dabaron Samba Member
Joined: June 21, 2018 Posts: 2568 Location: Philly, mang
Posted: Fri Dec 17, 2021 11:49 am Post subject: fuel pump noise, how to fix? |
this noise in my 1991 Westy is driving me bonkers for wankers... happens with just key on when the pump primes, when idling or when driving and under load. temp does not matter. sometimes the noise stops for a few minutes, sometimes it takes a few minutes for it to happen at key on...
it's the fuel pump right? i replaced it with a brand new Bosch... noise still there, zero change. i've replaced the fuel tank, the fuel filter (post, no pre pump), the fuel pump, the rubber mounts for the fuel pump... zero change.
is this the sound people are using the resistor mod to eliminate? _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1041 Location: Calgary, AB
Posted: Fri Dec 17, 2021 1:01 pm Post subject: Re: fuel pump noise, how to fix? |
Hard to tell for sure, but it does sound like cavitation to me. The resistor should fix that. It also sounds like a vibration issue. How do the mounts look? |
Posted: Fri Dec 17, 2021 1:23 pm Post subject: Re: fuel pump noise, how to fix? |
CanStan wrote: |
brand new mounts, no change. i feel no vibrations. i'll test reducing the voltage with an adjustable power supply and see what i find. _________________ 1991 Vanagon GL Camper
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9815 Location: Mt Lemmon, AZ
Posted: Fri Dec 17, 2021 4:25 pm Post subject: Re: fuel pump noise, how to fix? |
Mine has the pre-filter (white cube) and makes a lot of noise when the filter needs to be changed.
How does the status of the after-pump filter affect the pump noise (I really don't know)? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32666 Location: Reading Pennsylvania
oceanair Samba Member
Joined: June 09, 2013 Posts: 720 Location: Victoria, BC
Posted: Sat Dec 18, 2021 3:20 pm Post subject: Re: fuel pump noise, how to fix? |
Be absolutely sure that the pump is NOT contacting the frame. If it is, it's loud. My pump 'holder' was bolted on backwards and the pump was touching the frame. Turned it a round and silence ever since! _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
GreggK Samba Member
Joined: May 17, 2008 Posts: 898 Location: Colorado/Philidelphia
J Charlton Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Mon Dec 20, 2021 11:18 am Post subject: Re: fuel pump noise, how to fix? |
Several of our NAHT hightop installer / distributors, along with doing general vanagon service or retrofitting and modernizing customers' vans - i.e. everything from front to rear, road to top, power trains etc etc - also periodically buy vans that they renovate from bumper to bumper and then sell. When they do so it is critical, in their eyes, that the vehicle that they sell be be as sound and trouble free for years as possible. To that end and to start "with a clean slate" they all pretty well have a common systems approach. Rather than chasing gremlins they proactively routinely replace some critical systems components to rule out potential causal future problems. The most common proactive measures seem to be:
1. Replace the 30+ year old fuel tank. The fuel tank has a screen at the bottom over the outlet - this screen gets plugged or obstructed with 30+ years of crap from just "life" of being filled, going through years of internal rusting, gum residues from fuel sitting for long periods etc etc - Not replacing it can lead to hours and hours of gremlin chasing - including fuel pump cavitation, plugged filters, dirty injectors etc etc etc/. As an aside - it baffles me that folks think that replacing a fuel filter plugged to the point of restricted flow "solves" anything - where did the "stuff" that is plugging the filter come from?
2. Replace the rad and coolant pipes. Chasing overheating and / or overcooling issues can be a frustrating and ongoing process. The coolant pipes are a "while You're there" spin off on the fuel tank replacement but the radiator replacement issue and therefore starting with a clean 100% effective rad - not one that is 30 years old and probably more than partially filled with crap - presents a known starting point to sort out any emergent issues. This is even more important with engine conversions - the wbx engine is relatively inefficient ( if a wbx powered van gets 15 mpg and a suby powered same van gets 22mpg - then the difference in fuel consumed (energy) has to be accounted for - in the wbx case it is the form of heat - therefore the relatively huge cooling system in a vanagon - a cooling system that overcools in most engine conversion - the overcooling can be solved with bypasses or feedback routes - each specific to the particular conversion power plant but, again, working from a known"clean: starting point is important.
3. Replace the heater core, blower motor and whatever else needs redoing WRT the heater, defroster blower - this is such a PITA job and one that is critical for safety certification that it is far better that the vehicle is sold with it operating at 100% than having to deal with the unhappiness of buyers who have to deal with a faulty heater or blower a year or so in the future.
