Clips / plastic studs for door seal for upper a-pillar area ??
Tvättbjörn
Tvättbjörn is offline
PostPosted: Mon Jul 05, 2021 7:29 pm    Post subject: Clips / plastic studs for door seal for upper a-pillar area ?? Reply with quote
What are you guys are using? Each door seal has two of these plastic studs for holding the door seal in place in the upper A-pillar area. What will work? Any Napa or ..... part number I can use? Mine are missing and I finally found the spot where the water gets in Rolling Eyes Any info is great. I did not find any information with search. Thanks
ALLWAGONS
ALLWAGONS is offline
PostPosted: Mon Jul 05, 2021 9:32 pm    Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? Reply with quote
Here you go
https://www.thesamba.com/vw/classifieds/detail.php?id=2097748
https://www.thesamba.com/vw/classifieds/detail.php?id=2161193
is this what you are talking about?
Tvättbjörn
PostPosted: Mon Jul 05, 2021 9:55 pm    Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? Reply with quote
ALLWAGONS wrote:
Here you go
Yes, I did see it, but one of the used clips is cracked in the center and the new clips are on the other side of the planet. I was hoping there is a similar clip which could be used. I know the square head is important for the support of the seal.
ALLWAGONS
PostPosted: Tue Jul 06, 2021 9:33 am    Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? Reply with quote
I tried. Cool
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 07, 2021 12:00 pm    Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? Reply with quote
Nothing in the "help" section? Usually to can find something with a round head that could be trimmed to fit. The hard part is finding the right size to fit the hole in the steel.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Brent
Brent is offline
PostPosted: Thu Jul 08, 2021 6:11 pm    Post subject: Re: Clips / plastic studs for door seal for upper a-pillar area ?? Reply with quote
69 Fastback Build
Berg5 Build
