vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5811 Location: Wamego, Kansas, USA
Posted: Thu Apr 10, 2025 10:31 am Post subject: Expensive-sounding noise, time for a Subaru? heh |
This time, NOT the '78 TDI!
Editing to add, this engine was originally from an aircooled Vanagon. In 2014ish, I bought the engine and swapped all the stuff over to make it go in the Bus. In 2016, I swapped the center-mount carb for factory fuel injection from a '78ish Bus. Also has an 091 transmission.
Was driving the '73 today, and as I left an appointment, it very suddenly started making a clacky, metallicky, expensive-sounding noise. Got it to a safe spot (in front of a friend's house, conveniently) and made 3 videos, and started walking to my office.
Will call AAA after work.
As I walked I set about uploading the videos to YouTube... I don't do that often, and it automatically grabbed all 3 clips and put them into one video, so sorry that that is kind of annoying. (Edit: Lord, I realized two of them are upside down! Oh well.)
No holes in the block, no massive oil puddles.
From the back, the sound seemed to be coming from the middle of the engine, but from up top the sound seemed to be more towards the transaxle. So I'm trying to be optimistic that maybe it's just something to do with the clutch, like maybe a bolt came loose or something.
I think the engine may die in one of the clips, and at idle it is a bit rough... That seems "normal" at the moment; the #3 plug will eventually foul over time, such that it seems to come offline at low RPMs, and kick back on as the RPMs go up, so most driving is fine enough. Eventually it gets annoying and I clean or replace the plug, and all is well for quite a while. It's time to do that again, which I sort of forgot until after I promised my 4.5 year old we could take it this morning. Recently did track down and fix some spark "leaking" from the spark plug wires (after the last time I drove it), so I am/was somewhat hopeful that will stop the plug from fouling in the future.
All that to say, the stumbly idle could be a red-herring if you weren't aware of that.
So, what is your call for what I find?
_________________ Dave Cook
1973 Wild Westerner
My Thing
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5263 Location: Southern AB
Posted: Thu Apr 10, 2025 12:08 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
my guess is :: dropped a valve guide, and the bits are getting hammered in the combustion chamber
probably that #3 that was leaky _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13409 Location: West Coast, USA
Posted: Thu Apr 10, 2025 12:20 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
I would rotate the engine by hand in a quiet place and feel/listen. A half inch ID hose makes a fine stethoscope.
Or pull the valve covers and see which valve is doing the tango with its pistonโฆ My suspicion is your plug fouling was due to a sinking valve/seat that didnโt show up with self-adjusting valves.
Drive it home and put the tow money towards a Subaru.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Thu Apr 10, 2025 12:59 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
A '73 would have the hole for the factory air injection system that are plugged one way or another. I am guessing that a plug failed and all you need to do is replug the hole. |
Posted: Thu Apr 10, 2025 2:08 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
Wildthings wrote: |
Just edited the original post to add this specific information about the Engine:
Editing to add, this engine was originally from an aircooled Vanagon. In 2014ish, I bought the engine and swapped all the stuff over to make it go in the Bus. In 2016, I swapped the center-mount carb for factory fuel injection from a '78ish Bus. Also has an 091 transmission. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23601 Location: NYC/Upstate/ROW
Posted: Thu Apr 10, 2025 2:09 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
Itโs a cheaper, rod knock sound but it isnโt floating like a knock.
Have a good look at your exhaust manifold for cracks and fails _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Just had this thought:
Though I drove it only a short distance, it *seemed* like the power was normal.
And when I was trying to get the videos, I one time did rev it up and I'm pretty sure that the one cylinder came "on line" as always when I did that.
Doesn't seem like those things would happen if it had dropped a valve, right? _________________ Dave Cook
1973 Wild Westerner
My Thing |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1936 Location: Vancouver, BC
Posted: Thu Apr 10, 2025 2:26 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
I had plugs (bolts) threaded into my emission ports/holes on my heads on my 73 Panel (1700cc) back in the 90s and one of the bolts I was using to plug the hole, somehow worked it's way in (threaded itself in further) and started hitting the valve and made a similar sound.
The engine ran fine as it didn't affect anything until the valve finally broke and then the engine stopped dead, luckily at an idle and didn't cause too much damage.