There are other procedures that the pro's do as a matter of course but these 3 are done as a matter of course even if the systems are "working" in the van when they start. _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024 |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Mon Mar 07, 2022 3:16 pm Post subject: Re: fuel pump noise, how to fix? |
Bumping this thread, I have the exact same noise coming from my fuel pump as well. Brand new fuel tank and lines. Pump (Bosch) and filter (OE post filter, no pre filter) only have about 500 miles on them. Rubber isolator mounts are new as well, and no part of the pump is contacting the frame. Just started happening a few days ago, and seems intermittent (but it is mainly present). Its very loud and I can hear in the van when idling.
Were you ever able to solve your noise issue? _________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
DuncanS Samba Member
Posted: Mon Mar 07, 2022 4:17 pm Post subject: Re: fuel pump noise, how to fix? |
Had a fuel issue when in Belfast, Maine. The Beetle Shop is a serious T3 place with knowledgable guys. In checking everything out, he noticed I had a replacement fuel pump. His comment, "I guess we can rule out a crappy Bosch fuel pump problem as you don't have one. We've had a ton of Bosch fuel pump problems and we never put them on anymore."
Duncan |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Mon Mar 07, 2022 9:19 pm Post subject: Re: fuel pump noise, how to fix? |
Had a brand new made in EU Bosch fuel pump installed prophylactically, replacing the OEM 120K mile original fuel pump on my vanagon.
That darn new Bosch pump was noisy all the time. I tried all the usual electric motor audio solutions without success.
The Bosch finally became silent as it died after about 20k miles leaving me stranded.
I used a new $49 Hayg Walbro fuel pump from eBay as a replacement
That Hayg Walbro pump is completely silent and has worked well for several years.
No more Bosch fuel pumps. _________________ 'Let's Go Brandon' |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16514 Location: Brookeville, MD
Posted: Tue Mar 08, 2022 7:16 am Post subject: Re: fuel pump noise, how to fix? |
AtlasShrugged wrote: |
No more Bosch fuel pumps. |
Got a link to the Hayg Walbro pump? _________________ Dave O
The Western Syncro build
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15148 Location: Syracuse, NY
Posted: Tue Mar 08, 2022 9:31 am Post subject: Re: fuel pump noise, how to fix? |
agreed, when you are on the side of the road.. is the last place I want to pull out a old pump that 'ran when pulled' and hope.
I do keep old pumps around the shop, toss them on a project/carcass to move or test it.. but not on a vanagon built for roadtrips and MY leisure time activities.
worth far more than $50 at that time..
dobryan wrote: |
Thank you. Bought one. It is nice to have a new spare vs an old used pump as a spare.... |
Abscate wrote: |
Andymon Samba Member
Joined: February 24, 2015 Posts: 314 Location: Medford, OR
Posted: Tue Mar 08, 2022 9:49 am Post subject: Re: fuel pump noise, how to fix? |
Ours always has had a static sound. _________________ "Blanch" '85 Westy
"Too many freaks and not enough circuses". |
Posted: Tue Mar 08, 2022 9:56 am Post subject: Re: fuel pump noise, how to fix? |
That's because it runs on static electricity with the hidden and rarely seen Van De Graaff generator.
Duncan |
Posted: Tue Mar 08, 2022 10:33 am Post subject: Re: fuel pump noise, how to fix? |
i have ordered this fuel pump, recommended by Marco Mansi. i have not installed it yet, but once in, i will report back.
https://www.ebay.com/itm/353134701388
i tried a number of things with my replacement Bosch, adding the ballast resistor did not resolve the issue. i hope this solves it. _________________ 1991 Vanagon GL Camper
Posted: Tue Mar 08, 2022 10:49 am Post subject: Re: fuel pump noise, how to fix? |
dabaron wrote: |
i tried a number of things with my replacement Bosch, adding the ballast resistor did not resolve the issue. i hope this solves it. |
I'm curious to hear your results with the new pump once installed.
I did notice that several vendors (BusDepot, Bus Lab) also sell the Pierburg version of this fuel pump. Ron from BD stated in an earlier thread that he has seen no real difference in quality between the Bosch and Pierburg though.
https://www.busdepot.com/251906091
https://www.buslab.com/product-p/251906091.htm
-Mark |
Joined: January 01, 2007 Posts: 16894 Location: sticksville, ct.
Posted: Tue Mar 08, 2022 1:30 pm Post subject: Re: fuel pump noise, how to fix? |
walbro for the win
Botch is junk these days.
I agree that a tank should be replaced. they are (were) dirt cheap.
i'm running the large outlet to the pump and a post filter. literally can't hear it run _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
