TornadoVan Samba Member
Joined: March 11, 2024 Posts: 39 Location: Bellingham, WA.
Posted: Wed Mar 27, 2024 1:20 am Post subject: Looking for a Samba member in the PNW to help with A/C test. |
I called every shop in town that I would trust to work on my van, and some out of town, trying to find someone to do a vacuum test on my A/C system. Nobody will touch it as they don't want to deal with the r12 they'd end up extracting from the system in the process. Even the guy that does nothing BUT A/C work said he stopped working on older VW systems.
My rig has a seized compressor and I want to determine if the system is leaking before I go ANY further. If it is leaking, I'm done--I'm not risking damaging the interior duct work to replace seals. If it is NOT leaking, I plan on rebuilding the compressor, reinstalling it and then simply recharging the system.
So, basically looking for someone with the equipment to evacuate the system, vacuum test the system, and later down the road, recharge the system with one of the two r12-replacements available.
Of course, totally willing to compensate for time and effort.
I was also wondering if there are any SPECIAL tools required on the compressors used on a 1990. Kinda putting the horse before the cart with that question, but if rebuilding the compressor is a royal pain, I might just stop pursuing this right there.
Thanks in advance, for help and/or advice. Located an hour and a half North of Seattle. |
space Samba Member
Posted: Wed Mar 27, 2024 5:21 am Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
Get a set of gauges that should help u determine a leak
$30 thru amazon _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
bajabones Samba Member
Joined: April 17, 2019 Posts: 134 Location: Tacoma, WA
Posted: Wed Mar 27, 2024 5:25 am Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
You don’t need a vacuum test
You need the shop to check the pressure with the motor off
There is a low side tap by the compressor
If the pressure is 0 you have a leak
If it’s above 0 you could have a slow leak
If its over 50 you need to compare the pressure and temperature to a PT chart
If it matches there’s probably not a leak
I am a commercial HVAC Tech
I am not a auto A/C specialist _________________ 1990 Syncro Doka
2.1 DJ
Triple Knob
Solid shaft |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16510 Location: Brookeville, MD
vanagondan Samba Member
Posted: Wed Mar 27, 2024 6:00 am Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
Just push one of the schraders in and see if pressurized refrigerant spurts out. If it doesn’t then you’ve got a leak. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17158 Location: Retired South Florida
Posted: Wed Mar 27, 2024 7:05 am Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
No recommendations on a shop, but if the compressor physically seized, even if you could find the parts to rebuild it, you will need to completely flush the system. The most effective way is to disassemble the system and flush with acetone and compressed air. There are flush kits, but it doesn’t take much debris to plug the evaporator core.
I used to tell customers if you want AC, you’ll need to plan on eventually replacing everything. If that is off putting, best to not start. AC always has the same symptom. I can think of one or two owners that complained the AC was too cold.
I’ve been watching you tube videos for a mini split I’m installing. A gauge manifold and vacuum pump are reasonably priced. If you can rebuild an AC compressor, you can certainly evacuate and recharge.
My experience, it’s very rare for a compressor to seize and have a full charge. _________________ ☮️ |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1203 Location: Vancouver, BC
Posted: Wed Mar 27, 2024 9:41 am Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
I called around the Lower Mainland BC last year trying to find a company that does custom A/C work and all the shops said they use this company in Maple Ridge BC, about a 30-40 minute drive from the Blaine or Sumas WA border crossings.
I don't know if they handle R12 systems but give them a call and see if they would agree to work on your Van. They built custom hoses for me and do all the leak testing and system charging.
https://autotechac.com/
T: (604) 460-1422
Darrell _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 953 Location: Northern California
Posted: Wed Mar 27, 2024 10:11 am Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
A new compressor is still available. Not worth it to try to rebuild the old one in my opinion. If you should decide to rebuild, use the search feature at the upper left. You will find posts from others who have plod this path… _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
Posted: Wed Mar 27, 2024 12:40 pm Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
"You will find posts from others who have plod this path"
You sure make this path sound exciting!
As far as posts suggesting that I don't need a leak test but pressure tests instead, the problem is nobody wants to do anything to the system. Quite simply put, don't want it in the shop.
Vanessa has gone 25 years without functioning A/C, so at this point, considering cost, work involved and the lack of serious need, I think I am going to just pass on getting the A/C working again. It was more about a desire to have everything working than a need to have it working. After all, I live in the PNW and have only needed to have it functioning once , when I was traveling around the WA Scablands. Driving around at 65mph when it is 105F can be tolerable with the windows wide open and a wet shirt, but driving in city traffic at those temps can be a pain. Oh well. I'll deal with it.
