intermittent no-start
krusovice
krusovice is offline
PostPosted: Tue Jul 15, 2025 10:21 am    Post subject: intermittent no-start Reply with quote
Hi,
I'm tracking an intermittent no-start in my 2001 EVC. I'm looking for confirmation/suggestions before I start throwing parts at it.
Background: when I bought my camper, the PO told me sometimes you have to turn the key a number of times to make it start (but it always starts). When it fails to start, it makes a click that sounds like it's coming from the starter, as if the solenoid is not engaging.
Battery is at least a few years old. Seems to hold a charge fine.
We were on vacation last week, and drove to the Lake of the Clouds in the Porcupine mountains in MI. The last few miles were steep, slow, and hot. After our 30 minute walk, we went back to the EVC, and it did the clicking thing until the point that it seems the battery died. Probably like 30 turns. A jump start eventually got us going.
So I got home and ordered a starter. My plan is to replace the starter and the battery.
In the box is a notification that in some cars a heat soak can lead to a voltage drop.
This has me wondering if I don't have a battery or starter issue. Has anyone else had a similar issue? If so, what worked for you?
One other questions: the starter came with a bushing. I'm pretty sure I need to compare the shaft on the starters (old and new) to see if I need this bushing. If I need it, it's just a matter of oiling it, and slotting it into the opening where the starter goes in. Does that sound right? (Seems obvious, but better to make sure).
Thanks for any help.
1984 Vanagon 1.9/4 speed
2001 Eurovan Camper
kourt
kourt is offline
PostPosted: Tue Jul 15, 2025 11:08 am    Post subject: Re: intermittent no-start Reply with quote
Regarding the bushing, see my thread The great starter pilot/bearing/bushing mystery.
If this were my van, I would replace the starter and order an ignition switch to have on hand, just in case. That switch is not easy to replace.
kourt
2001 Eurovan Winnebago Camper
mikemtnbike
mikemtnbike is offline
PostPosted: Tue Jul 15, 2025 12:58 pm    Post subject: Re: intermittent no-start Reply with quote
I am not fluent with the later van platforms, so not really able to guide on statring issues other than the steps you are already taking, but chiming in to say I hope you had clear skies for Lake of the Clouds, beautiful place, was there last summer.
2020 GTI SE manual
61 BUS Premium Member
61 BUS is offline
PostPosted: Wed Jul 16, 2025 7:51 am    Post subject: Re: intermittent no-start Reply with quote
I'd do a load test on the battery. If it is more than about 3-4 years old, it may seem like it's fully charged when everything is off but might not be able to sustain enough voltage during an engine start when it's supplying a heavy load.
61 Bus, 76 Beetle, 2001 Eurovan GLS, 2013 Fiat 500 Abarth, 47 Plymouth Business Coupe, 58 BMW Isetta 300
Abscate Premium Member
Abscate is offline
PostPosted: Wed Jul 16, 2025 9:51 am    Post subject: Re: intermittent no-start Reply with quote
Inspect the pigtail between the solenoid and starter motor to see how corroded it is.
There are two bushings used on the T4, 12mm and 13mm and you have to match the shaft on the starter you use, of course.
gesoffen
gesoffen is offline
PostPosted: Thu Jul 17, 2025 3:45 am    Post subject: Re: intermittent no-start Reply with quote
As a first round of troubleshooting, I would recommend a thorough inspection and cleaning of all the electrical interconnections between the battery, starter, starter solenoid, and grounds (both engine/trans side and body side). Also, closely inspect the battery terminal clamps for both corrosion and cracks.
All connections should be clean and bright, all cables should be free of corrosion at the connections and free of frayed strands. Repair/replace as necessary.
1973 VW Superbeetle (1302) w/ RAT 2270 T4
2003 VW Eurovan Weekender w/ 2.8L VR6 AXK, DYA 5 Spd Manual Conversion
krusovice
PostPosted: Thu Jul 17, 2025 9:59 am    Post subject: Re: intermittent no-start Reply with quote
(I wrote this in the wrong thread. Working on my phone before coffee is not smart.)
