Missing Generator Shaft Spacer
Nayr_Sremlahc
Nayr_Sremlahc is offline
PostPosted: Fri Apr 25, 2025 6:57 am    Post subject: Missing Generator Shaft Spacer Reply with quote
I had bought this Bosch generator brand new from J Bugs and it came without a generator shaft spacer. Without the spacer the pulley will not spin. The only spacer I have found so far is one for an alternator on Topline Parts, but it was too big. Two questions. Is there somewhere I can buy a new spacer? Is it normal for new generators to come with the spacer missing?
Semper_Dad
Semper_Dad is offline
PostPosted: Fri Apr 25, 2025 12:50 pm    Post subject: Re: Missing Generator Shaft Spacer Reply with quote
Not exactly sure of what spacer you are talking about.
Which item number?
EDIT: On second thought. I seem to remember a bushing/spacer of sorts that positions the forward pulley half a bit further back in order to clear the generator housing. Strange that it doesn't appear to be listed on this parts diagram. It would slide on to the generator shaft forward of the woodruff key. I think I had to cannibalize one off my old generator.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
Ozmello
Ozmello is offline
PostPosted: Sat Apr 26, 2025 10:58 am    Post subject: Re: Missing Generator Shaft Spacer Reply with quote
I had a similar issue when I bought my car. The original owner sent a new generator with the car and when I installed it there were issues with clearance between the generator housing and the pulley. Unfortunately, I had already binned the old generator, so any spacer installed on it was lost. I solved the issue by purchasing and installing an alternator which came with a spacer.
Doesn't help the OP with his problem, but wanted him to know he's not alone in running into this problem.
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Sun Apr 27, 2025 4:03 pm    Post subject: Re: Missing Generator Shaft Spacer Reply with quote
Without that spacer the pulley will get too close to the housing and rub against it.
Do you have your old generator? Maybe you can take it from there.
Otherwise, just ask the place you bought it from to provide one to you.
kreemoweet
kreemoweet is offline
PostPosted: Sun May 11, 2025 6:04 am    Post subject: Re: Missing Generator Shaft Spacer Reply with quote
Shaft spacers (there's one at each end) are commonly missing from "rebuilt" generators/alternators. The generator spacers and front alternator spacer are sized 15 mm ID, 20.4 mm OD, 6 mm thick.
'67 bug: seized by the authorities