Thanks for the advice folks! |
Joined: January 01, 2007 Posts: 16892 Location: sticksville, ct.
Posted: Wed Mar 27, 2024 12:45 pm Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
25 years without working?
you will have leaks left and right. "normal" automotive seepage is about 1/8-1/4 pound a year
either get in your head you're going all the way or just leave it. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Wed Mar 27, 2024 12:50 pm Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
TornadoVan wrote: |
so at this point, considering cost, work involved and the lack of serious need, I think I am going to just pass on getting the A/C working again. |
That's the route I'm on too.
I had no AC for about the first 8 years after buying my van. Paid a shop to convert to R134 and recharge and it worked just well enough to take the edge off of a hot drive through SLC later spring. The next year it was dead again but I didn't bother going back for them to track the leaks using the UV light and dye that they added to the system.
I tried recharging it myself last year with one of those cans you can by at the FLAPS but it didn't do squat.
I'd rather focus time and $ on other stuff at this point - particularly considering how seldom I have back seat passengers. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
hardway Samba Member
Joined: January 03, 2012 Posts: 416 Location: Fidalgo Island
Posted: Wed Mar 27, 2024 1:17 pm Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
Pretty much every AC system has some leakage. Some 25 year old Toyotas have lost so little that they still operate on the original charge. But a Vanagon with 30 + feet of non barrier hose leaked quite a bit when they were new. If your van still has R12 in it it would be almost empty under ideal circumstances.
Most shops can no longer deal with R12. Only shops that deal with expensive classic cars are tooled up for it. Most shops won't touch a Vanagon. R12 is illegal in British Columbia.
If you really want the AC to work you should read the AC restoration threads here on The Samba. There is no short-cut. I am restoring the AC right now on two T3s. The only component being re-used is the evaporator.
AC technology has changed a lot. Many compressors are now variable displacement. Both of the vans that I am restoring the AC on have 1.8t motors with variable displacement compressors. The new condensors are much more efficient. The new barrier hose leaks a lot less. If you change to R134a you really want to get all of old mineral oil out. In fact the interior of the AC system needs to be absolutely clean, no black tar, flakes of rubber or rust.
If your compressor is seized that is a bad start. I autopsy the compressor to see if it spit shrapnel. But unless the system leaks so bad that it will not hold a vacuum for several hour the only real test is to fill the system and see what happens.
I have done AC for decades. It is either easy or very hard. If a system has been open or discharged for a long time, it is always hard. |
Posted: Wed Mar 27, 2024 1:25 pm Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
A good way to think about it is that the stock A/C unit in good working order will take the edge off of the inside of the Van temperature during hot weather. If you have window tinting and good door seals as well as insulation, it will be more noticeable and more comfortable, but not like a modern car. The air coming out of the ducts will be cold but the Van ambient temp will only be reasonable.
For my Bus, I have two heater cores and A/C evaporator units (one under the rear seat and one between the front seats) and it heats the entire Bus really well in the Winter and I expect that the A/C will work well too with the dual zone evaporators in the Summer but I won't know how well until the weather gets hot again in July as I didn't have it hooked up and charged last summer. _________________ *******************************
Sodo Samba Member
Joined: July 06, 2007 Posts: 9628 Location: Western WA
Posted: Wed Mar 27, 2024 3:51 pm Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
Air conditioning vastly improves your summer travel experience. If there''s even a ghost of a chance that it will work I would fix it.
Speaking of WA scablands I was there a week ago and we used the A/C. Not because we HAD to but because we wanted to see if it was still working after last summer.
And it was!
Last summer I put one can of "leak plugger" stuff in.
I've been using RedTek. _________________
....KTMs, GasGas, SPOT mtb |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32647 Location: Reading Pennsylvania
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Wed Mar 27, 2024 5:14 pm Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
Just for fun I’ll say this;
Customer: my bicycle tire is flat….
Shop; ok I’ll check it out….
Customer: hurry up!
Shop; yes it’s flat on air pressure, how would you like me to deal with this?
I’ve heard big rig (18 wheelers) shops deal with R12 all day. Most. Of the fleet is super old and uses R12 all day.
Give them a try. Spell check sucks and suck it |
a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Thu Mar 28, 2024 6:24 am Post subject: Re: Looking for a Samba member in the PNW to help with A/C test. |
It’s not that the shops don’t want to, it’s a regulation thing!! The governor put a bunch of restrictions in place. You can’t even buy the “green alternative “ r134 in Washington because of his nonsense.
I would go with the harbor freight tools . _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
