Portable tire inflator
aeromech
aeromech is offline
PostPosted: Wed Oct 08, 2025 4:12 pm    Post subject: Portable tire inflator Reply with quote
Guys,
I just got a call from a good customer with a question. What's a good, portable, possibly battery operated mobile tire inflator to carry on camping trips? He has a Vanagon that's lifted and has big tires. He and his wife aren't spring chickens either so something easy to use that will fill a big tire please. I'm sure that the off road community has things they prefer but I thought I'd ask you guys first.
TIA
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Shonandb Premium Member
Shonandb is offline
PostPosted: Wed Oct 08, 2025 4:46 pm    Post subject: Re: Portable tire inflator Reply with quote
I've been using this one for the last 6 months to pump my tires back up to normal pressures after airing down for FSRs. It's digital and automatically shuts off at the pressure you set it to.
The fill rate for my 29" 225/75/16 Load E Goodyear Wranglers is about 1 psi per 3-4 seconds. I'm sure that there are better ones but this has worked well for our needs so far and I use it at least twice a month without issue.
Tire Inflator Portable Air Compressor Car Tire Pump with 3 Nozzle Adaptors and Digital LED Light DC 12V Electric Air Pump for Vehicle Tires and Other Inflatables Red
https://a.co/d/dPXcYcT
Previous 1973 Panel Bus:
Click to view image
67rustavenger
67rustavenger is offline
PostPosted: Wed Oct 08, 2025 5:30 pm    Post subject: Re: Portable tire inflator Reply with quote
I carry a tire inflator that plugs in to the cigar lighter, it has a long cord so I can reach all four corers if needed.
Have I used it? Not yet but, I still carry it just in case.
My inflator came as part of a roadside emergency kit, likely made in the ROC.
There are plenty if inflators that will work either on battery power or plug-in like mine and the one posted above.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
aeromech
aeromech is offline
PostPosted: Wed Oct 08, 2025 5:49 pm    Post subject: Re: Portable tire inflator Reply with quote
Keep the ideas coming guys
One thing I’m concerned about is running off a cigarette lighter plug in. Not sure it would be able to power a compressor off a 15 foot wire. Seems like clipping to the car battery would be best or something self contained like one made by Makita. Downside to that is once you deplete its battery, your done
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
67rustavenger
PostPosted: Wed Oct 08, 2025 6:07 pm    Post subject: Re: Portable tire inflator Reply with quote
And that's the problem with battery inflators unless, the owner has a backup battery on hand but, they take up precious storage space.
I inflated four golf cart tire with mine years ago that a coworker thought was funny to remove the shrader valve from as a joke. Yeah I know, I said I nave used mine. Well, I did on a golf cart not a car or van.
The cigar lighter cable didn't even get warm during the inflation of the tires.
BTW, my inflator is an older piston driven inflator not a rotary type like the newer ones are these days.
Buy Once, Cry Once!
Xevin Premium Member
Xevin is offline
PostPosted: Wed Oct 08, 2025 6:30 pm    Post subject: Re: Portable tire inflator Reply with quote
Hey G, I use Viair similar to this model. I don’t think they make my exact one anymore. I have it for 10 years. Nice and compact.
I use battery clamp style. Not comfortable running something like that through the 76 bus cigarette lighter port. My 85 Vanagon and the 76 bus run 14” tires. So no experience with bigger tires. I would tell your friend to buy one from a retailer with a good return policy and give it a try. Take care.
https://viaircorp.com/products/evc88p-digital-portable-compressor
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
Wasted youth
Wasted youth is offline
PostPosted: Wed Oct 08, 2025 8:44 pm    Post subject: Re: Portable tire inflator Reply with quote
Slime 40077
Digital setting (set it at 33 and it stops at 33)
$50 at Walmart.
I set up my daughter’s Honda CR-V with an 40077 and I also have Model 40063 for my 1984 Ramcharger. Like any 12 volt affordable & portable compressor, respect the duty cycle. No doubt you can ruin it if you want to pump up a Queen size air mattress.
Four sedan tires from 21/23 psi to 40 psi in under 10 minutes.
Exclamation The valve stem nozzle is different! Instead of attaching it to the tire valve stem and folding the little handle down to lock it on, you actually attach it to the valve stem and then pull UP the little lock handle.
SGKent Premium Member
SGKent is offline
PostPosted: Thu Oct 09, 2025 1:29 am    Post subject: Re: Portable tire inflator Reply with quote
Milwaukee M18, especially if they already have any M18 battery tools. I have one and it is really nice. Expensive but outstanding.