Thanks for the replies. Iโ€™d hoped to get to the van today but a flight cancellation (boo) turned into 4 days at the cabin (yay).
I did clean the connection at the starter (it looked ugly) and I thought that would do it. Alas, no. Battery connections look good/clean but Iโ€™ll remove and check them again. The chassis ground definitely needs a look.
Iโ€™m going to replace the starter anyway. I have a new one and Iโ€™ll be in there.
And for the ignition to carry, do you mean the โ€œelectricalโ€ part - that connects to the harness - or the lock cylinder? I started searching and got myself confused.
Finally, beautiful day at Lake in the Clouds.
2001 Eurovan Camper
Saturn
Saturn is offline
PostPosted: Thu Jul 17, 2025 11:05 am    Post subject: Re: intermittent no-start Reply with quote
There is the lock cylinder (key) and the ignition switch (plastic housing where the wiring connects), you are looking for the switch. One of the recommended spare parts to have on hand in your Eurovan
In terms of the starter, an easy way to check if it is working properly is running a jumper between the male connector on the solenoid to the positive battery terminal. This bypasses the ignition switch/circuit, delivering 12V to this solenoid and should activated the starter. When experiencing a no-start condition on my 1995 EVC during a Thanksgiving trip, tried using a jumper on the starter and it remained dormant. When brushing the lead on the +battery terminal, the results were a bunch of sparks telling me the starter was most likely the issue and not the ignition switch. When returning home, tested the jumper wire bypass on my 1993 Weekender and the starter immediately started turning.
As an FYI, on my 1995 EVC, the starter is secured by 3 allen bolts and they were a pain get loose. Since you have the VR6 engine, not sure it is the same configuration. One of these had been removed about 2 years before when going through the cooling system and deciding to repaint the main metal pipe since it has a fair bit of surface corrosion on it. I pretty much mangled the head of it trying to remove it so it was replaced with a hex head bolt. When replacing the starter, the two remaining allen bolts took some perseverance and persuasion to get them to rotate. When installing the new starter, the hex-head bolt was repositioned to the backside of the starter as it is easier access that location with a socket than with an allen wrench.
1961tbird
1961tbird is offline
PostPosted: Tue Jul 22, 2025 10:33 am    Post subject: Re: intermittent no-start Reply with quote
In a no start situation.
Plan to:
1. Charge battery/check connections
2. Check starter (per jump to battery as posted above)
3. Assuming #1 and #2 are okay, then check ignition switch
#1 okay
In the process of jumping the starter, I noticed a broken brown/black wire (18 gauge maybe). It is located near the starter solenoid.
Given its length, there are only so many places it can reach. But try as I may, I cannot locate where it was connected.
BTW, the other end of the wire goes into a wire harness so no idea where it ends up.
Looked at wiring diagram but there was no mention of a brown/black wire on the logical pages I at looked at (i.e., starter connections, etc).
Maybe some pictures will help.
Thoughts?
1961tbird
PostPosted: Tue Jul 22, 2025 1:28 pm    Post subject: Re: intermittent no-start Reply with quote
Update: Cleaned up the connection of the starter solenoid/battery and she fired right up. I live on the ocean the salt air play havoc to electrical connections.
So the van runs fine. But still have no idea what that brown/black goes and what it does (?).
1961tbird
PostPosted: Tue Jul 22, 2025 1:49 pm    Post subject: Re: intermittent no-start Reply with quote
Opps. I spoke too soon. Put everything together and won't start.
I jumped the starter to battery and nothing. So I guess I'm in the market for a new starter. Funny, I installed this starter only 3 years ago. Quality of parts is certainly eroding.
Any suggestions for a high quality starter? Wasn't the original a Bosch?
