did the snow.
Which is not necessarily a bad thing. It has been great for
Driving my other bus in.
Here is the meager start of the project. Should move a lot
Faster once work and snowfall slow down.
That's as far as I've gotten besides stripping the syncro down. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9828 Location: Exit 7, New Jersey
Posted: Wed Feb 13, 2019 9:54 pm Post subject: Re: Making my 1961 Riviera syncro |
With the chassis that rusted, I like the suggestion to widen the whole bus. You could make it with three front windshields. Use a deluxe skylight sideways as the center window. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
Posted: Wed Feb 13, 2019 10:16 pm Post subject: Re: Making my 1961 Riviera syncro |
I like your creativity, my goal though is to hopefully end up with a bus that looks like a split with a mild lift. The vanagon track isn’t excessively wider than the split body, maybe 1.5” on each side. I left the vanagon chassis stock on my bay conversion and didn’t even mess with the rear wheel wells, front I played with the idea of adding the vanagon dogleg flare. One side is done, the other isn’t until I decide which way to go.
With the split though I don’t want the wheels outside of the body so I will likely remove 3” from the T3 chassis. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Feb 14, 2019 9:06 am Post subject: Re: Making my 1961 Riviera syncro |
You may be able to make up the difference in width with wheel offset. Just a thought, it'd make getting CVs much simpler, and not mess with any of your geometry. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Feb 14, 2019 10:27 am Post subject: Re: Making my 1961 Riviera syncro |
That is worth some looking into.
I really want to keep stock wheels on this though. Hopefully the weather will cooperate this week and I can dig into it a little more |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Posted: Fri Mar 22, 2019 10:12 am Post subject: Re: Making my 1961 Riviera syncro |
Another one? Has the welds even cooled off on the bay? This is going to be very cool indeed Gona piss off some of the stock Nazis for sure :fist:
I love it Kris - keep pluggin along. A lifted, syncro early split will be a nice treat to see. Especially with a nice retro wood camping interior.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