Might want to look this over
George Carlin:
Skills@EuroCarsPlus:
rsbadura
rsbadura is offline
PostPosted: Thu Oct 09, 2025 1:44 am    Post subject: Re: Portable tire inflator Reply with quote
I‘ve installed an „ARB CKMA12 12V“ compressor inside my bay window for sand deserts and other travel issues - already used at a Sahara trip.
it‘s mounted below the front seats with air tubes to both sides ready to use:
(in the spare wheel compartment - in the picture without seats, 9-seater bus)
the others are compressed air hose, tire inflator with pressure gauge, axe, saw, shovel, radio antennas, ...
regards,
Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools collection
richparker
richparker is offline
PostPosted: Thu Oct 09, 2025 2:31 am    Post subject: Re: Portable tire inflator Reply with quote
I carry the Ryobi 18V one that's posted in the YouTube link above on road trips. I make sure I put a charger battery in it before I hit the road. It works just fine for inflating air mattress, bike tires, car tires, etc. it’s compact and light weight.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
danfromsyr
danfromsyr is offline
PostPosted: Thu Oct 09, 2025 8:35 am    Post subject: Re: Portable tire inflator Reply with quote
same but I carry a dewalt 20v inflater.. plenty of battery for several tire fills, let alone many top offs.
my brother and my mom's van each have the ryobi 18v one..
nice thing about Ryobis is that they have a small socketed 18v charger for the handvacs etc. and we have a small 110v inverter anyways.. so even on long road trips with heavy tire use we can recharge the battery easily.
to note I also on occasion carry a 18v 8in ryobi chainsaw... more for camping in the woods than @ the beach..
lastly to the corded use ones, if the cord comes with the unit it'll be fine.
I've installed a marine external 12v socket at the rear valence.. since the Alternator cable is right there.. a short lead with a 25a inline fuse and I use it to power external lights/chargers.. it's a easy cheap and painless install.
I had/do plan to add a front 12v socket that taps into the constant 12+ of the radiator fan switch. but haven't really needed that yet..
2nd lastly. some have mounted the 12v Vair compressor in the drivers seat battery compartment and then carry a length of coiled air hose vs coiled power cable.
many ways to skin this cat
Abscate wrote:
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu Oct 09, 2025 9:19 am    Post subject: Re: Portable tire inflator Reply with quote
My Milwaukee M12 in Buddy can inflate all four tires from 12-15 psi back to road pressures in about half an hour, with enough battery left to do one or two more tires. I have an M18 too but it stays at home for space savings because the M12 is good enough by far.
Coincidentally, I’m driving BigEmma right now and the 12v cigarette socket compressor is so frustrating to use I’ve just been stopping for gas station air every few weeks as the seasons change.
For the San Diego crowd, Wink when the temps drop 30-40 degrees overnight, it’s worth topping up on air to keep the Grabbers from giving early onset tinnitus.
Robbie
www.airschooled.com
Road trip reports and tech blog:
OB Bus
OB Bus is offline
PostPosted: Thu Oct 09, 2025 3:59 pm    Post subject: Re: Portable tire inflator Reply with quote
We have the same and the inflator is awesome. A Ryobi 18 volt 4 amp hour battery lasts a long long time.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
aeromech
aeromech is offline
PostPosted: Thu Oct 09, 2025 4:04 pm    Post subject: Re: Portable tire inflator Reply with quote
Thanks everybody. Eric texted me to let me know he ordered a Craftsman from Amazon. I appreciate all the info.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
TomWesty
TomWesty is offline
PostPosted: Thu Oct 09, 2025 5:53 pm    Post subject: Re: Portable tire inflator Reply with quote
I second this.
Wildthings
Wildthings is offline
PostPosted: Thu Oct 09, 2025 7:17 pm    Post subject: Re: Portable tire inflator Reply with quote
You can get a combined battery jump start and compressor in the same unit.
metahacker
metahacker is offline
PostPosted: Fri Oct 10, 2025 2:43 pm    Post subject: Re: Portable tire inflator Reply with quote
IMO
for casual tire filling, i tried a bunch of them and this one can't be beat.
very high build quality, lithium battery, etc.
just set the psi you want and attach it and let it do it's thing.
https://amzn.to/4mVqK23
for serious (non-portable, installed on the vehicle) use, like airing way down to go off-road and then being able to re-inflate quickly ... there's only one choice .. the ARB (twin or single compressor) units ... or their chinese knock off equivalents .. with a tank .. etc
standard twin piston
https://amzn.to/471onF7
new brushless twin piston
https://amzn.to/4n36hbI
single piston
https://amzn.to/3J5ZNec
for something in between ... 12V cigarette lighter, that new NOCO sure looks interesting
https://amzn.to/3KL2imG
raygreenwood
raygreenwood is offline
PostPosted: Fri Oct 10, 2025 3:01 pm    Post subject: Re: Portable tire inflator Reply with quote
Oh good! You found that and posted it. I saw that when it came out.
I had a decent one back in the 90s in my trunk that saved my ass a few times. I used to travel a lot and several times I would come back after a week or so on the road and find my car at the airport park and ride with a flat from a slow leak. The emergency service tab at Atlanta Hartsfield airport for tire air in 1995....was $60.
And no you could not call a tow truck as they cannot get in. Having ny little plug in pump in the trunk of my 412 saved my ass.
Been looking for a new one. Ray
