question regarding starter wiring
schwim
schwim is offline
PostPosted: Wed Nov 27, 2024 9:19 am    Post subject: question regarding starter wiring Reply with quote
Hi there everyone,
I am hoping to get the start/charge connections made and I've forgotten the wiring between the starter and gen. I've got the two connections made from the front of car to the regulator and I've got the run from the regulator to the starter connected at the reg but I'm confused about two connections. First, the start wire female spade: there are two male spades on the starter relay. Does it matter which one the start wire connects to? Second is the wire from pos on regulator to starter relay: should that be on the same post as the positive battery terminal or on the other post active only during start?
Thanks for your time!
Zippy the Wonderbug's achingly slow meandering toward roadworthiness
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Wed Nov 27, 2024 9:44 am    Post subject: Re: question regarding starter wiring Reply with quote
The wire in the second picture goes to the top solenoid terminal with the 13 mm nut.
HYBRID STARTER 6/12 https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
schwim
schwim is offline
PostPosted: Wed Nov 27, 2024 10:00 am    Post subject: Re: question regarding starter wiring Reply with quote
Thanks for the help!
So same as positive battery cable, sending power to the regulator all the time?
Also, do you happen to know if it matters which of the two spades I connect the start trigger wire to? The old starter only had one spade if I remember correctly.
Cusser
Cusser is offline
PostPosted: Wed Nov 27, 2024 10:49 am    Post subject: Re: question regarding starter wiring Reply with quote
Yes.
Fine where your photo shows it now.
wdfifteen
wdfifteen is offline
PostPosted: Wed Nov 27, 2024 11:52 am    Post subject: Re: question regarding starter wiring Reply with quote
Actually, it's sending the power the generator created from the regulator to the battery.
I assume you mean the two male connectors on the solenoid. It makes no difference.
.65vw
.65vw is offline
PostPosted: Wed Nov 27, 2024 12:14 pm    Post subject: Re: question regarding starter wiring Reply with quote
Hey Schwim!
Good to see you are still bugging around. Me too!
schwim
schwim is offline
PostPosted: Thu Nov 28, 2024 12:26 pm    Post subject: Re: question regarding starter wiring Reply with quote
.65vw wrote:
Hey Schwim!
Well, hello there Smile
I'm working on ending my reign of the title of longest disassembled driver(in my zipcode).
Hope you're doing well, it's great to see you still having fun.
MrGoodtunes
MrGoodtunes is offline
PostPosted: Thu Nov 28, 2024 6:03 pm    Post subject: Re: question regarding starter wiring Reply with quote
wdfifteen wrote:
... the two male connectors on the solenoid. It makes no difference.
Don't be so sure about that. Solenoid can have 2 male spade terminals that are electrically identidal (VW #50); like here:
But the solenoid in the picture posted by schwim has its 2 male spade terminals far apart, probably not electrically the same. At least one of them is the VW #50 connection from Start position of ignition switch. The other could very well be VW #15a, which connects to positive terminal of ignition coil. I call it a "quick start hot wire" because of the effect it has had upon starting my engine since recently installing a starter solenoid that has this extra terminal. I love it, and posted about it here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=10121633&highlight=#10121633