Joshwa
Joshwa is offline
PostPosted: Tue Jul 22, 2025 2:27 pm    Post subject: Re: intermittent no-start Reply with quote
In the engine bay, I see Brown/Black being use for:
Brake fluid level warning switch; C/3
Horn ground ending up at A1/8, through a 2 pin connector T2N/2
93 Weekender TDI conversion (AHU)
93 MV TDI conversion (1Z)
Weekender rear cot
Late model cabin air filter on 93
Euro spec bumper install on 93
67rustavenger
67rustavenger is offline
PostPosted: Tue Jul 22, 2025 2:33 pm    Post subject: Re: intermittent no-start Reply with quote
Do you have "AutoZone" there?
I buy Type 1 starters from AutoZone here. They have a lifetime warrantee.
If the starter dies. I just go get a replacement, free of charge.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
1961tbird
PostPosted: Tue Jul 22, 2025 7:25 pm    Post subject: Re: intermittent no-start Reply with quote
Thanks for the brake and horn wiring possibilities. I'll check.
Unfortunately, no Auto Zone up here in Canada.
Is it typical for a starter to sometimes work then not? It's weird that when I cleaned up the starter solenoid connections it immediately started up then 10 minutes later nothing but lights on my dash and the clicking noise. So I'm back to square 1. Am I overlooking anything?
Da TOW'D
Da TOW'D is offline
PostPosted: Tue Jul 22, 2025 8:44 pm    Post subject: Re: intermittent no-start Reply with quote
I use Corrosion X spray on my electrical connections so they don't look like your starter's connections.
good stuff
Hank
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
Saturn
Saturn is offline
PostPosted: Tue Jul 22, 2025 11:16 pm    Post subject: Re: intermittent no-start Reply with quote
With my 1995 EVC, I had several instances of the starter failing to work, but those were weeks/months apart. From the first time this happened (Nov 22), it was finally replaced 9 months later (Aug 23). One of the things I tried which I did not mention in my previous post was utilizing a piece of wood to gently tap on the starter during a no-start occurrence (Mar 23). After doing this several times, the starter woke up and the engine fired up. I have done this with several different cars to get them to come back to life with various success. Usually ones which have been sitting for a long time. (March 23 no start post: https://www.thesamba.com/vw/forum/viewtopic.php?p=10017908#10017908)
I ended up ordering the (remanned) starter from FCPEuro for the EVC mainly because of their lifetime warranty. The one I received is for an automatic transmission which does not have the long nose extension going into the brass bushing piece Abscate mentioned in an earlier post. Since that was not on the starter, I did not replace the bushing part out at all.
WorthaTry
WorthaTry is offline
PostPosted: Wed Jul 23, 2025 9:16 am    Post subject: Re: intermittent no-start Reply with quote
I'd say it's atypical, but by no means impossible. My somewhat humorous anecdote in this vein happened in a Chevy Suburban. The starter worked just fine most of the time. On rare occasions it did absolutely nothing. Battery was fine. Usually when this happened, whacking it with a hammer would get it to go. Eventually I put 2 and 2 together and realized that it only happened when it had been driven on wet roads and then left to sit in sub-freezing temps overnight.
Diagnosis: water was getting into it and freezing. By this point the vehicle was running on borrowed time with over 200k miles and Upstate NY frame rot getting worse each year, so I just kept a hammer and a tarp in the vehicle.
2001 EV MV Wk
1961tbird
PostPosted: Wed Jul 23, 2025 10:30 am    Post subject: Re: intermittent no-start Reply with quote
Yes, apparently that Corrisson X is great stuff. Where did you source here in Canada?
Da TOW'D
Da TOW'D is offline
PostPosted: Wed Jul 23, 2025 12:54 pm    Post subject: Re: intermittent no-start Reply with quote
Aircraft Spruce
Branford Ontario
877 795 2278
$15 CDN
other dealers in the states
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
1961tbird
PostPosted: Thu Jul 24, 2025 11:13 am    Post subject: Re: intermittent no-start Reply with quote
Placed ordered. Thanks. It appears it may help a lot in my salt air
