Derickpete Samba Member
Joined: October 01, 2013 Posts: 23 Location: Gardnerville Nv
Posted: Sat May 31, 2025 6:56 am Post subject: Master Cylinder |
| I’m replacing the resivor on the master cylinder and the previous owner used orange sealer so it wouldn’t leak. Is there a gasket that goes between the cylinder and the reservoir? Or what is used to make sure it won’t leak. |
racecougar Samba Member
Joined: July 31, 2023 Posts: 281 Location: Imperial, MO
Posted: Sat May 31, 2025 12:19 pm Post subject: Re: Master Cylinder |
| What master cylinder are you working with? Can you post a photo? |
Posted: Sat May 31, 2025 1:15 pm Post subject: Re: Master Cylinder |
| It’s the stock master cylinder on a 1963 dune buggy. The resivor screws to the top of it. |
Posted: Sat May 31, 2025 2:41 pm Post subject: Re: Master Cylinder |
This style? It uses an o-ring.
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20838 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat May 31, 2025 2:49 pm Post subject: Re: Master Cylinder |
Mine used a copper sealing washer.....But the stupid plastic body kept leaking at joint of reservoir and base connection, finally went to all billet reservoir.... _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Sat May 31, 2025 3:52 pm Post subject: Re: Master Cylinder |
| Thank you. I will get a o ring for it. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8857 Location: Sunset, Louisiana
Posted: Sun Jun 01, 2025 9:12 am Post subject: Re: Master Cylinder |
The one on my buggy always leaked too. I replaced it with a dual circuit master cylinder with a plastic press on reservoir.
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3559 Location: West Coast (Michigan's)
Posted: Tue Jun 03, 2025 12:53 pm Post subject: Re: Master Cylinder |
lotta bad options for M/Cs out there _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