Mine wasn't as loud/pronounced as in your video and took a few days of driving before it broke. Yours sound like a much louder impact so I would recommend not running the engine anymore until you make sure it isn't something simple like mine was if I had taken the time to troubleshoot it better.
In my 76 Westy, I had a bad main bearing that was noisy but not the same knock as you are hearing for reference. _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23006 Location: Oklahoma City
Posted: Thu Apr 10, 2025 2:42 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
Having heard it before...it does kind of sound like one of the exhaust air injection plugs has come out....BUT....when that happens there is exhaust and/or flame into the engine bay. You would see it in the videos.
But...that same sound can come from a really blown out head gasket (if you are still using gaskets)...where you have a burn through at the edge.
Also if for some reason a header pipe has come loose or seriously cracked.
Ray |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42048 Location: at the beach
Posted: Thu Apr 10, 2025 3:01 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
if it comes and goes, that can also be a valve seat. If so catch it now before it breaks the head off the valve and trashes more than a head. With these engines, anything is possible. That said, you could have a ten year old modern car and be facing a blown head gasket or dead transmission. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Apr 10, 2025 4:09 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
The Vanagon motor wouldn't have had exhaust injection holes, right? Surely they didn't continue to build the heads that way and just plug them up...
I have no idea if there are head gaskets- I lucked into buying that motor for a good deal. Turned it over enough to feel compression 4 times and smooth rotation, and bought it. When I got it home, I only changed all the oil seals and removed the Vanagon specific parts and bolted on the Bus specific parts from the original engine. Put it all together and tried it out, and it ran well, so I ran it!
Engine hasn't been out since I installed the fuel injection in 2016. It's been a bit leaky and the foam seal is starting to get crumbly if you touch it so I have/had been intending to pull the motor sometime and fix all that stuff up. I guess if was going to drop a valve today, I'm sorta glad I didn't do that over the past winter like I'd hoped.
Was originally thinking I'd use AAA to tow it home, but then later in the afternoon today it did occur to me that this Bus was a tow-behind vehicle for the previous owners, and I have a tow bar for it! Duh.
So I'll plan to tow it home tomorrow or over the weekend and see what I find. May not get too far into it until Sunday at the earlierst but we'll see.
Besides the regular stuff, it sucks a little extra because we'd been using this Bus for transportation/a backdrop for our shave ice side-hustle business and it's just now starting to be that time of year!
1973 Wild Westerner
My Thing |
Posted: Thu Apr 10, 2025 4:38 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
Sorry Dave, I didn't read the full thread to know that it was from a Vanagon but thought I should share my experience as it sounded similar.
If you need an incentive to do the swap, listen to my first start:
SGKent  Samba Member
Posted: Thu Apr 10, 2025 4:46 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
Shonandb wrote: |
Heh, no worries. I did specify it was a Vanagon motor in the YouTube upload, but forgot to write it in the post initially. Certainly makes sense why someone would assume a 1973 Bus' engine would have the ports otherwise.
That is pretty sweet! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Thu Apr 10, 2025 5:00 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
Quote: |
Surely they didn't continue to build the heads that way and just plug them up... |
They did. And donโt call me Shirley. _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Joined: January 01, 2007 Posts: 17769 Location: sticksville, ct.
Posted: Thu Apr 10, 2025 5:40 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
if you juuuusssst give it a little throttle off idle does the noise go away? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Apr 10, 2025 5:42 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
Itโs not combustion/exhaust related. The sound is happening once per revolution and not changing with throttle. Combustion/exhaust leak noises happen once every other rotation, and change with throttle.
Youโre looking for an 800bpm cause, not a 400bpm cause. A cylinder drop test (pulling once injector wire at a time) would make the sound disappear if so.
www.airschooled.com
timvw7476 Samba Member
Posted: Thu Apr 10, 2025 6:27 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
I've dropped an intake valve seat & driven on it to spare a tow $. They don't sound like that. The seat usually just wedges into the head as you limp to safety on three cylinders. That's a real machine gun sound you've got there. Check the valve springs. Probably find out The Dealio under those covers. : i |
SGKent  Samba Member
Posted: Thu Apr 10, 2025 6:40 pm Post subject: Re: Expensive-sounding noise, time for a Subaru? heh |
Abscate wrote: |
They did. And donโt call me Shirley. |
Roger _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
